Detailing basics - diagrams & dialog (long but worthwhile)
Well it was a snowy day today in NH :snow: so I finally had some spare time to get to this write up done. It’s always good to go back to the basics every once and a while. I am a visual learner and figured that it would help others to associate a picture with words. This is a basic overview of some of the basics (if you will) in detailing. It isn’t a step by step or a ‘how to’ rather pictures that should be helpful in a variety of situations. The pictures are not drawn to scale but it should give you the general idea.
Ideal paint situation:
http://i124.photobucket.com/albums/p...deal-Paint.jpg
In an ideal world, automotive paint will have adequate thickness and be perfectly flat. However we don’t live in an ideal world. Most of the pictures coming are based off of this ideal paint situation, only to make my life easier. The paint on every car is different so take that into consideration when you are detailing. The above picture is a clear coated vehicle – it has a base color coat as well as a top clear coat. Almost all vehicles sold today are clear coated. Some higher end vehicles and older vehicles are single stage paint, essentially just a base coat:
http://i124.photobucket.com/albums/p...nt/SSpaint.jpg
When polish a vehicle with single stage paint, you will notice paint transfer on your pads. Be sure to keep your pads clean and free of excess paint build up – this will hinder the polish’s performance. If you have paint transfer on your pad but believe your vehicle is clear coated, you may actually have a tinted clear coat. Typical clear coat is paint with no pigments in it. Tinted clear coat is just that – clear paint tinted with the base color:
http://i124.photobucket.com/albums/p...int/tinted.jpg
Orange Peel:
http://i124.photobucket.com/albums/p...8/paint/OP.jpg
Orange peel is essentially a paint defect occurring in the paint booth. Improper air or thinner mixtures causes the paint to resemble an orange peel. Some people do not like orange peel and wet sand the paint to an even level. This, however, is not a good idea to do on a factory paint job. As you see in the picture, in order to remove the orange peel, you’ll have to remove a significant portion of the clear coat, which could lead to premature paint failure in the future.
Oxidation:
http://i124.photobucket.com/albums/p.../oxidation.jpg
To me oxidation is basically dead paint on the top layer of the car. Oxidized paint looks cloudy, chalky, lacks depth and is hazy. Many try to remove oxidation using an abrasive polish however that is not the best way to remove it. A paint cleaner and a polishing pad will cut through oxidation and leave the paint clean and ready for polishing.
Polishing:
http://i124.photobucket.com/albums/p...int/swirls.jpg
It is probable that every vehicle you detail will have swirl marks, spider webbing or marring. These defects are minor scratches in the clear coat and are visible because of light catches the sharp edges of the scratch.
http://i124.photobucket.com/albums/p...nauba-a-OB.jpg
Many people use an orbital polisher to remove this type of marring. After polishing the paint looks swirl free but the swirls may still be present in the paint. Depending on the polish and pad used, the swirls and marring may just get rounded over, so the light doesn’t catch the sharp edges anymore.
http://i124.photobucket.com/albums/p...rotary-SMR.jpg
A circular polisher, aka rotary, actually removes part of the clear coat thus removing the swirls along with it. That is why excessive compounding with a rotary is not a good idea. However, I believe that a rotary also rounds off the scratches like an orbital but most of the time the swirls will be totally removed, especially when done by a professional.
Scratches:
http://i124.photobucket.com/albums/p...ghtscratch.jpg
A light scratch pictured above can be removed. As long as you can not feel it with your fingernail, you should be able to remove it. The scratch may have a white tint to it but if you can’t feel it, it is probably still in the clear coat. A polisher should be able to remove it. Also, a compound and a terry cloth towel is a really good way to remove isolated scratches as well.
http://i124.photobucket.com/albums/p...eepscratch.jpg
On the flip side, a deep scratch like this one is not easily repairable. This scratch is down to the metal, and if not taken care of, rust will begin to form. You can use touch up paint to fill in the scratch and the sand off the excess to maintain a level surface. If the scratch is deep and long, the only realistic thing to do is have that panel repainted.
Contamination:
http://i124.photobucket.com/albums/p...tamination.jpg
The above paint surface has a ton of contamination on it. Some is visible to the naked eye, however some is not. Take a plastic baggie, stick your hand in it and rub you hand on your clean paint. If it feels rough, you need to clay. Claying removes contamination such as industrial fallout, rail dust, and embedded debris. This contamination sits on top of the paint surface and a clay bar, when properly lubed, shears off the top of the contamination, leaving a clean and level surface. In the above picture working left to right, you see some rail dust that has began to rust, tree sap, embedded dirt, and industrial fallout.
Water spots:
There are two types of water spots – mineral deposits and water etching.
http://i124.photobucket.com/albums/p...r-deposits.jpg
Water / mineral deposits are simply left over minerals found in water. Water left on the surface evaporates and leaves behind these minerals. These minerals sit on top of the top coat and will get harder to remove the longer it sits on the paint. If you are having a difficult time remove water marks, soak a microfiber towel in vinegar and lay the towel over the spots. The vinegar will likely loosen up the minerals for easy removal.
http://i124.photobucket.com/albums/p...nt/etching.jpg
Water etching is a more serious problem. I’m not 100% sure what causes water etching but acid rain could be one of them. This is when water and its minerals actually etches the clear coat. This is the same concept with bird bombs. These are nasty! There is a good chance that only wet sanding and compounding will remove all of these marks. This is why it is always good to dry / remove bird bombs ASAP!
LSP:
Now that the paint is free of defects it is time to seal and protect the paint.
http://i124.photobucket.com/albums/p...aint/glaze.jpg
Glazes usually contain oils and fillers that fill in swirls making the surface look defect free. These are used to either enhance the finish or hide marring. Glazes are also used by people who do not want to over polish – keeping a safe amount of clear on the vehicle.
http://i124.photobucket.com/albums/p...auba-ideal.jpg
A nice LSP is a carnauba wax. A carnauba wax actually sits on top of the paint protecting it from the elements.
Carnauba waxes may also have “filling ability.” The layer of carnauba will settle in the valley of the swirl and the swirls will disappear yet they may still be present. This is the same concept as orbital polishing; the sharp edges of the swirls aren’t visible anymore.
http://i124.photobucket.com/albums/p...nt/sealant.jpg
A polymer sealant molecularly bonds to paint, making it very durable. However, the layer is thinner than carnauba so sealants generally don’t protect as well as carnauba when it comes to contamination and such.
Well, that is all I have at this point in time. Hopefully you didn’t fall asleep through this :eek:. I hope this will be beneficial to some. Happy detailing! :cheers:
Re: Detailing basics - diagrams & dialog (long but worthwhile)
Excellent post Budman!!
It is nice to have such information for this forum. Thank you for taking the time to get this information to the masses.
Quote:
Originally Posted by
cwcad
+1
Just an amazing job :bigups
I`ve made it a sticky so people won`t have a hard time finding it.
Thanks again
"J"
Great write up budman3! :bigups
Thanks for taking the time to create and post this. :yourrock
Dave
Here is part 2- Diminishing abrasives:
I’m not sure if anyone else is confused about diminishing abrasives, but here is my take on the subject. Let’s start off with and example- sand paper comes in different sizes of grits and a quality piece of sandpaper will always maintain that same grit throughout the entire process. Since the grit is the same when you begin and finish, it has constant abrasives. In detailing, many companies have developed polishes with diminishing abrasives. These polishes start off aggressive to cut through damage and then the abrasives break down into smaller particles to create a smooth surface again.
Since you want to save as much clear coat as possible, do a test spot to find the least abrasive method which will remove the damage. You do not want to use a compound that is too aggressive – it will remove the swirling and marring BUT it will also remove clear coat that doesn’t have to be removed. This is why it is key to do a test spot to find a polish and pad combo that will remove the marks but nothing more. Once you become familiar with different polishes and pads, finding a combination will become easier. Many “hack detailers” simply grab a rubbing compound, a wool pad, and a rotary and go at it. Sure the marring will be removed but the clear coat will be as well. Also, if you do not let the polishes break down, you can be left with buffer swirls. Always use the least aggressive method as possible!
Once you find a polish, pad and even machine combo, it is time to work that polish into the paint. Different polishes ‘flash’ or work into the paint for different amounts of times. Experience with the products you are using will useful so you know how long to work it in.
Below are simplified and magnified versions of what is going on when you are polishing with diminishing abrasives in a two step manner. Polishing may definitely take more than two steps, but for simplicity I left it to only two. Possible examples of this type of combo are, and not limited to:
Menzerna Powergloss followed by Nano 106ff
Poorboy’s SSR2.5 followed by SSR1
Pinnacle XMT3 followed by XMT1
Meguiar’s #83 followed by #9
Etc.
http://i124.photobucket.com/albums/p...rd8/dim-ab.jpg
http://i124.photobucket.com/albums/p.../dim-ab-fp.jpg
So, let me try and explain this a little more. As you see above in step one, the abrasives start off large but when friction occurs, the abrasives begin to get smaller and smaller. If you stop before the abrasives have had a chance to break down, you will be left with micro marring, which could have been removed if you kept on polishing. It is possible to finish a compound off in just one step if you use a soft pad with proper techniques. However, it is likely there are some light marks or marring still left, which is easily removed with a final polish.
The final polish diminishing abrasives (in an ideal world) will start off close to the same size as the broken down abrasive from the compound. Once the final polish has broken down, the abrasives will be very very small. This will remove any marring left from before and will finish off to near perfection.
Again, this is just my personal take on the subject at hand. Let me know if you read anything out of line or if you have anything to add. This isn’t meant to be a tutorial on how to polish rather just some background on something that can get a little confusing.
thanks for the excellent write up and taking the time out to do it.:bigups
Excellent write up, some very handy information
wish i read this earlier !
