Re: My first one step polish
No chance you can avoid direct sunlight? I`d be starting as early as possible, so those panels do not get a chance to heat up
It’s suppose to be partly cloudy but other then that I will be staring at sunrise
Either of those polishes will do just fine. You could essentially flip a coin and choose one. I have not used any of those in direct sun though.
Do you think I’d be better off using 3d speed? I have some left over I polished my truck in the spring with it in direct sunlight with no issues
Test spots with all of them. i HAVE BEEN GETTING ABSURD ! Step RESULTS lately with Menzerna 400 and a Blueberry UroTec pad. You never know what works til you try it all out
Great choice on the duragloss it my favorite sealant very crisp look. Even with all the fancy new polishes I still like the 205 as a go to. I’d say use 3D one has most lube just chase shade by parking your car at different angles and get some old bathroom towels to put over the panel you have to polish next. Lay the towels on top of panels to block sun until you polish it will help keep your temps down and have at it!
400 and stiff pad is good stuff
I ended up using 3d one came out good four section passes. Only issues the sun gave me was during wipe off just seemed to smear more then it should. Letting the duragloss 111 haze then I’ll get some pics.
