Originally Posted by
Desertnate
Not only is it really easy to apply, but from what I`ve experienced the water behavior is very similar (if not identical) and the look is just as good, if not better. The only down side is it won`t last years like a coating. If you`re happy with what you have now and don`t want to add the cost and additional work of a coating, I`d stick with what you have.
If nothing else, since you`ve already got the sealant on there let it run it`s course and once its worn out you can then worry about whether or not to coat the car.
