Re: Final LSP conundrum...
I voted to use the PA, Overcoat style goodies. If you later decide you want the expensive coating “back”, these won’t last a year like Cancoat/Moonlight. Plus you could argue that you’re using expensive to top expensive. And they’ll possibly/probably make a better visual enhancement than Cancoat or Moonlight. They’ll be easier to apply. More fun factor. The coating itself is practical so add the fun in.
The main upside of Cancoat/Moonlight would be the extra protection like you mention, but let the $200 coating be the main protector and just have fun on top for looks and behavior.
Just my two cents. :). Fun questions!
When I had the CSL/EXO3 on my car the only thing I used regularly was PA HG even tho I did try overcoat but liked the HG better. Since my 500ml (been using for almost 3 years now) is almost gone yesterday I ordered the High Gloss paste wax to give a try.
Here is a shot of how that combination looked.
https://photos.smugmug.com/photos/i-...LDLXLTP-X3.jpg
Here is a picture I found that I took while washing 7 months after the coating application but not sure how long the High Gloss had been on at that time. You can see how well it is beading and I use a Milwaukee leaf blower to dry with myself and touch up with one drying towel after.
https://photos.smugmug.com/2017-10-2...8.09.47-XL.jpg
Can you go into detail about your Exo failures and what you mean by this? Also about drying your car are you sheet rinsing or still leaving a lot of water on the surface?
So to dry the car I normally sheet the majority of water off using an open hose then blow off / out the remainder with a dryer.
Sometimes I skip flooding the panels because I like seeing beads being quickly dispersed (how sad am I... but I guess safer than looking at my bonnet on a motorway ha!).
I don`t want to beat Exo up too much as Gtechniq have really looked after me and provided great aftercare. What I will say though is that I have found Exo to struggle to perform without topping over the course of a harsh winter - that`s pretty poor for a 18-24 month product marketed how it is. It`s not on it`s own, people have said the same about some Gyeon ceramic top coats (Skin is one - but at least it has incredible peak performance).
Exo has now been professionally applied to my car (this time over Ultra) 4 times including the original detail. I can`t comment on how it`s working this time as I`m yet to pick up the car. The first three `failures` - reduction of beading from 5 weeks in, sides of the car completely flooding after a month in winter - all supposedly due to a CSL issue which I hope has now been rectified. This could not be cured through using compatible Gtechniq decon products and has genuinely puzzled all concerned.
Regardless of whether it`s sorted now, I do believe I have seen (albeit for a short period before eventual deterioration) Exo V4`s peak performance and this does not come close to the self cleaning, water behaviour and slickness of other coatings. I was tempted to top Ultra with another product but figured it was no harm in having the extra protection of Exo and the option to top that.
I really don`t like the idea of topping the ceramic top coat to potentially top that with a maintenance product, but if that`s what I have to do to have an exceptional performing top coat so be it!
Sounds like you need to switch coatings based on the trouble you’re experiencing. A coating shouldn’t need a topper and should last multiple years with just an occasional decon wash.
I think half my problem is that I use high pH cleaners during the winter to remove road grime and dirt before laying a mitt on my paint.
The snow foam I use is between pHs 10 & 11, within the limit of what Exo V4 and Ultra can resist, however weekly or twice weekly hits in my experience does take it`s toll on a coating`s water behaviour over time.
Given my pre-wash regime I ended up opting for a more substantial `topper`, Gyeon Cancoat which I have used many times in the past with great results. I don`t intend to use any further toppers on it in the short term, only as and when required.
Quote:
Originally Posted by
atbalfour
I consider that pH only mildly alkaline and along with the dilution you get from a snowfoam I`d be severely disappointed if that made a dent in a coating even with weekly washes.
The only time I was satisfied w/ CSL (and really ended up liking it) was when I put Cancoat on top of it. It kinda retained the `richness` of the base CSL while vastly improving the water behavior. Added a nice bit of candy gloss to the CSL as well which was either real or all in my head.
atbalfour
I use Mckee’s coating prep soap and Bilt Hamber auto foam on my car. BHAF every other week and once in a while sub in a wash with Mckee’s CP when i need a deep clean. Both Alkaline and Neither has affected performance of coating. In fact the perform better.
