Is Graphene the next big thing for coatings?
This is going to be a long one so lets see who makes it to the end :)
As stated in the title of this thread, is Graphene the next evolution of coatings or is all hype?
We have all seen Graphene become the next buzzword in the world of ceramic coatings and all these youtubers praising how great it is as the next big thing while sort of writing off Silicon Dioxide coatings without any further test data. I attribute this to not having time and being sent various products to test out. So I am hoping to provide some feedback that is somewhat useful.
Before I move on I will be referring to Silicon Dioxide coatings as SiO2, quartz or ceramic. All are interchangeable.
At the time I am writing this, it is too soon to tell if Graphene will stick around as these products are in their infancy. Will it fade away in existence or will it survive the test of time like quartz based coatings.
We have a multitude of coatings along with different variations of chemical make up these days. These coatings are tried and true and they are going to stick around for awhile. Graphene has a lot of work ahead to dethrone SiO2.
Next we move onto pricing. Graphene is expensive and thus the product is expensive. At the same time these introductory products probably don’t contain too much Graphene. Again it is an expensive substance.
A known fact is that quartz coatings are prone to water spotting. Not everyone has experienced this issue and those that have get disappointed due to wanting that perfect product. The holy grail. This is where Graphene coatings are claiming anti-water spotting. This may be true but only time will tell if this solves that issue. At the same time the current Graphene coatings are sacrificing hardness. Although not something to really focus on. For example SPS claims 7H while other coatings are claiming 9H and some even 10H.
I originally wrote this review on the SPS Graphene Product sometime ago. Unfortunately I did not have it on long enough to really provide good information on.
https://www.autopia.org/forums/detai...e-coating.html
I then added it as part of my coating test comparing it to other coatings.
https://www.autopia.org/forums/car-d...ng-1-test.html
I decided it was time to polish my Grand Prix as the 21 month Cquartz UK 3.0 did it’s job. Such a great coating. I chose to go the SPS Graphene route to get more data and to see how well it would perform long term.
I have a friend of mine who whispered into my ear that IGL is planning to release a Graphene coating through their authorized installer network. This got the wheels turning and asking “what if I use IGL F4 Renew as a primer polish?”.
Those of you familiar with the product will come out and say, Mike you are crazy since IGL F4 states it is not to be used a primer polish. This is true. This product would fall in line with something like CarPro Essence. I thought to myself as soon as IGL releases their Graphene coating they are going to come out and say yeah F4 can be used as a primer. I even contacted IGL through facebook asking them if it would work with another Graphene infused product. All they said was no with no real reason. I read the back of the label a few times and IGL states F4 is not to be used as a primer for their Eco Coat coatings. Their eco coat line is all quartz based. Well SPS is not quartz based. So why not use them together is my way of thinking.
This is the end result.
https://www.autogeekonline.net/galle.../IMG_6364a.jpg
So I proceeded with my course of action. I did the normal chemical and mechanical decontamination. Followed that up with Meguiar’s M210 on a Rupes yellow pad using carious Rupes tools. This was more than enough to remove the 21 month Cquartz UK3.0. M210 is impressive on its own and the gloss it was leaving was great. I followed that up with a prep wipe using Meguiar’s M122 Surface Prep. Came back with IGL F4 Renew on a Rupes white pad. Let that set up for a couple minutes after wipe off and then followed up with Meguiar’s M122 to remove any remaining residue without removing the deposited Graphene. Finished it off with two layers of SPS Graphene coating.
The paint was in good shape. I gave myself a pat on the back for keeping the paint virtually swirl free for 21 months. I saw no defects under the Gyeon Prism Plus light on the silver paint. The swirls on the black pillars were minor.
Before on the left and after on the right after using M210 on a Rupes yellow polishing pad. I took advantage of the minor filling from IGL F4 later on.
http://www.autogeekonline.net/galler.../IMG_6332a.jpg
The end result of all this work was a glossy and silky smooth finish.
http://www.autogeekonline.net/galler.../IMG_6408a.jpg
http://www.autogeekonline.net/galler.../IMG_6410a.jpg
http://www.autogeekonline.net/galler.../IMG_6412a.jpg
http://www.autogeekonline.net/galler.../IMG_6414a.jpg
The paint was much brighter under the sun after after polishing and a fresh new coating.
http://www.autogeekonline.net/galler.../IMG_6425a.jpg
http://www.autogeekonline.net/galler.../IMG_6428a.jpg
I am going to mention this. This is more of an experiment to see if these two Graphene based products play well together. Detailing in the end involves experimenting with products from time to time. This can sometimes result in a failed experiment or a successful one. I am not concerned with durability or longevity with this combination. We do still have the coating test where SPS is bonded to bare paint.
A few thoughts on the products I used.
Meguiar’s M210 is a very good polish. Easy wipe off and definitely less oils than M205. A little less cut but the finish from it is great.
For IGL F4 Renew, the first thing is swap out the cap. It is terrible. The product itself is thin and rushes out of the cap. IGL needs to get rid of these caps. As far usability it is pretty straightforward. The minor issue is that it can be a pain to remove if it is left to sit too long or if there is excess product say when turning off the polisher. The overall finish is very good and the surface is nice and slick.
SPS Graphene is nice to work with. It does not need long to sit once it can be wiped off. It does not rainbow like a typical coating. The overall finish it leaves behind is silky smooth and it gets even slicker the longer it cures. Think Gtechniq CSL/Exo combo or Gyeon Syncro, either Cquartz coating topped with Gliss, but on another level. It just feels different in a very good way.
Thanks for reading through and stay tuned for updates along the way. I will be maintaining it with the SPS Graphene spray detailer. I also applied SPS to one of my wheels on January 25, 2020 to see how it holds up over time. So far so good.
Application
https://www.youtube.com/watch?v=WaT6Qz4DHPs
Walk around
https://www.youtube.com/watch?v=iT4RcyqAD64
Re: Is Graphene the next big thing for coatings?
First, great write-up, topic, etc Guz!
OK, I`ll throw my hat into the ring!
I`ve been testing SPS`s Graphene coating on one of my vehicles for the past 10months. I just updated my review on here.
I am continually impressed by this coating. The characteristics/properties are still going strong and are impressive at this date/time.
I am a certified installer of SPS and 22ple coatings. I mainly use 22ple Mistico Elemento Forte as my primary coating. I have done a few client`s vehicles with SPS with excellent results. I`d put all of the top tier coatings into one basket as each of them have the properties and attributes that we are looking for. Some just do it in different ways-sheeting/beading/etc, etc...
Now, onto the topic at hand:
From MY experience I will say that yes, Graphene coatings, infused products, etc, will be the `next big thing` in our professions/passions. This could be two-fold: 1.) `We` are always looking for the latest and greatest and love buzzwords. 2.) `We` seek out products that work, are easy to use, and will give ourselves/our clients a positive experience both in the short and long term on their vehicles.
Again from my experience, the particular product I used has impressed me greatly.
My $.02!!!
Nice write up Mike, definitely thinking outside the box, I was wonder why someone asked if F4 would be a good primer polish before Graphene on the SPS Facebook page.
As I mentioned to you I recently used Slickback as a primer polish on my daughter’s car.
I actually used another company’s base coat under one coat of Graphene on part of my wife’s truck to see how they play together. All three of our vehicles were coated within 6 weeks of each other so I’ll be able to get a good comparison.
I’m interested in seeing how the Graphene does in the wheel test. I’ve only used SPS Metal Oxide on wheels and calipers.
Quote:
Originally Posted by
Sizzle Chest
My $.02!!!
Thanks for the update. It is nice to see someone with long term results using it. The thing that impressed me the most is the feeling of the coating as it cures and after it cures. The smooth and slick feeling seems to last quite a bit of time. It does have some of the tightest water beading.
DaveT435
Thanks Dave and thanks for setting me with them to be an authorized user. So someone else did ask about F4 on the SPS page. Do you recall what was said?I will have to check it out. I figured it would be a good idea to try them out together. I can tell SPS went on it just fine because the surface tension changed. SPS is slicker that F4.
It will be interesting to see how your testing goes.
I will definitely update you on the wheel test. I have been using the spray detailer every other wash and both work well together. I will ping you more about Metal Oxide to get some more info on it. I plan to test it out at some point.
On a side note I did see it on my coworkers car in the parking lot at work before the pandemic hit. I have to say for me not maintaining it and him just taking it to a hand wash, it has been holding up well. It does have minor swirling but the gloss is still there.
https://www.autogeekonline.net/forum...ona-392-a.html
Someone came back and said it wasn’t a prep polish. I mentioned the Slickback test then someone mentioned that you had posted about the F4 as a prep polish.
You welcome for setting you up. Glad I could help. Your work is incredible and reflects positively on SPS.
Glad your co workers car still looks good.
I have been researching and reading up on use of Graphene in coatings. While I see that there appears to be good factors in the use and integration I also think its fairly early in the process to think its the next big thing. The % ingredient in current coatings is fairly low making me wonder if its the Graphene doing the work or the other additives? Also the fact that currently its mostly "Pro Only" seems to be counter intuitive to it being the next big thing. Currently I think the % ingredient needs to increase drastically and there needs to be real long term durability and usage at the normal consumer level. Thats a problem where all these "Pro Only" coating have so little in the way of documented long term usage and reviews from the end user not just the detailer applying them.
The more detailing I do the the more coatings I use I am really starting the question the "Pro Only" model for "top tier" products. If the coating is that good why not get it into as many hands and users possible? Unless there is some super special cure lamp or something that is required. And even then if people are willing to go to the trouble then it says something about the coating. In reality its the polishing and the prep where the real "Pros" shine and make their money. And from what I have seen the warranty stuff on coatings is just a worthless piece of paper with way to many rules and reasons to not honor the warranty. The real Pros stand behind their work and are their own warranty.
THE GUZ
I was reading somewhere that since graphene coatings are lower on the hardness scale will they be more susceptible to scratching from routine washing or road debris then SIO2 coatings ?
I think the graphene also read will maybe the king of hydrophobic properties.
I was also wondering is Car Pro , Fireball and , TAC Systems all one in the same company or some how are they related?
I appreciate all the testing you have done.
TroyScherer
It is Marketing.. They used to just require you to have a business license, perhaps pictures of your work, etc., good reviews from Clients, years of experience, etc.
Then, it got to "you have to pay much more, and we are going to send you much more product = a finishing compound, plus the coating, etc.,. that you have to pay for, or we will delete you", kind of business..
I think they like to make it for "Pros" only because that is a Captive Audience, they think this group will have the $$$, become dependent on them, and will sometimes, do anything to stay in the group..
The inexperienced user who purchases the most expensive Pro coating and does everything Wrong, will be calling them about returning it and a refund.. The real Pro will not be doing this as often, if ever, unless the coating is really a disaster to start with, no ??
Yes, it seems to make more sense to sell it outright to everyone, but the old, old, old, tired, marketing model of the 50`s, 60`s, still prevails !!!!
""We have something "special" and only "certain" people can have access to it.""
So in the end, the "Pro" is Selling their "Pro" product for them, will take the heat/blame/etc., most of the time for any problems, and will always be THE Warranty to the Client, while the Company gleefully rolls along pushing their products on you whether you like it or not..
This might be the ultimate Pyramid scheme of all time ! :)
Dan F
We should start a betting pool on next company to come out with a graphene coating... can’t use IGL... I would hope carpro,
Stokdgs
So in the end, the "Pro" is Selling their product for them, will take the heat/blame/etc., most of the time for any problems, and will always be THE Warranty to the Client, while the Company gleefully rolls along pushing their products on you whether you like it or not..
Dan F
I think this is driven more by the professional detailers than manufacturers. Pros don’t want hobbyists to be able to get the exact same product they are selling. You have guys out there charging 1500-3000.00 and more. We all know there are a lot of us hobbyists who can put out the same level of finished product. If they’re installing the EXACT same product it’s going to be awfully hard for a pro to be able to justify charging a customer 50-500% more. Case and point we used to be able to get Opti-coat 2.0 but the pros complained because they were having to compete with hobbyists.
@Stokdgs
I was one of those early users that got to use the original Opti-Coat and had great success. I like it so much I did 1 customer car. At the end of the day I was the warranty and I had to back up the work. I was really disappointed when they decided to go "Pro Only" especially when the Pro shops that did crap work then started selling the work and it diminished the overall rep in my opinion.
DaveT435
@Dave
If the "Pro Detailers" are the ones that drive this change I don`t think they are looking at their markets correctly. Us hobbyists that are this deep into detailing know what we are getting ourselves into and know the work involved. We are not the target market for the "Pro Detailers" business. Many of us would only ever do our own vehicles or maybe just a few customers. But our market share is so much smaller than what the "Pro" can do. And at the end of the day most of us hobbyists are the ones out there giving the long term results and praise tot he coatings.
I will go back to what I said before:
In reality its the polishing and the prep where the real "Pros" shine and make their money. And from what I have seen the warranty stuff on coatings is just a worthless piece of paper with way to many rules and reasons to not honor the warranty. The real Pros stand behind their work and are their own warranty. If they are worried that I can buy and use the same product as they can then they should be more worried about if I decide to open up a detailing business because they are worried that I am better then they are.
So when can I actually get SPS or any of these new Graphene coatings? And when will we have a system where you can put down the Si02 coating as a base and then a Graphene topper that gives us the best of both options.
TroyScherer
@Stokdgs
@Dave
Thanks for your opinion. You have yours and I have mine. When the whole Opti-coat thing went down there was a lot of discussion about this subject.
TroyScherer
Google artdeshine.
DaveT435
You would think in 2020 the DIY market is able to over take the pro on bringing in profits. Did not know that about opti stopping sales of 2.0 based on pressure. The market probably made sense back then to do that but right now it’s the opposite.
Now opti has more competition in the pro range IGL, Modesta, Gtechniq, C-pro Feynlab who have prob gobbled up potential customers.. if they were interested in making a great deal of money re introducing new version of opti 2.0. Would bring them up to date in the ceramic line where they are competitive again.
I learned coatings by using gloss coat but it cannot compete with CQUK better gloss, beading, longevity and price 30mls Vs gloss coat 1 year 10mls for $60. I might be wrong and people still buy and use gloss coat but they seemed to have lagged behind and are over do for a new coating.
DaveT435
DaveT435- Tks for your comments..
So, if the really great hobbyists wanted to go through the nosebleed of having products pushed on you (remember Amway?), and were able to get access to the newest, best, Pro, coating, what do you think they would charge their Clients ? A lot less than the Pros ?
I used a lot of OptiCoat 2.0 in the big syringe years ago, and it was a great product.. I never knew about people complaining enough to somehow cause a big company to change their own business plan marketing strategy to keep them happy, etc..
In any event, the huge amount of product out today is here to come and go, and more and more on the horizon! :)
Dan F
TroyScherer - Thanks for your reply.
I know, I was also there at the beginning of Opti-Guard.
This and their 2.0 were great products back then!
So easy to apply, never had issues, etc..
Yes, I certainly know and agree with you that the Prep work will always be the make it or break it for the coating lasting the longest, if that is part of the coating`s make up in the first place..
The absolute number of coatings out today is pretty amazing, with new ones coming out very often.
I cant remember if any of the new ones ever talk about how long they actually tested their products on actual vehicles anymore..
Dan F
William_Wallace
I was just making a point that there are several reasons behind their decision to make pro only products. Another one is they don’t want just anyone installing their top of the line products. We all know there are a lot of hacks out there. Consumers blame the product when there is a problem. On the Camaro forum I saw a hack job on Gtech Crystal Serum, apparently Gtech sent the customer back to the same installer to take care of the problem. The installer managed to make it worse the second time. The guy was on the forum dragging Crystal Serum through the mud. Hundreds or possibly thousands of people saw that. Some will be smart enough to know it was the installer not the product. Even so if people are calling around getting prices and someone mentions Crystal Serum that negative image is in their mind. Now this was actually a professional that screwed that one up. Can you imagine opening up sales of Crystal Serum to the general public? It wouldn’t be long before they were selling less than they do just selling to pros.
That leads to another point. Some of these pro products are a little more difficult to install.
FunctionalDoc
THE GUZ
It is possible they scratch easier. I don`t buy too much into coating hardness. I listed the hardness rating of SPS up above.
I can`t say if all of these brands come from the same place. It is possible they use the same blender.
William_Wallace
CarPro would be smart to be the first to come out with one. We will see who is next. I know Angelwax has one in their authorized installer line. Migliore Forte seems to be available to purchase and it is graphene. It has a pretty high price point at $250 for what looks to be a 30 ml bottle.
I’m beta testing one now...:ph34r:
Anyone have a contact to SPS? looking to dip my toes into my first certified coating
donbeezy
Contact them through facebook or on their actual web page (surfaceprotectivesolution).
Back on Topic.
@The Guz
Do you have any plans of a side-by-side panel comparing the Graphene coating to one of the popular long term Si02 coatings? On a test panel or even a full hood of a vehicle? I would love to see the differences compared directly.
A long time ago I remember reading a post where someone did a testing using color charged waxes on a white Panel. (Dodo I think) It showed that you could "tint" the color of a vehicle by using these waxes. So my question is will the same thing be true with the SPS Graphene since it is a dark color in the bottle?
TroyScherer
Back on Topic.
@The Guz
One of the characteristics of Graphene is that it dries clear.
Sizzle Chest mentioned something about a darkening on the first vehicle he did, it was a darker color though, if I remember correctly. Maybe he can elaborate.
You can put clear ceramic on some paint and it will have a darkening affect as well. The affect is more the paint than the product.
TroyScherer
Back on Topic.
@The Guz
It does not change the color of the paint. My silver car is still silver.
DaveT435
It was Ford paint, Sterling Grey. It did ‘darken’ the look of the surface, most of the coatings I’ve used have done the same, but it did not change the color whatsoever.
The car received it`s first wash last weekend. This coating is super hydrophobic and to quote waxmode oleophobic. Followed up with the spray detailer after blow drying the car.
The spray detailer like the actual coating has the graphene juice in it. Definitely shake up the bottle due to it settling within the bottle. There is nothing complicated about using this. It is a quick detailer after all that is easy on and easy off. The coating is already slick so the difference is negligible. The gloss under the coating is great and the difference is in gloss is minor at this point. I can say that the spray detailer does not have the same water behavior as the actual coating from testing it earlier in the year on a test panel.
Edit: Found the following information on the durablity of the SPS detailer. SPS claims up to 4 months of protection.
I will say that the slick feeling from this is great.
Low and behold it rained the next morning.
http://www.autogeekonline.net/galler.../IMG_6502a.jpg
Can be used on multiple surfaces and on any forms of protection.
http://www.autogeekonline.net/galler.../IMG_6503a.jpg
http://www.autogeekonline.net/galler...IMG_6505a1.jpg
http://www.autogeekonline.net/galler...IMG_6506a1.jpg
Enjoy the super hydrophobic properties after the first wash.
https://www.youtube.com/watch?v=aT35ClG3RrI&feature=youtu.be
righto boys... what are we thinking about the Graphene??? Longevity aside, do you love it?? Is it worth the 3x cost vs. CQUK3.0?? How is it with hard water spots??. as an observer, the slickness seems a big advantage over sio2.
The Guz
Ah - while that detailer looks nice my selfish motivation would have been to see how the coating performs on a standalone basis. Topping it blurs the lines somewhat - any coating will last pretty much indefinitely if topped and likewise all of the characteristics (gloss, water behaviour, slickness, self cleaning), at least for the next while will likely be imparted by your new LSP!
That said, I`d struggle to keep my hands off it either :)
bodidly22
For me it is still too early to claim it is going to take over. I will say the slick feeling of the coating is by far better than most quartz coatings tacky feel. As I mentioned think CSL/Exo but on another level. I can`t say about water spots as I have not had a quartz coating spot on me.
atbalfour
There is another test panel for that on my year long coating test. The rest of the paint will be maintained with the detailer to see how IGL F4, SPS Graphene and the SPS Spray Detailer all play together.
Quick update but unfortunately Graphene is not going to be the miracle product we all wanted it to be when it comes to water spotting.
Will post photos and video in a bit.
As promised. If we look at the included pamphlet that comes with SPS they clearly state decreases water spot prevention but at the same time water spot prevention.
http://www.autogeekonline.net/galler.../IMG_4240a.jpg
Unfortunately that is not the case. It appears that water spotting is still going to happen. My hood is peppered in water spots in various areas in various sizes. I was only able to see them under the garage lights. After I finished the video, I took some CarPro Sportless and Optimum MDR and neither of them did anything. Although they never really work that well.
I am one month in with SPS graphene on the paint and topped with the graphene dpray detailer after the first wash.
Examples of what I am referring to.
http://www.autogeekonline.net/galler.../IMG_6757a.jpg
http://www.autogeekonline.net/galler.../IMG_6759a.jpg
http://www.autogeekonline.net/galler.../IMG_6760a.jpg
Forensic detailing also posted a video on his channel with similar results on the art de shine graphene coating covered in water spots.
https://www.youtube.com/watch?v=1O0WdiwB2c0&feature=youtu.be
Thanks for the update Mike! I`ve always been a bit curious as to the water spot resistance claims of coatings from different chemists and manufacturers. Would like to know how they`re setting their testing up to observe this resistance, and baselining that against a control section. I don`t think I`ve ever seen any of the coatings that I`ve worked with provide a clear resistance advantage against spot etching.
Would like to know if you have any experience Artdeshine`s Metal Oxide Coating made with ATO (Antimony Tin Oxide). i was wondering since this metal based coating vs SIO2 thta it might not have a water spot issue. Would great if can undergo the torture car long term testing. thanks for your videos and methodical studies. Rick
FunctionalDoc
I have no experience with that coating. It is on the list of future coatings to try.
As most of you know very shortly into it I decided not to rep the SPS line. I still use the line and really like the products. Nothing is going to 100% resistant to water spotting, especially when you look at some of the sources of water that can get on the surface.
My water at 220 PPM has spotted it, I wasn’t doing a side by side test so I don’t know how much less spotting if any occurred. When I run my water through a portable water softener and can get it down to about 30 PPM. At 30 PPM I washed my car in high noon full Texas sun and the light spots that were left after air/sun drying wiped right off. 30 PPM I believe would be pretty similar to rain water and environmental deposits.
I have seen a side by side water spot test against a well known ceramic and there was more than a slight difference, I would say in the neighborhood of 70% difference. I will definitely pass this on to Brett and I’m sure tests will be done to support the claim with photo/video documentation or I’m pretty sure the claim will be removed. The statements about what will possibly happen are strictly my opinion based on knowing Brett.
Thank you for the honest input Mike, I appreciate and I’m sure a Brett will as well. I’m not on here much these days but if I get any feedback I’ll try to pass it along. Have any of you other guys had any issues with water spotting or anything else?
Adams is getting into the Graphene game.
Possibly a relabeled exhausting product?
I don’t think graphene is game time ready and it’s not ready to dethrone current ceramic coatings. These are just my current observations and opinion.
https://uploads.tapatalk-cdn.com/202...e02268c217.jpg
makes my decision of recently coating the wife`s new Mazda with CQUK 3.0 even more satisfying.
bodidly22
You made a great choice. CQUK 3.0 is a great coating in my experience.
Here is Adams. They are calling there’s Graphene ceramic coating.
They have a spray coating as well. Both using their UV technology for application.
https://uploads.tapatalk-cdn.com/202...650efcb953.jpg
Coating claims
https://uploads.tapatalk-cdn.com/202...abf84d2f28.jpg
Graphene is coming out of the woodwork fellas. We shall see if it lasts or if it’s the next flavor of the month.
