Re: LSP’ing wheels and tires
Question 5: once the wheels are LSP’d during my wash process should I use brake buster to clean, or will that render the wheel wax LSP worthless the first use?
Question 6: Of I were to use a product such as Beadmaker as a drying agent, can this be used on the wheels and tires during drying?
Your car doesn`t have a jack and a spare tire? I can`t see not taking the wheels off. If you haven`t opened the wheel wax, IMO, take it back and just use your favorite product. Wheel waxes are nothing more than marketing of a mediocore product.
Astouffer512- I really do think you oughta pull `em off, for a number of reasons, but I`ll spare you that lecture ;)
What Dan said about the "Wheel Wax". IMO if you`re not Coating them you oughta use something known to be durable like FK1000P.
Are the wheels BARE ALUMINUM? Very important Q as using stuff made for Bare Aluminum on anything else will cause serious damage (as in, can ruin them, requiring refinishing).
If the *are* bare aluminum (which is extremely rare), I`d sure want to use something *really* durable like the 22ple Coating for metal. Running bare aluminum wheels in the Winter would be a terrible idea anyhow IMO (BTDT, with regrettable results).
I`d do the wheels first, then the tires, planning on a little touchup of the wheels since you might get a bit of the Tire Coating on them (which shouldn`t be a big deal).
Unless you use a Coating, you should avoid subsequent use of aggressive cleaners, and if you do use a Coating you won`t need them anyhow. For that matter, you almost certainly won`t need anything more than a sorta-strong shampoo mix to clean them once they`re LSPed with anything.
If you use a conventional LSP, try to keep your Tire Cleaner off them as best you can.
I don`t know from Tire Coatings, but I wouldn`t expect them to need anything like the 303 as a Coating oughta replace such stuff (otherwise, why bother?).
Sure, use whatever Drying Aid you like on the wheels, it should provide a little extra sacrificial layer and maybe boost the looks a bit. Not that it oughta really be necessary.
Generally, what you`re trying to do here is treat the Wheels the same as the paint on the rest of the vehicle and avoid having to use special Wheel Cleaners/etc.
Quote:
Originally Posted by
Accumulator
Sometimes the lectures from the “old timers” are the best though. (Hopefully that innuendo doesn’t insult you. That being said I should buy a floor jack and jack stands regardless I suppose. I would also make it much easier to use the turtle wax ice spray wax on the wheel wells
Accumulator
I just realized it isn’t just wax. It is actually a wheel sealant. It’s the CG’s max coat wheel guard. Got it on amazon for like $10 and figured I’ve wasted $10 in worse ways
Accumulator
They aren’t bare aluminum they are OEM clear coated wheels, both the Equinox and our Fusion
Should I buy something more along the lines of Optimum metal polish then rather than using the Mother’s mag and aluminum polish?
Accumulator
Thank you
Accumulator
With the CG’s stuff being a sealant I will still try to just use my wash bucket, but perhaps if needed I can then step up to the brake buster if needed.
My normal tire cleaner is purple power degreaser. I’ll assume I should use it not so much as to not degrade the McKee’s coating?
Accumulator
I didn’t figure I’d need the 303, but I didn’t know if it would help prolong or not. I think using the Beadmaker would be a better route anyway as a drying aid. Never used a drying aid because I’ve been using my leaf blower to help push most the water off and then my drying towels to finish. When using a drying aid, should forced air still be used to push off most of the water? I missed this when I replied above about the brake buster by trying to not use harsher cleaning methods. Hopefully soap and water does the trick. For the tires is a tire brush still used on coated wheels or does that effect the coating?
On another note I do have that powerlock I seaes our fusion with. How does powerlock work for sealing rims?
Another vote to bag the Wheel Wax.
Take a look at Pinnacle Black Diamond Cleansing Polish and Diamond Wheel Coating, this combination is as idiot proof as it gets. For the same amount of effort you would put into an application of Wheel Wax, you’ll have a much more durable layer of protection.
And as others have suggested, find a way to do a “wheels off” detail, you won’t regret it.
Astouffer512
Sometimes the lectures from the “old timers” are the best though. (Hopefully that innuendo doesn’t insult you.)
Heh heh, not insulted at all! I`m working at being a Poster Child for Proper Aging and actually like being an old-timer :D I try to not be a [jerk] but sometimes come across that way anyhow :o
Quote:
That being said I should buy a floor jack and jack stands regardless I suppose. I would also make it much easier to use the turtle wax ice spray wax on the wheel wells..
While it`s easy for me to spend your money for you....yeah. Some stuff just *goes* with being a Car Guy (or Gal ;) ) and a floorjack/jack stands are in that category. Also some means of inflating tires, even if it`s just an Air Tank that you fill up now and then at the gas station.
I`ll spare you the lecture about how I need two floorjacks for every carwash I do :D But I couldn`t get by without them both (need two if only because of the Differentials I run). Anyhow..
If you don`t have a practical means of getting the car up/wheels off, just do the parts of the barrels you can access through the spokes. Better than nothing and as long as you don`t have problematic wheels (some Cadillac model was notorious for stuff building up in there enough to throw the wheels out of balance!) that oughta be fine until if/when you indulge your Inner Autopian by pulling `em off.
Quote:
..I just realized it isn’t just wax. It is actually a wheel sealant. It’s the CG’s max coat wheel guard. Got it on amazon for like $10 and figured I’ve wasted $10 in worse ways..
Noting that some Sealants I`ve used didn`t last as long as some Waxes..hey, you have it and you`re cool with the cost, so maybe it`ll surprise me when you post back about how great it works!
Hey, this ended up maybe being my Autopian Good Deed for the *year*! That would indeed have been a really, REALLY, big mistake.
And NO...do *NOT*use the Optimum Metal Polish either! Even if they look like "metal"/chrome/etc. they almost certainly (like...99.999% chance) have some kind of clear on them that you don`t want to compromise, and Metal Polishes of all kinds are extremely abrasive, way too much so for this.
Use a mild Polish..or, gulp...carefully try a compound if they`re really marred up, but do the "try the mildest approach first" so you`re not more aggressive than necessary. Refinishing wheels is pricey! Just think of the wheels as being regular, if hard, autopaint and settle for "better" rather than aiming for perfection.
Quote:
..I will still try to just use my wash bucket, but perhaps if needed I can then step up to the brake buster if needed.
Don`t use your Regular Wash Bucket unless you`re gonna dump it out/refill after doing the wheels..nasty stuff you don`t want to risk getting on your paint.
I use a spray bottle with a pretty strong (~7oz./gallon) shampoo mix on mine, which also works great for the wheelwells/undercarriage. And yeah..I have wash/rinse buckets dedicated to this application. (And a separate bucket for Tires too.)
I`d assume the same thing. I use Griot`s Rubber Cleaner (which is, if anything, too mild and very pricey) but that`s mostly out of habit and from having so much of it. But I don`t think you`ll need the PP and FWIW I don`t use Degreasers on wheels lest they perhaps mess with the rubber (valid concern? I dunno but I`ve only had one set of tires age badly and I`ve had countless sets of `em).
Quote:
I didn’t figure I’d need the 303, but I didn’t know if it would help prolong or not. I think using the Beadmaker would be a better route anyway as a drying aid...
I would expect the Tire Coating to do fine by itself, and if it didn`t I`d be, uhm...disappointed..to say the least.
I`ve never been all that impressed with 303, but that`s just me and I`m sure there`s nothing wrong with it (not that I ever use such products for anything except tires).
I`m a fanatical advocate of Drying Aids :D And I too blow off most of the water first (with my AirWand) and also last (with my compressor) as my vehicles retain a lot of water.
Then I spritz on the Drying Aid and wipe with my MF Drying Towel before doing that final go-around with the compressor`s blow gun.
I wouldn`t expect the brush to be a problem, but again, I just don`t know from Tire Coatings. FWIW, I use both brushes and a sorta-aggressive sponge on my tires.
That`s another one I`ve never tried, but since you already have it...sure, see how long it lasts. Hey, I did wheels with *Souveran* for years and that worked fine (just didn`t last long to say the least). The whole idea that you need "really high-temp LSP" on wheels is vastly overstated IMO, they just don`t get that hot (even during Track Days), I even use "regular LSPs" on brake calipers with OK results (on cars that`re driven hard enough to experience brake-fade).
SGM2008
...as others have suggested, find a way to do a “wheels off” detail, you won’t regret it.
Makes for a good time to assess what`s going on in the wheelwells too..not an area to neglect, especially if the vehicle is driven in the winter.
Well my neighbor and co-worker has a hydraulic jack and jack stands I can borrow this weekend. So I’ll get at it and do it right. Speaking of doing it right.....do you coat the backside of the tires as well?
In relation to polish, so no mother’s, not going to buy optimum....but I do have Meg’s ultimate polish I had bought on a whim a year or so back....maybe I’ll try polishing with that before putting some kind of protection. Who knows I might try the Jescar powerlock or I might try (please forgive my bad words here) CG’s Hydroslick. I know, many better products out there right, and a lot of guys complain how hard this stuff is to use. For whatever reason I have zero issues with this product. I’ve had it on the windows of the equinox for 2 months now and through rain and several washing’s and I still don’t have need for wipers unless it’s a drastic downpour. (Even used bug remover on it and cleaned it with the stuff at the gas station pumps a to good number of times between washes)
Astouffer512
Nah, but then I don`t coat tires period :D I do clean them just so they`re not awful to handle during the seasonal switches to/from Winter ones.
Watch that the socket you use fits the lugs nice and tight, especially if they`re exposed and plated/etc. You might try lining the socket with Saran Wrap or pieces of a nitrile/latex glove.
Quote:
...In relation to polish, so no mother’s, not going to buy optimum....but I do have Meg’s ultimate polish I had bought on a whim a year or so back....maybe I’ll try polishing with that before putting some kind of protection.
Just be sure to strip those Trade Secret Oils. If UP is still similar to M205 that might be a challenge (well, it always was for me). IPA didn`t remove them for me...the TSO won`t necessarily cause compatibility problems, but they might cause things to look worse once they dissipate.
Quote:
.. Who knows I might try the Jescar powerlock or I might try (please forgive my bad words here) CG’s Hydroslick. I know, many better products out there right, and a lot of guys complain how hard this stuff is to use. For whatever reason I have zero issues with this product...
Sure, if it works that well for you give it a try! Worst case is that it won`t last long, but even then IMO you`ll be ahead. IMO it`s all about whether something works OK *for YOU*, never mind how it works for others (myself included :D ).
But be careful using the Gas Station Window Stuff..who knows what`s really in there and I sure wouldn`t want the solution to get on my paint. (Heh heh, we have Window Cleaning Kits in all our vehicles so my wife and I always have our fave stuff handy.)
I have been doing two coats of Cquartz Lite
When I was new to this I remember wondering what LSP stands for. It is "Last Step Product," for anyone new to this lurking on this thread.
OP, just to add another voice to the conversation-- I also think wheel wax is not very effective. I like using Sonax Rim Shield instead because I can spray it onto a clean wheel and walk away. The protection lasts a couple months for me which is pretty good for not having to wax or ceramic coat my wheels. Applying wipe-on protection products to wheel barrels without dismounting them is tough.
Here is how I do wheels without removing them, fwiw:
1) Wear some nitrile gloves, this is going to be messy.
2) Pick your favorite wheel cleaner and follow the instructions on the bottle to soak the inner barrel (some cleaners want to be applied on a dry wheel, some following a rinse). Use a wheel barrel brush to agitate the barrel.
3) Use an old towel or a microfiber finger pocket to further scrub behind the wheel face as much as you can. The back of the wheel face is really difficult to clean without unmounting the wheels, depending on the wheel of course. This is the especially messy part and you likely won`t get it 100% clean. You can get the barrel pretty good, though, by really working the barrel brush.
4) Re-wet the wheel cleaner. Agitate the wheel face with a detailer`s brush. Don`t forget to spend lots of time on the corners, lug nuts, etc.
5) Rinse. Consider repeating. Then rinse your brushes.
6) Apply your iron remover as instructed on the bottle. Use your wheel barrel brush to work in the iron remover and spread it around the inner wheel. Sometimes I do this step twice if I`m getting a lot of purple goo. Rinse. Rinse any brushes you used.
7) Now do the tires as instructed by your tire cleaner. A stiff bristle brush is great for this. If you really want to be thorough, you can use a drill brush to scrub the rubber. Rinse and repeat until your tire cleaner no longer turns brown. I do the tires after the wheels but it probably doesn`t matter in which order you do this. Rinse your brush.
...now do the other wheels...
8) Dry all 4 wheels with a dryer or leaf blower and a towel
9) Apply your tire dressing as you see fit and clean up all overspray from the wheels.
10) My preference: apply Sonax Rim Shield which is a spray-on-walk-away LSP. Get the faces, barrel, lugs; all of it (according to the instructions). Let the wheels sit for a couple hours and you are done.
I think Sonax Rim Shield functions and lasts really well especially compared to the effort I spend applying it. A runner-up product is McKees 37 Wheel Coating which works the same way. My everyday wheel cleaner is currently Griot`s ($/gallon vs. performance is good), and my favorite tire cleaners are Adams Tire & Rubber and Tuf Shine.
Hope this helps. Believe it or not, it takes practice to be able to do this consistently well.
I ended up buying some McKee`s wheel coating....but I`m wondering if I should pick up the Adam`s wheel coating and then top it with the McKee`s?
Sent from my SM-T580 using Tapatalk
