Re: Air Filtration Syste.
Quote:
Originally Posted by
Detailrookie!
Hello all,
I plan on getting into coatings, but my garage is extremely dusty, new devel being built behind my house, and was looking into getting an air filtration system. I`ve been looking into the Wells and Jet brands, but not sure if there is something better to reduce dust and pollen. I vacuum the garage before I wash the car and hose it down, but I see dust on the paint shortly after I pull the car into the garage.
Does anyone use an air filtration system in their garage? If so, has it helped with the excess dust?
Thank you in advance!
Sent from my SM-N960U using Tapatalk
I’ve heard of an old wives tale that one can ground the car to the building or shop floor by attaching a grounding cable from a grounding point on the car or ground side of the battery to a grounding rod or strap in the building, all in the effort to mitigate dust falling onto the car.
TheMeanGreen
Interesting, I will try it. Thank you!
Detailrookie!- Welcome to Autopia!
Check out the Jet system that donbeezy has in his new shop: https://www.autopia.org/forums/show-...98-shop-2.html
