Re: IGL F4 on a black CTSV
That does it I`m ordering some Premier soon, beautiful work, if that still needs heavy correction work - wow. lol
Nice work with an AIO Justin. Seems like it’s a winner
So if I use this on a coating this will not affect to bad? Looking to add a layer of cancoat every 6-8 months. could I use this clean the paint without damaging my cquartz? Would it leave pant good for the cancoat
Quote:
Originally Posted by
Coatings=crack
So if you have CQ you should be able to use this with a black foam finishing pad on a 12mm or 8mm da. Low speed. Then you can try cancoat right after but IGL Premier is a more suitable topper for F4. And that works wonders when machine applied with a black foam finishing pad on a low speed.
