Re: Electrified pump foamer
In seeing people do things like this, or add schrader valves to their IK 9`s, the new arrival of the IK Foam Pro 12, I have set to thinking about how I can make an electric pump version of these foamers. The hardest part will be finding a pump that is small enough, but powerful enough to create the pressures needed to make the foam.
Mary !
I am so proud of you for using great innovation to make this ! Yes, it was on YouTube, etc., but you took that and made it so much better !
Your foamer really works great !!! Awesome job !!!
Thank you for the super nice pics and explanation !
Dan F
Wow!!! Once again always impressive, nicely done
As usual Mary, I’m impressed. I very much enjoyed reading this.
Always seen this.... wish someone would just produce it. Awesome better version of this Mary!
Quote:
Originally Posted by
TheMeanGreen
The one she used would work, well I don`t know how many times it could pressurize the Pro 12 on a single charge. But I`d imagine a decent number. Attach it to the side of the Pro 12 with some double sided sticky tape. I actually want to get the Pro 12 + the same pump OP used. I`m about to go look it up to see it`s specs. I gotta imagine it probably will take a long time to get the Pro 12 up to 58 PSI though.
OMG, you`re a mad scientist! Great work!
Awesome done Mary!
Have a look out of a great cordless electric air pump. What brand and modell is this air pump? I have an Epoca Foamer 1L and it`s awefull a lot of pumping. Have not found any good and not too expensive air pump here in Sweden yet. Had been great to have the tire cleaner and it`s the same I use to pretreat the bug squash if not the prewash was enough. Handy to have this little foamer to do this. Now I don`t use it but have an pump spray bottle instead. When foaming I can use it less concentrated and getting a longer dwell time.
Thanks for shareing your build of this and the testing! Looking like it works great.
/ Tony
Wow! Looks good Mary. Thank you for sharing.
SWETM
Awesome done Mary!
/ Tony
Here’s some info Tony,
An AMZ pickup. They have several to choose from.
MB.
https://uploads.tapatalk-cdn.com/201...9369793465.jpghttps://uploads.tapatalk-cdn.com/201...e71dbb665f.jpg
Sent from my iPad using Tapatalk
Someone that has already installed a schrader valve to their Ik9 needs to try using this to keep their Ik9 at pressure. I am not willing to sacrifice my Ik9 for something that may not work.
Setec Astronomy
Heh heh, + 1 from me too :D Nicely done!
Quote:
...Attach it to the side of the Pro 12 with some double sided sticky tape...
What about Industrial Strength Velcro?
quebert
From the readings, it seems like one of these small tire inflators could actually do a decent job at inflating the IK Foam Pro 12, I would assume at least twice. The biggest benefit to the 12 over the 9 is the size of the tank, if I have one gallon of solution in both foamers, I can fill the 12 with more air than the 9, thus getting a longer spray time in between pumping intervals. The question is, who wants to spend the money on the IKFP12 and blow more money on one of these inflators, all within a short time period, to satisfy the curious. I personally would like the IKFP12 for the longer spray time, as I suggested^, but as I am a currently a broke college student, again, I do not see me purchasing the 12 until next summer.
