Lewis,
You are welcome !
I also have that Flex PE-14-2 150 Rotary in my cabinet as back up for my Makita.. I have never had to use it as back up.. But I have tried it out a few times on hard, German, paintwork, and it works ok..
It makes a lot of gear noise, and it is way lighter than my Makita..
I still prefer the heavier Makita because I like to apply so much downward pressure to the work, depending on how much pressure is needed..
The 10-lb Makita makes downward pressure easier for me..
I like to keep all speeds down from the nice 600rpm soft start to hardly ever over 1,000rpm..
I can achieve all I need at those speeds, and I NEVER have to clean up product sling all over the panel and especially in those edges... :)
NEVER allow the product/pad/paint to get DRY, and you will have longer work time that will achieve more, quicker, and again, no product dust everywhere, to clean up later..
I have only used Lake Country Backing Plates, all the way down to 1-inch size, and a steel spacer bolted directly to the spindle of the Rotary..
https://www.autopia-carcare.com/back...e-country.html
The Spacer gives me exactly 1-1/4" additional space + the Backing Plate, then the pad, so I have enough room for almost every kind of spot where a big machine cannot possibly fit, but the pad will fit just fine.. You just have to ALWAYS MIND where that spinning spacer is between things, under things, etc., and NEVER let it hit them, ok ?
Get it ?
The Spacer will make the pad a little more hard to manage, until you get used to it and then naturally compensate for that little physics result. I never take the spacer off and have had it on for decades.. Of course, the
longer the spacer, the more difficult it will be to learn how to manage..
I have tried all the pads from as far back as 50+ years ago.. Actually longer, but I refuse to keep counting backwards.. :)
The best Pads I have used are from Lake Country, but there are other makers out there now that I have hear have good pads also..
The Lake Country Purple Foam Wool Pads have proven themselves on dozens of vehicles that needed severe correction, and even a couple of Airplanes, who qualify for having the best, worst, paint, to ever have to clean up.. And this is using Meguiars 105 and 205 with foam afterwards..
https://www.autopia-carcare.com/foam...ads-thick.html
I also have had great success with the
Lake Country Hydro-Tech Pads, but I believe they may have stopped making them or something.. If this is true, too bad because they have/had a couple of pads that could easily correct most anything and polish the surface down to about LSP ready condition..
Yes, it will take a few passes to clean up some blasted paintwork, but I have never had to change my process..
Correct with downward pressure however many passes (within reason), then allow it to polish down and most of the time, I get a really great, clear, glossy, smooth, finish, with even the Cyan pad..
Here is a link to the pads I mention --
https://www.autopia-carcare.com/hydr...e-country.html
The big secret to using a Rotary and achieving perfect, flat, glossy, clear, finishes is keeping the machine AND downward pressure perfectly FLAT, through the entire pass stroke, on ALL the passes. And EACH pass has to be smooth, and not stop-and-go, smooth, same speed, all the way to the end..
Imagine you are using a paint gun painting that panel; each stroke has to be perfectly straight, smooth, and the same speed, all the way to the end..
And at the same time keeping the balance between speed (machine and arm) and downward pressure
Perfect, and not allow very much heat under there..
I had the advantage to work through the years required in apprenticeships to Journeyman Painter, so a lot of time with some Excellent Painters really helped me to learn best, proven, processes from the Best..
We never made holograms, etc., in paint because that was just not acceptable..
You, as has already been said, will need the BEST Lighting possible on all this work from start to finish, to help you see what needs to be further done, or undone if that happens..
Glad to read you have a lot of time in the Shop ! This tells me alot about your work ethic and desire to DETAIL !!!
Dan F
