2 Attachment(s)
Help with weird stains/marks (w/pics)
There are two stain marks that appear to be beneath the clear coat as the surface is smooth. They are located on the lower driver`s door where road grime and dirt kick up. I`ve tried some basic scratch remover and clay bar but they made zero difference. They look like they could be rust, but I don`t know if that`s it. No other marks around the car like this. Any idea what I could do or use to remove it?
Re: Help with weird stain/mark
Hank3 --
Did you try a tar remover, mineral spirits, etc., on a Q-tip on those spots ??
Dan F
First, use at least a 30X lighted magnifier to know what for real you are dealing with.
Quote:
Originally Posted by
Stokdgs
Hank3 --
Dan F
I have not. But I appreciate the suggestion. I know I don`t have that remover, but I think I have a little bit of mineral spirits left.
EDIT* Turns out I don`t have mineral spirits. But I did have denatured alcohol left. It didn`t do anything.
Ron Ketcham
That, although I prefer a 15X.
I don`t have any magnifiers on hand.
Someone mentioned trying Iron-X. I have a small bottle on order to see if that does the trick. Will report back.
UPDATE: Iron-X didn`t do anything.
Hank3
Did you get any color changing from the IronX?
If not it`s not a rust problem you are haveing. Has it been this way since you bought the car or has it happened when you have owned it? It seems almost like a repair where they have used some kind of clearcoat to cover it. Or it`s a damage in the paint that`s not through to the metall if you didn`t get any bleeding effect from the IronX.
It`s so hard to say what it is just by looking at the pictures. Where on the car is this damage?
I`ve seen similar, although not quite as dark, stains in clear coat from (non-water based) tire dressings that sling up onto the car. Those were on a white car, too.
