Do you use an IPA between compounds/polishes ?
When you use a compound or polish do you use an IPA wipe down after the compound/polish ? Say example you use a M105 then a M205 do you wipe down with IPA after the M105 and or M205 ? thank you very much for any help/comments. I am thinking yes to remove the compound/polish just used to create a fresh surface for the new compound/polish or LSP. Just want to make sure I am not waisting my time.
Re: Do you use an IPA between compounds/polishes ?
IPA can be good for inspecting between polishing steps but I’m not sure it removes all polishing oils. To make sure they are gone I use a product designed especially for oil removal. I hope I’m removing all of them by using it
I dont wipe down the panels with a product designed for that Final Inspection, until I am finished with all the correction, polishing, work..
Dan F
Quote:
Originally Posted by
Bill D
Same here. I found IPA (various dilutions) utterly ineffective for removing Meguiar`s Trade Secret Oils (TSO). I`ve found that stripping those is worth doing, ditto for the stuff Menzerna (under any label) leaves behind, as the filling from some of their "106" family can really do some concealing.
When buffing off the M105 residue, I use a little Meguiar`s M34 Final Inspection as I find it provides a little (very little..) buffering to minimize micromarring from the nondiminishing abrasives, which just keep right on cutting whether worked by the polisher`s pad or my buffing MF. But that doesn`t strip the TSO.
FWIW, other than the Meguiar`s compounds/polishes (and Menzerna stuff, though I no longer use it), I might/not bother stripping the paint before LSPing. IME it`s not always necessary with every product. No, not stripping...even those oils that I now always do strip...has not diminished the durability of my LSPs the way I would`ve expected given the conventional wisdom on the topic. I`ve had oils dissipate, revealing terrible issues, while the overlying LSP stayed 100% fine, but I`ve *never* had a LSP die prematurely because of underlying stuff left by the correction...another of those who`d`ve thunk it? things.
Accumulator, do you still use TOL Prep Wash/ Klean to strip polishing oils? This is the only product of that nature that I have
Bill D
Yeah, and that`s the only one I have also. I`m not wedded to that particular product, but I probably have a lifetime supply.
Heh heh, well...as little as you and I polish.. ;)
:) that goes for my parents’ vehicles as well. I just give them an extreme wash via foam gun and I haven’t had to polish them either.
Accumulator
So it was you who took all the Prep Wash Klean.........:ph34r:
I had to order some more this week or next.
It’s an “oldie but goodie” product that’s not talked about much any more. I have to be careful with it though because it stained my painted driveway. Luckily, after a while,the staining did go away.
Hey guys where can I learn about this "Prep Wash Klean" ? I did a search and kept getting some Oral treatment. lol. thnx for any help.
It’s sold on topoftheline.com. Gotta search for it under Hi Temp products there
It’s described as a silicone and wax remover
