Re: Tacky plastic coating?
BMW does the same thing. Try 91 percent alcohol to remove it.
Quote:
Originally Posted by
Mike lambert
Some interior bits of the A8 are like that too.
What Mike said.
I`ve also used GG Rubber Prep when some real cleaning power was needed, but I was awfully careful/gentle about it lest I find the (presumably limited) extent of the pigment on such surfaces. I just maintain with Cockpit Premium on a low-lint MF, which works OK as long as I`ve diminished the tackiness enough.
3D Total is an excellent and mild cleaner. I`ve used it on my leather steering wheel to remove grease left there by a careless mechanic. Took it right off, left no residue or tackiness. No damage to the leather.
I don`t think it`s still in production and I don`t know what 3D replaced it with,(or even if they did).
What causes the tackiness? I’ve seen it in several cars. Is it just deterioration?
Mike lambert
Just to clarify - does the alcohol just remove the tacky feeling, or the soft touch finish itself?
I would be very carefull to paint that part of the steering wheel. And would contact a verified mechanic that is working with air-bags. The texture in the plastic is meant to be perforerated so the air-bag can get through it if activated. So it could be that you need to change the whole center console in the steering wheel with the air-bag unit in it. It`s also important to not saturate the parts where you have air-bags units and other protections that is activated in a collision. There are alot of them in newer cars all around the doors and the seats and other places. It`s just to be safe that I would seek up a mechanic and see what they say is needed. There is alot of power when a air-bag is activated and there is explosives that is engage it. You never know when you need them to work properly. But it`s safest to look it up. Clean it up as good as you can with damp mf towel and a mild APC or interior cleaner. But don`t peel anything off is what I would do. And look it up and take it from there.
/Tony
Oneheadlite
Explicit Statement: I am not trying to speak for Mike or to horn in on something directed towards him and I look forward to what *he* has to say in response to that Q.
That said, IME it does remove a little bit of the Soft Touch Finish and you need to be a bit careful to know when to say "when". It`s like using IPA to clean other rubber(ized) stuff, you`re trying to remove the compromised (often oxidized) material to get down to "good" material. The "tacky feeling" is the material once it`s deteriorated.
Or at least that`s how it seems to me with the Audis. I vaguely recall doing the same stuff on the M3s but they never needed it in a big way and it never made a big impression on me back then.
Alcohol removed in the spot I tried but took a long time. It smeared around for a while before it finally lifted. I will not try goof off as I am afraid it is too harsh, but I want to try Goo Gone. I know brake fluid will work also but It may be too messy.
I find it hard to believe that somebody doesn`t make a soft-feel, soft touch paint in a rattle can or something. I can only find services that will do it for you, or buy, mix and spray your own for hundreds of dollars...
Yes happens to the radio and climate knobs in German cars too.
rlmccarty2000
It`s a sprayed on ~rubberish~ coating. It`s usually on the bits and or the interior console, inside the cupholder. It just breaks down over time...
Once it does, most just remove said piece, remove said coating, and just plasti-dip it to refresh the piece
Plasti-dip....alright, I was thinking something along the lines of Dupli Color removable wrap, which is a similar product, but was afraid it might fill in the small grain details, and maybe peel or "roll" off in time, but Its worth a shot. Thanks!
Some people wrap it as well - really depends on the piece.
Hell, I`ve had this occur on year 2 of ownership on some cars. The dealer replacement // co-incidentally , did not have said coating on it. It really is a mixed bag.
Personally, I see for some items they use this coating to give it a bit more tactile feel....
But`s it pretty concensual this stuff does break down, looks like crap, and in some areas like a center console, breaking it down to replace with new or refurbish is such a PITA
Corvettes have the same issue. Goof Off and time will fix it
Are you guys stripping it off, down to the underlying plastic?
Some other soft-touch areas have worn away on the A8 and V8, we just ignore it and consider it patina.
