Re: New Member from Virginia
Welcome to the Forum Patrick !
A lot of us on here are Vets also, so you are in good company again..
I calculate around 271 lbs of water if your tank is filled to 32.5 gallons (half full 65-gallon tank = 32.5-gallons, water weight = 8.34 lbs per gallon)
That doesn`t seem like a lot of weight if it is distributed properly in the vehicle, i.e, not all over 1 wheel, etc...
I imagine, you will want to distribute all heavy things across the vehicle side to side and front to back so its more in balance and then easier to steer and less stress on one side or the other...
Find out the maximum weight that vehicle can carry and you can then add up the heavy things and see how it comes out..
I know nothing about Ford Transit Connect vehicles but I imagine you are doing your research on their reliability, engine reliability, etc.. Perhaps there are some Forums for Ford Transit Connect Owners??
We are all happy to help !
Dan F
Welcome to the forum Patrick!
/Tony
Welcome. These folks on here can answer any question you have about detailing. There’s a lot of people in your area, your business should do good.
Welcome to the forum. The payload of those vans are over 1000lbs so that water tank even full is much less than the maximum. Just make sure u distribute and center the weight and you shouldn`t have any problems.
Sent from my SAMSUNG-SM-G930A using Tapatalk
