Boss foam system review using foaming sprayer
We’ve been using the products for a few days now. Since the cannon is unavailable and a lot of my clients don’t have a pressure washer, we decided to see how well the system works with the foaming sprayer. I must say I’m pretty impressed! We used it on both well maintained cars and as you will see, my wife’s car which has not been washed for a month and 2 trips to West Virginia. The only problem with this method is mixing according to directions, you have a significant amount of product left in the reservoir. So my advice is get a couple of plastic bottles to keep the solution in. As you would guess it’s not shaving cream foam but it works very well and gives good coverage. On the wife’s car it removed about 80 percent of the dirt without agitation. I followed that with a quick regular wash with Griot’s concentrated wash. After rinsing foamed using poly gloss, over Modesta BC08 without issues. I can tell you the water started running off the surface while the foam wash sitting! I honestly think for a car washed on a regular basis you probably won’t have to touch it. After a final rinse, car was blown off and just needed to blot it dry in a few areas. In my opinion the system is well worth the cost, and does everything it says it will! Can’t wait to see what it does with the cannon! Thank you for looking!https://uploads.tapatalk-cdn.com/201...88429f17b9.jpghttps://uploads.tapatalk-cdn.com/201...6b183e2553.jpghttps://uploads.tapatalk-cdn.com/201...71c105cb38.jpghttps://uploads.tapatalk-cdn.com/201...d35073ca27.jpghttps://uploads.tapatalk-cdn.com/201...1c28d327ef.jpghttps://uploads.tapatalk-cdn.com/201...e87159e289.jpghttps://uploads.tapatalk-cdn.com/201...5c16714da7.jpghttps://uploads.tapatalk-cdn.com/201...13fc49a381.jpghttps://uploads.tapatalk-cdn.com/201...84a81435d5.jpg
Re: Boss foam system review using foaming sprayer
Mike - Thanks for sharing your initial thoughts! Thanks for including pictures of it in action too.
Super excited for my kit to show up. Looking forward to seeing how it changes maintenance washes, and I think it’ll be a good motivator to finally work through getting both cars where I want them.
Thanks Mike. Excellent review and pics.
I`m still waiting on my cannon. I have the rest of the products.
I`m chomping at the bit now.
