Does a mild, inexpensive, clingy wheel cleaner exist?
Right now my go-to wheel cleaner is the regular, green, Griots wheel cleaner. It isn`t overly strong and it cuts through the grime and break dust on all my vehicles, even when they are at their worst. I also really like the price and buy it by the gallon to make sure I never run out.
The only thing I don`t like about it is how quickly it runs off the surface I`m trying to clean. It`s a thin liquid, and I`ve found the cleaner has run off the face of the wheels before I`ve finished the barrels. On my car this is really true as the OZ wheels have quite a few spokes to work around. I`d love something thicker or gel-like that would cling to the surface better.
Looking around I didn`t find any wheel cleaners in the same price range which were thicker/gel like in nature and many of those I did see were a stronger/heavy duty version. If I want a wheel cleaner which clings am simply going to pay more and step up to something like the McKees 37 or new Poorboys wheel cleaner? Have I overlooked a brand/product somewhere?
Re: Does a mild, inexpensive, clingy wheel cleaner exist?
What about a foaming sprayer on the Griots? No first hand experience, just throwing it out there.
It`s not always about the initial price, but the price per use , how effective and will it satisfy you
The foaming sprayer definitely could be a solution. As far as a different wheel cleaner I use McKee`s and it`s worked extremely well. It`s a thicker liquid so it does stay in place. Removes brake dust and has removed a few stains that none of the others would. As far as mild it`s not going to damage anything, you do want to make sure it doesn`t dry of the surface.
2nd on the Mckees. It`s been my go to wheel cleaner for a while now. I buy it by the case
Griots HD wheel cleaner is mild IMO. It is thicker and tends to stay put.
Ever since I started waxing my wheels with 476s, I haven’t needed wheel cleaner. I just use a microfiber mitt with my regular wash solution,even using my rinseless when I’m doing that type of wash. I just wet them down first.
I used to use the Griot’s up until then.
Same here. Since I started Coating/Hydro2ing my wheels good old soap and water cleans them up easily. Before that I used Poorboys wheel cleaner or Sonax. I haven’t used it but I think P21 has a gel wheel cleaner.
If you want cheap and mild dilute an APC, although this doesn`t solve your runoff problem. Maybe spray the face again after you`ve scrubbed the barrels? Most diluted are cheap enough you don`t have to worry about being stingy. If that`s not good enough try the new poorboys, I like their stuff and want to see a review :)
Love OZ wheels
Look at the Nanoskin non-acid wheel cleaner. It works out to be less than $5/gallon. Good product, works well on cared-for wheels. I`ve gone thru a couple gallons - have been completely pleased.
CG Diablo is a mild wheel cleaner that clings well. It never lived up to the hype of a heavy duty wheel cleaner like nearly all things CG, so it sat 80% full on my shelf for years. Then when I started coated my own cars` wheels and didn`t need to keep using the strong cleaners. So I started using the Diablo again for maintenance washings. Normally the car shampoo I`ve chosen to wash the cars is enough, but every now and then I will use the Diablo for a deeper clean without worrying about it degrading the coatings on the wheels. I`ve got half a gallon of the CG Citrus Sticky Gel sitting too. The last spray bottle I made up I put a little of the Sticky Gel in it also.
I will hardly ever throw something out. I`ll find a use for it someplace.
Thanks everyone for the responses!
Quote:
Originally Posted by
jatleson
I hadn`t thought about going this route. I might give it a try.
Poorboy
So very true. This has been happening to me a lot these days. Typically I`ll got cheap on something and be dissapointed. Once I try something better and slightly more costly I`m much happier...which leads to knowing ridicule from my wife because I didn`t go the better route the first time.
That alone makes me think I need to give your new acid-free wheel product a try.
ShaneB
Good to know. When vendors start tossing around terms like "heavy duty", it makes me cautious, espicially when they already have a "milder" product in their line.
rlmccarty2000
My wheels are coated with CQuartz, but the other wheels in the family fleet are not and require a dedicated wheel cleaner to properly clean them. Even on my coated wheels, I`ve found a light spritzing of the wheel cleaner seems to cut through even a light dusting of German brake dust better than just wash soap.
DBAILEY
I came across Diablo while doing some research, but was a little leary of using CG products. I found people diluting it down to 1:3 or 1:4. Do you dilute, or are you going full strength right out of the bottle?
Since I am not trying to use it as a heavy duty cleaner I have been diluting it to about 1:6, but I did add about an oz. of the Sticky Gel last time. Creates a ton of foam.
Older
I could`ve posted that :D Although I use different LSPs that last longer. Even though some of my vehicles are considered problematic with regard to brake dust, the same dilution I use in the Foamguns (~7 oz. shampoo : ~121 oz. water = gallon of concentrate) cleans effectively while not stripping my LSP.
But of course that means getting all Autopian about all those family cars` wheels! Understand completely if that`s not feasible.
@ Accumulator, you use 7 oz soap to 121oz water in your foam gun.
That`s the mix you put in the bottle?
If you don`t mind me asking, what soap are you using.
A few weeks ago I used Turtle Wax soap and got no foaming. Just trying to use it up since it`s on the shelf.
I`m gonna try PB SS&S tomorrow if its not too hot. I do like foam though even though it`s probably not needed
I bought a gas power washer again. 3100psi max
Much better than the 1600psi electric I bought when my gas one died.
