Re: Ceramics which one etc
Check out this write up and see if it helps from one our fellow Auopian`s
https://www.autopia.org/forums/car-d...ngs-final.html
Optimumn Gloss Coat. Very forgiving when applying. Two years longivity.
Polish angel, stupid easy and looks great! Kamakaze if you can get it is also easy, when it`s in stock?
Thanks for the info
When I called a utopia they said either c quartz or the evo something or other. Like everything else everyone has there flavor I guess. I just don’t want something that needs a gorilla to wipe off that is my main thing
Quote:
Originally Posted by
Us1champ
Thanks for the info
you cant get easier than polish angel cosmic v2 for applying and removing a coating... due to its unique formulation it 1)applies and removes like a sealant 2)doesn`t crystlalize on your towels either and 3) looks better than any coating I`ve applied (exo,csl,pbl, fenylab, gloss shop, cquartz and pearl nano)
not really that cheap tho..especially if you consider you can do Multiple vehicles with one kit and all the other kits are pretty much sold as single use
McKee`s 37 gets good reviews and it is the value leader. Very easy to apply. You get a generous amount, enough to do four cars for under $40 if you find a coupon.
McKee`s would be the most cost efficient choice indeed
The PA Viking doesn`t require any special prep. Can use any polish. That brings the cost down.
any better or worse?
So got the car done. Looks great with the polish angel but I keep thinking. Is this stuff gonna hold up? It is more like a sealant in application that a thicker ceramic coating. Did I waste 175 bucks on this for a 30 day shine ?
Didja use Cosmic?
Quote:
POLISHANGEL GLASSCOAT COSMIC V2 COATING
This German patent coating system contains silica (SiO) and titania (TiO2). Compared with the original COSMIC, COSMIC V2 contains 5% more silica and 10% more titania. No paint sealant on the market has such a layer which is resistant to harsh environmental influences. GLASSCOAT [emoji769] COSMIC V2 provides unbelievable surface clarity and color transparency. Its creamy texture is easy on and easy off and has a long lasting life of 18-24 months.`GLASSCOAT[emoji769] COSMIC V2 is the ultimate protection for your jewel finish.
Durability : 18 - 24 Months
Pencil Hardness : 9H
(Note: Pencil Hardness is not the same as Mohs Hardness Scale)
Yes
Can you post some photos?
