FK1000p Beginner questions
The product description says this has UV protection, considering how thin asian factory clear coats are along with giving the top
a cut & polish with D/A. Would the FK1000p UV protection help much? Or is it just an exaggeration? Some reviews say this stuff is like an extra clear coat.
After reading a couple of online reviews, I`m trying to decide whether one coat is all thats needed or if 2-3 is really better?
More coats sound like longer lasting protecive film, but not really sure if this is true.
And is letting the haze sit on the paint over night then buffing off of any real benefit vs just buffing off shortly after it hazes over?
thanks
Re: FK1000p Beginner questions
One is good, three is surely better
Sent from my SM-G955U using Tapatalk
Accumulator should be along in 3... 2... 1...
It`s pretty awesome stuff, short of a coating. Self cleaning, durability, and protection against bug and bird etching are its strong suits.
Accumulator should post shortly, but here`s my short take:
make sure your paint surface is prepped (clayed and polished as needed). I apply one coat (THIN is key with FK). Wait for it to haze where you get a clean finger swipe, but I wouldn`t leave it on there overnight. ~15 minutes should be plenty depending on temp and humidity (don`t do this in sunlight).
The second coat coat is worth it, and does add more durability in my experience. FK needs some cure time (24 hours), so you can wait a day, then put the second coat on the next day if you would like. What I do is just wait a week until my next wash and then do the 2nd coat at that time.
Hope this helps.
Quote:
Originally Posted by
Boden
You guys also forget that I push this stuff as well, short of a coating, there is nothing like it. UV protection, pretty chemical resistant, long lasting, inexpensive, bird bomb resistant, easy to clean, mineral deposit resistant.
OP, multiple coats at a time aren`t really needed. Apply one coat after decon or polish, drive the car for a week and put another coat on, if you want. There is not much sense in waiting short times between multiple coats. You *can* leave FK1000P on the paint over night, but make sure that you have a lot of MF`s on hand, because you will need them all to buff the finish to a *psuedo-hologram* free shine.
TheMeanGreen
I agree, I`ve used FK BWM101 on my boat for years.
Manix- Numerous comparisons always yielded the same results for me: More layers are definitely better for both durability and etching resistance and it wasn`t a subtle diff by a long shot. Just don`t layer it *too soon* lest your risk (just a risk, but it`s a biggie) pseudo-holograms from Solvent Action.
Or at least refresh the single application long before it really dies.
Note that waxes used for Mold Release applications pretty much *have to* layer.
The nice thing is that FK1000P is OK with fewer layers than something like KSG.
(IF anybody has had differing experiences regarding the benefit/not of multiple applications of FK1000P I`d like to hear about `em, especially the testing protocol. NO, no...not challenging/arguing/etc. just very curious. YMMV always applies with this stuff IMO.)
Thanks all.
I will just add a couple of coats, one per week after a wash.
I wonder how 1000p would work over essence. This could be a killer combo.
Post Pics!!
Manix
Thanks all.
I *think* Brandt (512 Detail) did this a while back... might be mistaken on the person but I know there`s a thread around here somewhere. Good results from what I remember.
OneQuickGT1
Looking at all those "Accumulator oughta...." posts makes me :o a bit, but I don`t mind fanboying something that works so well for me.
IME FK1000P is, perhaps surprisingly, quite compatible with all sorts of underlying products.
I`d take it more as a compliment and testament to you being the resident authority (or at least the most vocal :)) on FK1000p
I am by no means an expert on this stuff but I have used it over the last 4 to 5 years on my Camaro(actually I haven`t used it in the last year). I thought I read when I first used it that waiting more than a few hours between coats was all that was needed. When I used it I have done mainly 2 coats a day apart, too much work to get 2 coats on and off in one day. I did try 3 coats one year but think the that coat was a waste of time as it didn`t seem to improve anything. My thoughts on 2 coats is for coverage purposes, to make sure the entire car has been covered and no spots were missed which is highly doubtful when I finished the first coat but peace of mind. I have always had a rough time time getting it off but found that I likely been putting it on too thick and waiting too long before removing. Just my thoughts.
Accumulator
I`ve often wondered how it would work on top of PB black hole or white diamond.
06vrss- IIRC, people have said it works fine, at least over Black Hole.
skibik- No added durability from the third coat in your experience? Not arguing, just curious.
Yeah, the Official Line is that you can layer it promptly and Ketch always said I was doing it wrong if I had any issues with that. But some of his suggestions Re tweaking my technique weren`t gonna happen so I just wait.
And yeah#2, I strongly suspect you`re putting it on too thick if buffing off isn`t really REALLY easy. OK, not Souveran-easy, but it shouldn`t even get your attention. FWIW, I always fog the surface with my breath while buffing it off...do that with pretty much every LSP I use and IMO it makes things even easier.
nickclark08- Heh heh...yeah, "vocal" rather than "authoritative" ;)
And as I try to emphasize, I DID NOT expect to be impressed with the stuff; my sample tin sat unused for years before I finally tried it, and by then it was awfully hard/dried-out (talk about a PIA LSP to use), so for it to make such a positive impression on me is a genuine testament to how great the stuff is. I mean, sheesh...between 476S and KSG I was all set on my daily-driver LSPs, or so I thought.
Accumulator, as for the 3rd coat I had seen no extended durability. It was my winter LSP for the Camaro(drive it year `round) put it on in September and it would last I guess about 4 to 5 months. I can`t say is there was much protection left at 5 months even though it seemed to bead was likely just the clear coat. To help it along when I would run it through the touch-less car wash I would add the wax cycle after a few months in to the winter whether it helped or not I don`t know. If memory serves correct I did the 3rd coat try the second winter I had the car so I only had 1 winter before that to compare it to and 1 winter after. I never used it last winter as I kind of missed my warm days(weekend) in the fall to apply it and after the previous uses of being so hard to work with I gave up on it. I even apply it a few times with my GG 6" with success but still I know I was applying it to thick. To use the machine I used a piece of plastic carved from an ice cream pail(I had no plastic knifes handy) and would scrape a ribbon from the can and smear it on a wax pad and go to town. I know now that I applied to often to the pad, that and if you wait too long it ends up like the old days as a kid trying to remove the old Turtle Wax Hard Shell paste.
Last summer I began using up some of the BFCS that I acquired and since I missed my opportunity with the FK this last fall I applied a couple coats of the BF but it didn`t make it two months into the winter.
skibik- Thanks for taking the time/effort to explain it so well! I`m struck by:
-how it just doesn`t last for you the way it does for me
-that the third coat didn`t add a few extra months
-that it`s that tough to transfer from the tin to the pad
-that it`s so hard to buff off
Wonder whether the touchless factors in big-time and/or whether applying a thickish coat by machine makes for more solvent-action. I`m just *SOOO* extreme about the "thin application, applied very gently" thing that it might make *me* the wildcard here.
I even added a *fourth* coat of it to some wheels and the `93 Audi last time, and I sure don`t do this stuff unless there`s a big payoff :D
That comparison to TW..in my case it was the orig. Simonize...makes me think that *something`s* haywire though...I`ll apply to a whole large vehicle, let it sit for a few hours if something comes up, and it buffs right off just *that* easily.
Well...more proof of how !YMMV! always applies, huh?!?
I thought getting the amount of time out of the protection to me for the area I live in was quite impressive. I still had a little bit of beading left in February or March but nothing like it was when freshly applied. The paint surely didn`t feel as smooth or slick either so I just took it to be about the end of the protection. I also attribute this to the fact I live in northern Minnesota where every time it snows we lay down salt. My car usually turns white and it is on it for up to a few weeks so that in itself I would guess takes a toll on longevity.
I did figure out the last time I used it that of course I was putting it on a little thick but I was also waiting too long before removing it. I wasn`t getting it the point it was flashing off or just after it hazed over. I woulf wait until it was completely hazed and that I think is why it was a bear to get off.
I had the same problem with Wolfgang Fuzion. I applied it I don`t think i read the instructions completely. I did apply thin but instead of doing a panel at a time I did like half the car. Maybe my idea of thin maybe wasn`t thin but that stuff is not friendly at all when left on for too long either.
skibik- Yeah, your winters are similar to ours, and my vehicles regularly get so nasty that you genuinely can`t tell what color they are. Takes well over an hour to clean the salt off the undercarriage...
I dunno about FK1000P (or any other LSP I`ve ever used) being tough to buff off because it sat so long. If I can let it go for hours with no problem..and I do mean *hours*...then I dunno why just the time it takes to do the rest of the vehicle would be a problem.
Maybe it *does* all relate to "how thin is thin?" Even on dark colors, you sure can`t readily see my applications before I buff them off, I never apply LSPs of any kind so thick that they`re obviously visible in the sense of "look at the dried wax on that hood". The average layman would ask "what wax? where?.."
I even let Souveran sit until I`ve done the whole vehicle most of the time, get a bit more durability that way.
EDIT: Eh, the above sorta sounds like a lecture, and I don`t mean it that way. Sounds like you`re still getting good results with it, and making the application a huge PIA could be a lousy trade-off for a little better durability, huh?
Doesn`t sound like a lecture at all. I think my problem all stems from laying anything I use on way too thick, two to three times more than i should. I grew up in the 70`s helping Dad wax his car with that Turtle Wax paste. We put that on and remember when it dried the car was white. If you have ever laid on a heavy layer of that stuff on the whole car, and let it dry before wiping you know what I am talking about on something being tough to remove. The FK for me wasn`t quite that bad to remove but kind of reminds me of those days of Turtle Wax.
It is hard to get away from my thoughts of "if a little is good a lot is better" kind of mentality. It doesn`t help having enough to do my car 30 times over and would rather use it than throw it out. Example of usage, the can of FK1000p, if memory serves correct, is close to half gone. By memory I used it in the fall for winter protection 3 times I believe and I think for 2 of the spring waxes, all of which were 2 coats and at least one of those was a 3 coat application. If I out it on like I should I think as many times as I used it I should have used half of what I have.
I will say though it is a good wax I just need to learn how to use it.
skibik- Glad I didn`t come across like a pedantic [jerk].
I do indeed remember the waxes/etc. from the `60s/etc. :D Other than Meguiar`s #7/etc. I learned very young that "less is better", especially with stuff like the TW/Simonize/M16.
Heh heh...I gotta tease you about going through FK1000P so fast! That tiny (and dried-out) sample tin I got for free did dozens of coats on wheels and countless coats on big vehicles like my old Yukon XLD (including jambs/etc.), and still lasted me for years. The regular-size tin I have is gonna last far longer than the decade+ that I get out of most any tin of wax (and you may have noticed that I do believe in layering on many applications of my LSPs).
While doing the *really* thin applications strikes some as a PIA, I honestly believe you`re making things very hard on yourself by slathering on more than is necessary. But admittedly, what we do regularly becomes what we consider normal, and I`ve been doing this thin stuff since forever so I might have a skewed perspective.
Like...a really thin application of something like KSG can be virtually invisible on white/silver, but as long as there`s complete coverage (no missed areas) it`s still plenty. I think in terms of bonding to/covering the paint at the *molecular* level even if that`s an exaggeration if taken literally.
I focus on *feeling* the diff between waxed/not areas, rather than seeing the LSP on the paint, when I apply. Paint with LSP on it feels different from paint that`s still bare and also from paint with not-immediately-fresh LSP on it (even if that`s more subtle). I bet that a little concentrated, determined experience will make that obvious to you and then the lightbulb will come on :D
Not sure if you got complete coverage? Fog the surface with your breath (OK, some environmental factors matter...) and I bet you`ll see it on there after all. And I find that fogging contributes just enough moisture to make buffing off easier without compromising the results in any way.
Anyhoo...I`m glad it`s working well for you and that you think it`s a good LSP.
Accumulator - Yeah, if I can just tell myself that thin is better I probably wouldn`t have as much trouble as I do removing some of the waxes I use or have used in the past. A few years ago I picked up some BFCS to try for my spring and summer sealants so I wouldn`t have to mess with the FK1000p for more than once a year. I even have trouble on usage on that and have gone through more of the bottle than I should have considering the couple different times I have used it. The only one I seem to have properly put on is the BFWD, but have only used that couple times. Then of course I had to BFMS , have used that once or twice and at least on black it seemed a little easier to see exactly how much I was using.
Maybe I will learn one of these times to try and use sparingly. Although I can say if I don`t I don`t think I will run out of product in a while.
skibik- Heh heh, sounds like you`ve certainly, uhm...accumulated...plenty of LSPs! So yeah, other than making it hard(er) on yourself and maybe precluding the most effective layering, eh...you`re doing fine. You might work harder on the thin application than you currently work on buffing it off ;)
You sure did get my attention with that rate of FK1000P consumption though!
I have applied FK1000P by hand using a 4 inch lake country hydro-tech red pad which does not let the product sink into the pad. I really didn`t try to keep it too thin but after 1 panel took a short nap micro fiber and wiped lightly to even it out thin it out. Then let it dry completely wipes off easy after that just as easy as anything I have ever used. My new go to LSP
superdave592- Welcome to Autopia!
You`re in good company with that two-stage buff-off; Ketch (the guy who schooled me on so much FK and ValuGard stuff) advocated that too. (He thought it`d help make the immediate layering work out better.)
I never thought of doing that to level it out, that might be just the ticket for people who don`t want to do the thin THIN *THIN* applications, so thanks for sharing that.
Glad to hear it`s working out so well for you!
I got around to trying this LSP out on my headlights & other plastics first. I noticed the haze is pretty hard to wipe off. A single 30cm sq mircofibre cloth did not get most of the haze off no matter how many times I tried, just 80% & the left over would not absorb by the cloth. I had to use many tissues to get it crystal clear.
So how do you guys buff this haze off? Do you use many MF cloths of something? If so how do you wash these MF cloths after?
Sounds like it was applied on the heavy side. Thin, thin, thin layers is the key.
Tc99m
Any pointers on how to get that thin application? It seems like a skill that once you develop it its second nature but until then it can be less than intuive. Is the amount you are loading the applicator the key or a light touch or something else?
My recommendation is a thin, round foam applicator. Place it in the tin and give it a 90 degree twist with just a little bit of pressure to pick up a small amount of FK1000P, and then use that to cover an entire panel.
After you do this a few times, the applicator will start to get saturated and you won`t have to replenish it as much. When you`re done, store the applicator in the tin.
If you use more than what looks like a greasy palm print, you`ve used too much.
Quote:
Originally Posted by `PRND[S
;2113069`]My recommendation is a thin, round foam applicator. Place it in the tin and give it a 90 degree twist with just a little bit of pressure to pick up a small amount of FK1000P, and then use that to cover an entire panel.
^ This about sums it up.
Regulars here have probably heard all this from me before, and if I had All The Answers people wouldn`t keep asking the same "how do I make this application process go easier?!?" all the time! But anyhoo, here I go again:
I too use the regular round foam applicators. When I do it, I get a minimal amount on the applicator, fold it in half and rub the "application/loaded" side of it together so the minimal amount of product gets uniformly distributed on the face of the applicator, then...very important... I try to scrape as much product back out of the applicator (on the edge of the tin) as I can.
No matter how diligently I do the above, I always get more product transferred to the applicator than I need, but oh well, that`s usually enough to do a rather large area, and I try to transfer a minimal amount of fresh product when I reload the applicator, always trying to scrape out any excess on the edge of the tin`s rim. I DO NOT rub the applicator together aggressively, and I sure don`t wipe it across the product in the tin with any more force than I need to transfer a minimal amount of product to the foam. I think of it as wanting the product to be "on" the foam rather than "in"/saturating it and if I only get enough to do part of a panel then I got it right.
I never give any thought to how firmly I`m pressing when I apply, though I guess I try to not overdo it in case some contamination somehow gets on there. I go over the same area a few times to ensure that I get a uniform application since there`s so little product being used. I usually go in overlapping circles, only doing straight-line when the area calls for that (e.g., thin pillars).
I suppose that practice/experience factors in...I`ve been aiming for "so thin I can`t really see it" with all my LSPs for decades so I oughta be pretty dialed-in by now. I go by feel rather than visual cues; the applicator glides over (re)LSPed areas more readily than it does over the areas I haven`t done yet.
For easier buff-off, try fogging the surface with your breath. This can also make it easier to notice skipped areas.
End-of-process test- If I can squeeze an appreciable amount of product out of the applicator at the end of the job, then I had it loaded with *WAY* too much product.
Use however many buff-off MFs as *you* need. Just because I can do a large vehicle with only one (well, at least sometimes..) that doesn`t mean much of anything relative to anybody else.
I don`t leave the applicator in the tin for very long these days. I`ve found that it can apparently (and only sometimes) soak up additional product, which is the last thing I want, and if I leave the applicator in there long enough (I can go many months between applications) the foam sometimes deteriorates a little bit (maybe it`s not real deterioration but rather just that soaking up additional product, but whatever happens I don`t like it).
I dunno...I just don`t get it..and please don`t take that as some kind of put-down. I`ve used "hard to buff off" LSPs since forever, and I`ve simply never experienced that other than when I missed an area done with M16...now *that* will take a bit of effort after a few weeks! Heh heh, the ladies who intro`ed me to M16 back in the day said how *EASY* it was compared to Simonize, they thought it was some miracle product with regard to user-friendliness! And M16 is a lot less forgiving than FK1000P. Gee, wonder if Floyd had *that* in mind too when he came up with the stuff...
I think FK is easy to remove if applying it thin, do you consider to use some DA polisher after applying by hand? I`ll give it try next after washing my car
Sent from my Grand2 using Tapatalk
Thanks Accumulator and PRND[S, really useful tips on applying thin. Its good to know you do overlapping circles with no solvent issues Accumulator.
Years ago I used some Nufinish, now that stuff is hard to buff off!
Thanks for the lesson Accumulator. I am going to have to give that a try. It is the end of June and car needs protection bad. I guess my applications go far beyond thick seeing your procedure. I guess I don`t need to swirl the applicator around in the tin 3 or 4 times every half panel then, huh! B)
Mic575
If it wasn`t for finding this site I would still be using NuFinish and only remember having trouble removing it when I did it in direct sunlight(no garage at that time to work in). Otherwise I liked that stuff for how easy it went on and came off. After some thought I kind of wish I wouldn`t have found this site and got the detailing bug. I would have one polish, one wax(maybe two) a handful of towels(cotton, the old school stuff), one car wash soap, and wax twice a year and maybe polish once in the time I own the car. All products could be found at the local hardware or auto parts store and no special ordering.
The best stuff I ever used for ease of removal was AutoFom. It was kind of left an oily film that took extra cloths to buff off.
skibik
Back when life was simple is what you`re saying :), bet you only had one bucket too. I used the Nufinish liquid and I think I must have put it on like I was frosting a cake. I think that this is not the approach that Accumulator is getting at here :)
Mic575
Yes! I may have two buckets now, and have tried the two bucket method, but back to one when I hand wash. It might be just me but I don`t see the benefit of using two and yes I have done the research.
I laughed when you mentioned "putting it on like frosting a cake". That brought me back to my teen years helping Dad wax his new Chevette and using the TW Hardshell, liquid even and putting that on and when it dried actually looked like we had frosted the car. LOL!
As a kid I over-applied M07...no big problem, just took forever to buff off/out of the ss lacquer of the day. But then I went to wax over it, and !uh-oh! over-applying M16 was a quick lesson in What Not To Do.
Wonder if any Marine places sell the FK...and remember that brink-and-mortar Autobody/paint supply places often sell decent detailing supplies (along with sometimes OK/not off-brands).
Some guys here have actually done OK with NuFinish...IIRC they use it for non-critical areas on customers` vehicles that aren`t headed for the how circuit.
Quote:
When I *did* get the solvent-action issues (well, I assume that`s what caused the pseudo-holograms) I figure it was from trying to layer too much/soon. I had the same issues on sections where I did/not use circles/straight lines, didn`t seem to matter.
Some people make a big deal out of the "wax in straight lines!" idea, but that flies in the face of how well LSPing works via RO/DA. Speaking of which...
Time expenditure-wise, I probably LSP a lot faster if I just do it by hand (get out polisher, set up, etc. etc. compared to just grab applicator and go) and I just can`t do the minimal product/thin application stuff as well. Do (did?) like applying Collinite/M16 by machine though...and once it`s on there...
Quote:
Originally Posted by ariezhai5
...do you consider to use some DA polisher after applying by hand?
I might be the only guy here who buffs off LSP residue with a machine on a remotely regular basis...and I don`t do it all the time. No matter how I do it, I always have to do some by-hand buffing too, not just for tight spots but also to get that last 1% of product off and ensure a perfectly clear buff-off. Whichever I do first, I gotta do the other as a follow-up, so I usually use the machine first and then go over it again (fogging with my breath) by hand.
I`ve used plush and suede-style/no-nap MF bonnets and other than the latter being *utterly* unforgiving if some abrasive contamination gets caught in `em, I found no appreciable diffs. (The argument that "plush MF bonnets pull the wax off! Gotta use the suede-style ones to avoid that!" did NOT prove true IME.)
If you use a wool for the backing pad (that the MF bonnet(s) fit over), I would *NOT* turn the bonnets inside-out to get a second time`s use out of them lest some wool get transferred and cause marring. For that matter, I don`t do it period because I like using the bonnets over fairly firm/large-pore cutting pads and I don`t want their (foam) material getting transferred either. I usually use the Meguiar`s burgundy cutting pads with 5-6" bonnets and LC yellow cutting pads with 4" ones. After a while the backing pads compress and IMO that`s the time to get new ones. The only time I used a pad that was supposedly specific to this task it did NOT work well at all; the bonnet slipped around way too much to be effective (you need a pretty tight fit).
Often, the outer edges of the bonnets get loaded with product residue *MUCH* sooner than the rest and IMO you`ll need more bonnets than you`d expect, even if you put LSPs on as thinly as I do. Maybe a lot more.
While I do think it takes more time, and yields only *VERY* minor appearance benefits (and not always..), doing this stuff by machine is a very different motion and was the only way I could do such stuff when I had shoulder issues. And it`s an excuse to run those Cyclos I like so much :D
I have done some searching about how exactly you are suppose to clean the buff off microfibre cloths? I tried a typical hot soak with soap powder but it doesn`t get all the wax off resulting in a dry cloth that is a bit hard & may cause swirl, aswell probably won`t absorb well when buffing as it still has wax on it.
I then tried wax & grease remover a few times by hand which gets most of the wax out. Then let the hydrocarbons evaporate completely & then a soapy wash. After that the cloth is very clean with no smell & buffs off the wax well.
