Jescar Micro Finishing Polish (+ special guests) - Review
As a long time fan of Menzerna SF-4000 and now SF-3500 I was intrigued when I saw Jescar, (formally MenzernaUSA) developed their own line of compound and polish. Could Jescar’s Micro Finishing Polish be better than SF-3500? Or was it the same thing just relabel? With my annual Spring detail coming up, I jumped at the chance to try Jescar’s Micro Finishing Polish out and find out for myself.
http://i.imgur.com/Ap4dkMcl.jpg
From Autopia’s copy for Jescar MFP:
Jescar Micro Finishing Polish, developed using the same advanced abrasive technology as the Jescar Correcting Compound, contains uniform particles that will perfect your paint quickly and consistently. Jescar Micro Finishing Polish contains no fillers, silicones, or waxes that hide paint imperfections – not only making Jescar Finishing Polish body-shop safe, but also a genuine paint polish that will leave your paint looking it’s best.
*Bias Review Disclaimer* AG sent me Jescar Micro Finishing Polish, Correcting Compound, and Lake Country’s HDO pad line to use and review at no-charge. Ok now that bit of housekeeping is out of the way… Onto my review!
Directions
Typical and straightforward:
http://i.imgur.com/7nvnusWl.jpg
Warning and contact info:
http://i.imgur.com/TRqs5ZBl.jpg
So basically don’t eat it, wear safety glasses, and gloves!
Appearance:
http://i.imgur.com/XZ1LHX4l.jpg
The speckled purple consistency of MFP looks exactly the same as SF-3500 and Pinnacle Advanced Finishing Polish. Smells pretty similar too. Anyone know why finishing polishes tend to be this color? Is there a technical reason besides being a nice color?
Application
Using MFP is as easy as you’d expect. Here’s a 50/50 of my trunk after 5-6 section passes using a B&S Uro-Tec light polishing pad:
http://i.imgur.com/nzfUj8al.jpg
Same area, viewed from the side:
http://i.imgur.com/fTIw7ZI.gif
Nice and corrected!
During my last visit to the dealership the tech left behind a special gift:
http://i.imgur.com/fPSDeJ5l.jpg
http://i.imgur.com/taoBWVQ.gif
These have been bugging me for long enough!! It’s time to get rid of them!
Enter Jescar Correcting Compound + LC’s HDO Blue Foam Heavy Cutting Pad.
http://i.imgur.com/jgt7s0Wl.jpg
Pad primed and ready to go:
http://i.imgur.com/PlKQ7wyl.jpg
After 5-6 section passes:
http://i.imgur.com/1eYkOmul.jpg
Scratches are gone, with only a slight amount of compounding haze remaining:
http://i.imgur.com/ojuGtbS.gif
Time to refine the area with Micro Finishing Polish + LC’s HDO Orange Foam Polishing Pad:
http://i.imgur.com/jRIRpbHl.jpg
After 5-6 passes:
http://i.imgur.com/4Aol5c4l.jpg
Perfection!
http://i.imgur.com/7wLSg40.gif
*mini-review* I was very impressed at how well Jescar Correcting Compound + LC’s HDO Blue Foam Heavy Cutting Pad did to remove the DISO’s. The HDO pads are also very nice to use, ran smooth, and did not heat up as quickly as conventional pads would have. However when performing a 1 step correction Jescar’s MFP + HDO polishing pad didn’t remove watermarks as quickly as B&S Uro-Tec light polishing pads and required additional passes.
Jescar Micro Finishing Polish VS. Menzerna SF-3500
After completing 75% of the car I had a pretty good understanding how Jescar Micro Finishing Polish performed. It was time to use it back to back with SF-3500.
First up, Jescar MFP:
http://i.imgur.com/duM2Zfu.gif
Now for Menzerna SF-3500:
http://i.imgur.com/wDHJlKj.gif
If you couldn’t tell by the above, the main difference I found was SF-3500 is oilier and takes longer to remove. I repeated this comparison a few times and the results were always the same. Both do a fantastic job at polishing the surface BUT Jescar MFP requires less effort to remove and in turn, allows you to finish the job faster.
In both test I used the same amount of polish, on a HDO polishing pad, worked for 5-6 section passes on adjacent areas of the same panel, and wiped off with separate clean towels.
Cost comparison: based on an 8oz bottle: oz per oz Jescar MFP is less expensive than Menzerna SF-3500 @ $2.25 per oz vs $3.12 per oz respectively or $17.99 vs $24.99 per bottle.
Results
All done and coated with Gtechniq CSL + EXO:
http://i.imgur.com/rYP46vUl.jpg
http://i.imgur.com/Qs8QqjJl.jpg
http://i.imgur.com/zHrtzztl.jpg
http://i.imgur.com/RemOpTpl.jpg
http://i.imgur.com/NnzNWVIl.jpg
http://i.imgur.com/6A0qf0Ql.jpg
Conclusion
Jescar Micro Finishing Polish is awesome. If you like using Menzerna SF-3500 but have been put off by how oily it is to remove or how expensive it is to purchase - Jescar Micro Finishing Polish is the answer. I can’t wait to use up my current supply of SF-3500 so I can switch over.
I hope you enjoyed this review and the information provided was helpful to anyone considering purchasing any or all of these products.
Re: Jescar Micro Finishing Polish (+ special guests) - Review
Great review. I also like the gif`s you made! That is a great idea.
How are the HDO pads? I have been looking at purchasing the Blue pads but was not sure if it was worth jumping in with all the other pads I currently have.
Quote:
Originally Posted by
RaydiantDetail
Thanks! The gif are pretty cool huh? Takes things to the next level ;)
RE: HDO pads: the blue ones are nice, held their shape, and cut well as you could see from all of the scratches that were removed. I only used the Blue HDO pad in a few small areas so I my feedback on them is limited, sorry!
Awesome review, thanks for sharing. The GIFs are pretty cool, I was able to see how the menzerna took a bit more to take off. I`ve used menzerna for years and love them, so taking off the product is normal to me but in your comparison there`s a big difference! BTW, your car is a beauty!
Car looks good !!!! (still miss mine)..
LOVE the gifs. How do you do them?
I wonder why a company would make a product that competes with itself? Why didn`t Menz/Jescar just improve 3500 and slap a label on it? I`ll use up my remainder of 3500 before I jump on the Jescar train. Thanks for the nice review!
awesome review, pictures and gifs and everything! i love me some HD polish+ but i may be switching soon....
xspwrstang
Thank you! I`m happy to hear you enjoyed the review. The difference in oil between Menz and Jescar is significant: It`s faster to remove, your towels stay cleaner for longer, and you move faster from section to section.
Ronkh
Thanks, Ron! I`m doing my best to hold on to it...
Ronkh
:ph34r:
rlmccarty2000
Thank you, Sir! From my understanding Menzerna and Jescar are separate companies. Jescar was the US importer for Menzerna but decided to drop the "Menzerna USA" name and develop their own Jescar product line. Just wait, Menzerna will inevitability change the name of Super Finish again and when they do maybe they`ll make it even better then Jescar MFP.
donbeezy
Thanks, Don! Very kind of you to say :)
Boden
Nicely done
Thank you!
I`ve been a Menzerna user for years. I absolutely loved the fast glass 400. I`m going to pick up some of that micro finishing polish. Thanks for the review!
Thanks for the review. I picked up Jescar correcting from AG during one of the sales, have yet to try it. I have a car that`s pretty swirled and scratched that I`ll try it on in near future.
WaxManRonnie
HCF
Thanks, fellas. Jescar polishes are great. You`re not going to be disapointed.
I used Jescar Correcting Compound with Orange Lake Country Hybrid pads on a Honda. I`m really cautious, so this was as aggressive as I wanted to go. It required a few attempts in some sections to remove ice scrapper scratches, and it probably due to my pad limitation. What struck me the most was how well it finished. Fantastic reflection, no haze, and I mean fantastic.
