Pro Polish & Pro Polish 2
Hi, I am someone who has primarily used Menzerna Polishes, and curious about 2 other products in my possession.
For the people who have experience using Poorboys Pro & or Pro 2: what`s your optimal number of section passes/working time? for paint cleansing, correction, light correction?
Sharing your experiences would be very appreciated!
Re: Pro Polish & Pro Polish 2
I LOVE PRO POLISH AND IT HAS SAVED ME ON MORE THAN ONE OCASSION. I WORK IT UNTIL ITS JUST ABOUT GONE AND THEN WIPE. THE PAD WILL DETERMINE THE CUT.
Oops, just looked up, sorry for the caps,
Pro polish is pad dependent. 2 has abrasive put like all other polishes is also pad dependent. So depends on a lot of factors. "it takes what it takes"
(that`s why we do test spots)
you using it with a rotary or DA?
Pro Polish is usually my first choice as a pre-wax cleaner. I use it will be LC Black/B&S Blue pad. As a paint cleaner, you just work it for like 3 passes at medium speed (like 3 to 4) and wipe off.
I like ProPolish 2 on glass to remove water spots and contamination. I will use a cutting pad (not going to hurt the glass) and work it until it disappears somewhat.
They are great by themselves or as a combo ... cleaning and correction ... pad dependent .... use either in sun or shade ....
