Just got some Rupes supplies, thinking about ordering more, but have to try first , especially the orange peal remover lookin` blue pad.
Printable View
I havent used them but theyre supposed to be very good as a heavy cut pad
Just got my Blues in this week. Have used the Gray (next step down) with UHS and was very impressed.
They soften considerably when the get warm. Actually felt very soft when washing with hot water.
I have all the rupes pads. The blue foam i still have yet to use.
Glad to hear about the uhs though too. Still yet to try my uhs system.
I used the blue mf cutting disc which is more aggressive and w the blue rupes compound it was very effective.
The foam is a step lower in cut i believe.
the green softens up a lot after use. Id expect the same from the blue foam
That is partially the reason why I haven`t swapped everything over the full Rupes line. I love the polishes and pads, but I don`t want to be wasting money because the pads wear out. I still try to use the Lake Country Hd`s when I can because they can take a lot of abuse.
Same, I really try an sub in microfiber for cutting as much as possible. I love foam but it does get expensive, that said it is easier to clean then MF.
As far as being worried, the only pads you should never touch are denim, velvet and maybe some surbuf`s other wise any Rupes pad is fine. Always judge the cut by starting with the lightest cut then go down from there. You can always take away material, you cannot add.
As always a lot of good advise here, Thank You All.
My only complaint with the blue pad is the large size of the holes or cells; it seems to cause the compound to dry very quickly resulting in massive dusting. Be prepared to use a lot of compound to prime.
I never prime any of my Rupes pads. 3 drops, spread around speed 4, and crank up the speed and polish.
How do I prime a Rupes Foam Pad on a Rupes Polisher? - Detailing World
I love the denim pads, I cut my teeth with them...
Before(factory paint job had really bad OP):
http://i7.photobucket.com/albums/y28...fore%20002.jpg
http://i7.photobucket.com/albums/y28...fore%20001.jpg
After (denim pad & m101 only):
http://i7.photobucket.com/albums/y28...fter%20002.jpg
http://i7.photobucket.com/albums/y28...fter%20001.jpg
