Have a DA, what to get next?
I have a typical $150 DA and I really like the results I get with it.
However, I aspire to make this in to a career and the time it takes is much too long.
With that in mind, what would you recommend as a second tool for a prosumer? It seems like the biggest contenders are the PE14, the Rupes, the 3401 and the G21.
Re: Have a DA, what to get next?
A rotary and learn how to use it.
Dave
I would suggest that you ned to learn more about paint and the step between a 150 dollar DA and a rotary would certainly be a long throw machine like the Rupes or the Griots Garage unit.
Paint correction takes time, I did not expect it to take as long as it does and I think that is a common misconception of people who don`t understand the process.
Quote:
Originally Posted by
JSFM35X
I would suggest that you need to learn more about paint
and the step between a 150 dollar DA and a rotary would certainly be a long throw machine like the Rupes or the Griot`s Garage unit.
Agreed. IMHO A rotary, although an excellent machine, is something you grow into I`d suggest a long throw Rupes 21 or Griot`s BOSS 21.
I have not used a Griot`s BOSS but my Rupes 21 is MY GO-TO machine. The Flex 3401 is a direct drive DA that can cut down polish time.
Again, the Rupes 21 with a 5" backing plate is the machine I reach for 90% of the time. It is well balanced & leaves a crystal clear finish.
In the end isn`t a crystal clear finish what we want? This can that be accomplished with a rotary or a 3401 but you`ll need to master skills.
If there`s one thing I`ve learned it`s that modern clear coat is VERY thin. Fast hard cutting machines are very dangerous in untrained hands.
If prefer slower. Why? I use less aggressive methods & remove minimal CC. Removing too much may look good at the time but causes issues.
number1show
Time is your friend. My typical exterior paint correction and gloss enhancement polish takes 20-40 hours. Don`t be a hack. Be the best you can be!
