i am in the middle of a correction and i only have 1/4 bottle of carpro eraser that is 2+ years old... is it still ok to use to wipe the car down after the polishing? any chances that it could have a negative effect?
thanks
Printable View
thanks
Alcohol evaporates over time. So it`s safe but might be alcohol free because of the time lapse.
As long as it doesn`t have a bitter taste you are good to go
thx guys
it looks and smells just like new
Like I said the alcohol is almost a guarantee to be evaporated and probably won`t work as expected. But you`d never know unless you feel like applying a microscope to your paint and dissecting molecules. Lol
I still have 2 year old Eraser not used. Shook it up today, opened the cap and it still smelled like alkie. Mine looks OK, smells OK, BUT, I did not taste it!!!
Don`t throw out your Eraser!!!
Figured I`d post this info for anyone with the same problem.
I emailed Carlos @ 3D this morning. ...
"Carlos, hoping you can help. I purchased a bottle of Eraser last year. Never even had a chance to try it. It has lost it green color and become cloudy and separated. My garage gets cold in the winter but not to freeze temp.Does this product have a short shelf life?
Has the formula been changed to prevent this if I was to get more?"
His reply:
"that tends to me normal,our products are biodegradable so even if you leave it a week in the sun it will lose its color, the cloudiness has change we`re using a different type of acid, but even though its cloudy it will still work"
So you asked Carlos @ 3D about your Carpro Eraser?
Id say mine wore out, not sure if that means it went bad but it worked on multiple cars then started falling apart on the clay pad surface.
