How long after application can the gloss coat get wet? It`s in the garage and forecast is for rain I`d like to know when I. Can pull it out.
Printable View
optimum told me you can put a coat of wax over it in an hour so would say if it sit over night you should be fine. How do you like gloss coat so far. I like the fact it is easy to use
I will do a full write up shortly but for now I can share the following.
Application is easy, gloss is better than 2.0 and slickness is much better. I had a harder time seeing the product go on the the paint (silver metallic) and that slowed me down as I had to apply slower since you could not see missed spots.
I hope it lasts a long time asm beads like crazy.
Were facing off lol. I`m putting cq UK on the S7 this weekend. Even though it`s a month past the expiration date. Also putting Dlux for the exhaust, flyby30 all windows and forte for the windscreen.
I would say any coating a week an make sure you put a top coat.
Well this is my sons car and I kicked myself out of the garage Bc I did not want the coating to get misted on yesterday.
Best advice is this, if it does rain or get wet. It`s not the water thats your enemy it`s minerals an sun. Just be sure to park it in the shade, as long as it doesn`t bake in you should be fine (Assuming you remove the water within a couple of hours).
