This is another`<span style="font-size:14px;"><span style="color:rgb(0,128,0);">Detailing Made Simple`instruction on how to clean, shine & protect your wheels/tires on your favorite vehicle with 3D Products. As long as you have the right tools, you can dramatically reduce your touch time and increase your effectiveness to achieve a great end result. You certainly don’t need complicated tools or expensive products, just a little ingenuity and some common sense thinking to get the job done. Here`s basically what you need:
http://i485.photobucket.com/albums/r...Wheels/856.jpg
Let’s start by mixing up the proper dilution of 3D’s Yellow Degreaser. 1st and foremost, this is an alkaline based cleaner and should only be used on chrome & clearcoated wheels. Using it on polished or uncoated wheels could cause blushing of the finish, so it is important to know what surface you’re working with before starting. In this case, we are working with a Corvette ZR-1 and this car is equipped with both clearcoated (powdercoated to be specific) wheels with carbon ceramic brake rotors. Even though the directions state this product can be diluted all the way up to 10 to 1, I’ve decided to select a 4 to 1 mixture for this application due to this vehicle’s tires having a heavy buildup of dressing and soiling.
http://i485.photobucket.com/albums/r...Wheels/832.jpg
Simply mark off a line on your bottle to exemplify a 4 to 1 mixture and add the appropriate amount of straight product to your bottle of choice.
http://i485.photobucket.com/albums/r...Wheels/834.jpg
Then fill with water:
http://i485.photobucket.com/albums/r...Wheels/835.jpg
http://i485.photobucket.com/albums/r...Wheels/836.jpg
Then give it a light shaking to stir up the contents:
http://i485.photobucket.com/albums/r...Wheels/837.jpg
Here’s what I was referring to as far as old dressing build up on the tire:
http://i485.photobucket.com/albums/r...Wheels/862.jpg
Next, prepare your wash bucket by cleaning it thoroughly to remove any dirt or loose debris that could cause scratches to your car’s finish.
http://i485.photobucket.com/albums/r...Wheels/840.jpg
Now, I selected 3D’s Wash N Wax concentrate shampoo. According to the directions, it states that for every 1 Gallon of water, you should add 1 Ounce of product.
http://i485.photobucket.com/albums/r...Wheels/841.jpg
Because I chose to mix approximately 3 gallons of water, I added 3 ounces of product.
http://i485.photobucket.com/albums/r...Wheels/844.jpg
Simply pour the contents into your water filled bucket and flush all contents from the mixing cup:
http://i485.photobucket.com/albums/r...Wheels/845.jpg
http://i485.photobucket.com/albums/r...Wheels/846.jpg
Next, mix thoroughly by hand and then give it a good blast with your water hose to get the foam extremely thick.
http://i485.photobucket.com/albums/r...Wheels/847.jpg
http://i485.photobucket.com/albums/r...Wheels/848.jpg
http://i485.photobucket.com/albums/r...Wheels/849.jpg
http://i485.photobucket.com/albums/r...Wheels/853.jpg
Next, give the surface you are going to clean a thorough rinsing to loosen and remove any potential topical dirt that could cause marring to the finish. This not only makes your job of cleaning the surface easier, but allows the chemical cleaner to attack the surface quicker as there is less dirt to break through.
http://i485.photobucket.com/albums/r...Wheels/859.jpg
And don`t forget about the wheel wells too:
http://i485.photobucket.com/albums/r...Wheels/861.jpg
Next, coat the entire wheel, tire and wheel well with product and allow to dwell.
http://i485.photobucket.com/albums/r...Wheels/864.jpg
Because of my personal preference (yours might vary), I like to scrub the tire 1st:
http://i485.photobucket.com/albums/r...Wheels/865.jpg
I then clean the inside barrels of the wheel with the tool of your choice:
http://i485.photobucket.com/albums/r...Wheels/868.jpg
And then next is the most time consuming part…..cleaning the outside face of the wheel and back behind the spokes. For this chore, I like to use a retired Micro Fiber towel that no long gets used for paint duty:
http://i485.photobucket.com/albums/r...Wheels/858.jpg
http://i485.photobucket.com/albums/r...Wheels/870.jpg
http://i485.photobucket.com/albums/r...Wheels/872.jpg
A MF towel is an excellent and inexpensive tool to use for cleaning the inside lug recesses of the wheel:
http://i485.photobucket.com/albums/r...Wheels/873.jpg
And then lastly, take you MF towel and clean your wheel well:
http://i485.photobucket.com/albums/r...Wheels/877.jpg
Rinse the entire wheel, tire & wheel well:
http://i485.photobucket.com/albums/r...Wheels/880.jpg
http://i485.photobucket.com/albums/r...Wheels/881.jpg
<span style="color:rgb(255,0,0);">IMPORTANT: even though your wash solution may appear dirty, it doesn’t mean that it’s still not effective to keep cleaning your wheels:
http://i485.photobucket.com/albums/r...Wheels/886.jpg
Just simply shoot your water hose into your bucket to rejuvenate the suds:
http://i485.photobucket.com/albums/r...Wheels/887.jpg
http://i485.photobucket.com/albums/r...Wheels/888.jpg
After the cleaning is done, I like to use my leaf blower or compressed air to dry out all the cracks and crevices of the wheel:
http://i485.photobucket.com/albums/r...Wheels/890.jpg
Once the wheels are cleaned and dried, I apply a quality paint sealant like HD POXY to the wheel faces. HD POXY is an excellent choice due to its ability to bond incredibly to the wheel and withstand high temperatures all while still protecting the surface and providing a barrier for ease of cleaning at later times:
http://i485.photobucket.com/albums/r...Wheels/901.jpg
Apply to soft applicator and work it in to thoroughy coat the pad:
http://i485.photobucket.com/albums/r...Wheels/895.jpg
http://i485.photobucket.com/albums/r...Wheels/896.jpg
http://i485.photobucket.com/albums/r...Wheels/897.jpg
Then wipe on entire wheel:
http://i485.photobucket.com/albums/r...Wheels/899.jpg
http://i485.photobucket.com/albums/r...Wheels/900.jpg
Once the sealant is removed, we will lastly be dressing the tires. For this, I like 3D’s Ultra Protectant.
http://i485.photobucket.com/albums/r...Wheels/905.jpg
http://i485.photobucket.com/albums/r...Wheels/907.jpg
http://i485.photobucket.com/albums/r...Wheels/908.jpg
<span style="color:rgb(255,0,0);">IMPORTANT TIP: I like to consciously NOT dress the area of the tire between the 5 and 7 o’clock position of the tire. This way, when you move the car forward/backwards it will noticeably stick out as being bare compared to the surrounding wet looking surface.
Then, reverse or move your car forward a few feet and finish dressing the entire wheel:
http://i485.photobucket.com/albums/r...Wheels/912.jpg
Lastly, with a retired MF towel, final clean and inspect the wheel for any missed spots of wax or soiling:
http://i485.photobucket.com/albums/r...Wheels/919.jpg
<span style="color:rgb(255,0,0);">FINAL OUTCOME: Perfectly cleaned, shined & protected wheels and tires:
http://i485.photobucket.com/albums/r...Wheels/921.jpg
Products Used:
<span style="color:rgb(255,0,0);">3D Wash & Wax: Car Soap for Glossy Finish | Wash N Wax | 3D Products
<span style="color:rgb(255,0,0);">3D Yellow Degreaser: White Wall & Tire Degreaser - Yellow Degreaser | 3D Products
<span style="color:rgb(255,0,0);">3D Ultra Protectant: Tire Dressing Product - Shining Tires with Ultra Protectant | 3DProducts
<span style="color:rgb(255,0,0);">HD POXY: Polymer Sealant Car Wax & Car Paint Protectant - HD POXY | 3D Products
