Cloth seats have been one area that has given me more grief than any other aspect of detailing. Ive used about every tool and method out there, and the results were rarely consistent. It seemed that even with a good extractor, I could never get them dry before the wicking occurred (I didn`t have a good air dryer). I decided to think way outside of the box a couple years ago, and came up with what is now known as the Nathan Flannell Method.
Here is a 2012 Ford Focus with what I would call average seats.
http://i970.photobucket.com/albums/a...1/DSCF1382.jpg
http://i970.photobucket.com/albums/a...1/DSCF1381.jpg
http://i970.photobucket.com/albums/a...1/DSCF1380.jpg
http://i970.photobucket.com/albums/a...1/DSCF1379.jpg
I like to start out with a pretreatment of the bad areas. Ive found Megs APC+ to work very well for this, but that`s just my personal preference.
http://i970.photobucket.com/albums/a...1/DSCF1384.jpg
http://i970.photobucket.com/albums/a...1/DSCF1386.jpg
I try not to really soak the seats, but you do need to apply`enough for it to be breaking down the stains. I also`like to do every seat before I move on to the next step. This in theory will be`working on`the heavily soiled areas and will`make it easier to remove in the`next`steps. `
The next thing is choosing your pad. I personally like twisted wool, but foamed wool, foam, microfiber, they all work to some degree. I like the 7in twisted wool because of its absorbing ability. Also, you want to dedicate this pad to only seats.
http://i970.photobucket.com/albums/a...1/DSCF1389.jpg
I decided to use Tuff Stuff for this write up as opposed to Car Brite Xtra Duty that I normally use. Tuff Stuff is easily available to everyone, so that`s what I went with for this.
http://i970.photobucket.com/albums/a...1/DSCF1390.jpg
Now that the APC has been applied to the trouble areas, I move on to foaming the seat. I cover the entire section with foam, let it sit for a few seconds, then slowly start scrubbing it with the rotary. RPMs should be set to around 800 on a rotary.
http://i970.photobucket.com/albums/a...1/DSCF1392.jpg
http://i970.photobucket.com/albums/a...1/DSCF1391.jpg
Once the entire seat has been cleaned including the back and sides, I`ll use a clean dry mf towel and wipe the seat down really good, alone with the surrounding areas. This method can be a little messy. I like to do this first, before I detail the rest of the interior. Usually by the time I finish the interior detail, the seats are dry enough to sit in. This is possibly my favorite thing about this method.
http://i970.photobucket.com/albums/a...1/DSCF1397.jpg
http://i970.photobucket.com/albums/a...1/DSCF1395.jpg
http://i970.photobucket.com/albums/a...1/DSCF1398.jpg
http://i970.photobucket.com/albums/a...1/DSCF1400.jpg
Thanks for looking, and I look forward to any questions or comments.
