To ensure that a decontamination system can effectively remove surface or sub-surface contaminants, you may need to remove the paint protection system. The requirement is for a product that will effectively remove surface residue; *such as silicone, surfactants, oil, wax and polish lubrication residue, ensuring a ‘clean’ (Gtechniq Panel Wipe) surface prior to the decontamination process. These panel wipes blend pure alcohols with aromatic solvents to dissolve any polish residues and `flash` off, to leave a completely ‘cleaned’ paint surface.
The ValuGuard Decontamination System contains an ‘Acid Neutralizer’ (part A) that will accomplish this residue removal
*This type of residue should also be removed prior to the application of a coating type paint protection
