I`ve always like the idea of an all in one (mild polishing abrasives w/ LSP protection), especially for single stage paints, and I started using OPS (optimum poli-seal) earlier this year. I just picked up some 3D speed to test against and here is what I found:
Decided to try out my new Flex 3403 lightweight rotary (1st time with any rotary) with LC white pad.
Wanted a quick test on something that would show good results for what I`m after with this type of product so I did half/half on my 7 y/o, never maintained truck toolbox (black powdercoat).
OPS:
Initially looked like less (no) dusting, though slightly harder to cleanup (marginal)
Good durability (~2months, known from previous use on an outdoor only-vehicle)
Good cut (fine polishing) ability for what the product is, pretty good swirl removal on the other vehicle I`ve used it on that lives outdoors.
Slight chemical smell, not bad at all.
Slight yellowish stainig of white pads, liveable
--Overall, what I wanted initially.
3D Speed:
Slight dusting, but easier wipeup than OPS
Unknown durability so far
Better cut than OPS and finishes just as good
Grape smell (normally I don`t like grape smell, think Dimetap, but this was actually ok)
Pink staining of white pads (My biggest complaint about this product)
--Overall I like it better than OPS, though both are great products.
NOTE TAPELINE DOWN THE MIDDLE:
http://forums.bimmerforums.com/forum...0&d=1375721108
http://forums.bimmerforums.com/forum...1&d=1375721111
http://forums.bimmerforums.com/forum...2&d=1375721115
