Hello all...I got a sample of a bulk solvent based tire and trim dressing that goes on WAY to glossy. Just wondering if it can be diluted down with water.
Thanks a bunch.
Printable View
Thanks a bunch.
What is the brand/chemical?
I know some dressings (Hyperdressing) are intended to be diluted, but those are water-based. I`d image something solvent based would be a little different.
Car Brite "Brite Shine". Sorry, I can not post links yet.
If I like it I will be using it on the cars at a couple of used car lots I do work for. I currently use a water based dressing with a matte look (which I like), but the dealers like a higher gloss and longer lasting product since the cars can site on the lot for extended periods of time.
If you dilute it with the same solvent that the product uses, you can potentially apply less product to the tire because the ratio of volatile solvent to shiny stuff goes up.
cut it with mineral spirts it will also make stay on the tire without sling also try to put it on with a spong
Quote:
Originally Posted by sparklescarwash
Perfect. I`ll give that a try. I have applied it with a wax applicator and it looked much better than with a foam tire applicator for some reason.
Where did you get solvent based dressing? VOC laws suck!
Is putting mineral spirits on rubber a good thing? I`d suggest a water based tire dressing.
Thinking the same thing. Would prolong use dry out the rubber?Quote:
Originally Posted by wannafbody
Quote:
Originally Posted by JPostal
Here`s your link:
Solvent Based, Water Based, Aerosol, Bumper & Trim Restorers | Dressings | Exterior Care | Car Brite
all solvent based tire dressings are usely cut with mineral spirts
