Help? You don't need any stinking help!
Having just purchased a used pontoon boat, I can really appreciate what you have done. I solved the above deck problems with all new carpet and all new seats. I hope to get the pontoons looking like aluminum later this fall. I most certainly don`t expect to get them looking like chrome. That is truly an amazing job of polishing!
Re: Pontoon Boat Help Needed
Quote:
Originally posted by Rob Preston
I`m looking for suggestions around the front end of this thing. I`ve tried using an 8 and 6-inch pad in this area and is vary difficult to do. Is there another tool out there that you guys use to get into tight areas? Thank you in advance.
Would a dremel type tool or a flexible shaft with a buffing wheel that uses the edge to do the polishing fit in the areas you are trying to reach? Maybe even an electric drill with one of those wheels that just goes in the chuck. Most likely, what you have left to do is a pretty small area, right?
Serves you right for doing such a terrific job on the rest of the pontoons.:D
