Please criticize my detail!
Hi everyone, i`ve been lurking here for a while, and what a great group! I need a little advice as to if this is the best approach to my vehicle...
My 98 cobra for the first winter had to spend quite a bit of time outside, and was daily driven. As a result, i have the usual scuffs, light scratches, chips, etc. In any case, I`d like to try and get this back to looking good, and i`m wondering how the following system looks to you!
-touch up small chips w/ factory ford touchup, then use langka to smooth
-wash with dawn
-claybar vehicle, z-18 with z-7 lubricant
-wash with dawn
-meguiars medium cut cleaner #M-0116 (#1) only on areas with scuffs and deeper scratches, used with yellow polish pad and PC7424.
-meguars DACP #M-8332 on entire vehicle used with yellow polish pad and PC7424.
-meguiars Swirl Remover #M-0916 (#9) on entire vehicle used with yellow polish pad and PC7424.
-wash with dawn
-zaino z-5 polish w/ zfx additive/accelerator, used with soft finish pad and PC7424. repeat 1-2 times as needed, wait 24 hours between coats.
-zaino z-2 polish, w/ zfx additive/accelerator, used with soft finish pad and PC7424. repeat 3-4 times as needed, no need to wait between coats.
After all this, i`m going to get a clearbra on the front, to help avoid at least some of the rockchips that come from all the sand and gravel on the road.
How does all this look? I`m particularly concerned about fillers, but none of the megs products i listed say that they contain them...
Any comments or criticisms are welcome - thanks in advance!
