my detaling plan(need input)
Hi all, i`ve been reading this forum for a while now, but hadn`t participated yet. My name is Mark, and i`m a car buff too( no pun intended:--).
I want to detail mine and my girlfriend`s in about 2 weeks time. I gathered a lot of info from this forum as well as *detail city* forums as well. I have a friend in the field whom i went to so i could verify if my theoritical plan and technique was ok.........he told me it was indeed fine. As i said i have gathered and printed a lot from this forum, and highlighted key points. I don`t want to use an orbital buffer, but instead will use a rotary buffer(makita), beginning with the softest polish and foam pad(3ms foam finishing pad) seting the speed to 1k, since i`m not experienced with a rotary. I have practiced on the dryer and washer, in order to get the feel of the rotary( so far so good). Now i will outline my paln for my car, and i`d like to guys to correct me if mistaken somewhere along the line.
here it goes :
1. dawn wash
2. claying
3. dawn wash(or car wash) to remove residue from claying.
4. polish(round 2000 to begin with since my car is a black 2000 toyota corolla......i want to use a polish with no fillers in it, so i can correct the slight imperfections on the paint.) My paint is in good condition i have to say, so i i guess it`s much better to avoid medium compound, and since i`m not experiences with a buffer, i prefer to go easy on it.
5. swirl remover ?? i wonder if i should use one, as some say if you have a decent polish, it should also remove swirls(wonder if it is true), again i`d like to use something that doesnt hide swirls, but rather correct em. I have noticed that it`s hard to keep the buffer constantly flat on the surface, so i give it about a 15 degree angle, and keep that angle steady. With regards to the holding of the buffer, i have found left hand on the handle along with a right underhand grip on the housing of the buffer, provides me with the most stability moving it. I move it from right to left, at a moderate rate of speed, but i really keep it moving all the time, i never hold it still on one spot. I have also found that either spritzing the pad or the surface to be buffed, allows one to buff longer, and provides me with more stability in holding the buffer in it`s 15 degree angle. As mentioned above i will be using 3m`s foam finishing pad, beginning with a polish for dark colored cars( my girlfriend`s car is red, and mine black) with regards to black cars, with a buffer and my being a beginner, i`m aware i will have to be careful, and i think being meticulous as i am, will be able to go through it all with good results. Iwill cover plastic moldings, winshield wipers, and more if i need to. I will not use large quantities of products.......i know more isnt better.......i will also buff 2x2 feet areas at a time, like most advise here.
Then i plan on using zaino products(z2,z6,zfx,z7) as i live in a humid area.
I have printed and read the zaino procedure, dawn wash, claying, wash again, then z2+zfx......then z6 and then back to the z2 step with a z6 coat in between each coat of z2.................of course im fully aware that the surface has to be prepped properly, in order for the final result to be satisfying. My car doesn`t have losts of minor scratches though it has a few, but considering it is black, id say it s decent. I also has some that wont go away, so im not even considering removing em, but rather only make em less apparent.
Im pretty clear about the dawn wash and claying which im going to do first, but as far polishing and swirl removal, im not that clear........i mean, is it the norm to polish then use a swirl remover, or the polish on its won will do the job ? As to my girlfriend`s car it was re-painted one and a half year ago(red car), so i`ll go very very easy on it, since the paint isn`t the original one.
I will start by flat surfaces, like the roof, trunk, hood, then side panels.
do you guys use the buffer on painted bumpers ? or you do it by hand ?
The hood, and roof, and trunk, and doors(half of it at least) are easy surfaces to work on, but what about the rocker panels and lower half of doors, which are narrow and not as obvious as other parts ? do you do em too, and if so, what kink of pattern do you follow using the rotary ? im puzzled about em, i admit.
I will also use micro fibers cloth, as wipers after the buffing job is done, and white 100% cotton towels to remove zaino sealant.
I`m sorry if the above is a bit unstitched, it`s cause halfway through my post, i had visitors, and resumed hours afterwards.
P.S. am i making a good decision to use zaino, or i`d be better off using others less expensive products ? most of you have wayyy more experience than i do, so rest assured your comments will count.
for interior, moldings, what should i use ? all i know is i wont use silicone based products, that s for sure...........i was thinking of buying all of zaino line of most of em.......tire cleaners, plastic/vinyl stuff etc.... but it gets pretty expensive and im not yet convinced they will be that much better than others on the market could be......correct me if mistaken here.
Thanks in advance, as the post is a lenghty one.
