I`ve got that musty smell coming from my A/C on my `04 G35 Sedan.
I`ve gotten some Einszett Klima-Cleaner and need to insert the dispersal tube into the fresh air intake (FAI). However, I can`t figure out where that is! I`ve been looking all over the web for info on where I can get to the FAI. But, I can`t find anything on it.
In the pic below of the engine bay, is the cirlced area the FAI? Is so, how to I open that panel to get the tube for the Klima-Cleaner down in there?
http://www.worthingtonweld.com/DETAI...edan_75dpi.jpg
Thanks!
Ian
You might have better luck at a g35 forum. I know there`s a bunch because i had to look up some stuff for my dad`s g35 coupe a couple months back.
Here`s a link to an old thread by someone affiliated with 1Z who explains his method for treating the evaporator. http://autopia.org/forum/detailing-p...ner-scent.html
It appears you can spray the Klima-Cleaner in thru either the center dash vents and/or thru the fresh air intake vents on the outside of the vehicle as you have circled in your picture. Just make sure to remove any cabin filter before application and always replace it with a new filter. You also need to check the ac drain and make sure it isn`t plugged with any debris or you`ll find the same problem returning again.
