Hello
Im brand new to this sight and not quite sure if im in the proper section to ask questions..however im looking for product & suggestions for better ways to clean the plastic windows on rag-tops.
Printable View
Hello
Any quality auto parts/products store should carry a type of plastic polish. Personally I think you will find a lot of board members here recommending Meguiars PlastX (www.Meguiars.com) Hope it works out for you.
Shaun
Thanks shaun
cheers...RTM
Platx works well, but it cannot correct everything, depending on how bad it is. I use 1500 grit sandpaper to start, then Meg`s diamond cut cleaner, then plastx to finalize the process. That`s how I do headlights, which is similar to ragtop backlights. Also, be sure to use a window cleaner with no ammonia, like Stoner`s Invisible Glass, to extend the service life of your window(s). Same goes for tinted windows.
plastX is a great product as said above. I use it on the head/taillights of the tC every couple of months to keep everything clear and shiney
