I thought I would share this product with everyone to get the wheels turning on the latest & greatest HD Car Care product to be hitting the market very soon. Several of the nation`s top professional paint correction specialists have been beta testing this exciting new product and have given their blessing on it`s overall performance. Please stay tuned for the official release coming soon.
Here is a small demonstration of what HD Adapt is capable of doing. 2000 grit scratches (hand sanded) via Micro Fiber cutting pad. 1 Step. No final polishing. No protectant applied.
http://youtu.be/mfU-SSfZCwE
<span style="font-size:12px;">HD ADAPT with Adaptive Abrasive Technology
Multi-Surface Adaptive Compounding Polish
Introducing the industry’s 1st compounding polish with Adaptive Abrasive Technology (AAT). HD ADAPT uses specially engineered micro abrasives that effortlessly adapt to correct, polish and restore perfection to virtually any hard surface such as modern base-coat clear-coat paint systems, older single stage lacquer paint, non-plated metals, glass, Lexan, gelcoat & plastic. Designed to produce exceptional results when used with your choice of machine polisher such as rotary, dual action and/or forced rotation. Can be used with foam, wool or microfiber correction and polishing pads.
HD ADAPT uses a combination of unique abrasive technologies that increases the efficiency and effectiveness of the buffing cycle by using both chemical and mechanical compounds that allows the user to quickly level defects while at the same time producing excellent gloss & clarity to virtually any surface. This specialized lubricant and cutting system enables the user to adapt to any type of polishing machine or polishing pad to not only quickly level away defects, but also produce a fine polished result.
HD ADAPT’s unique abrasives are designed to quickly level away heavy defects while leaving little to no residual micro-marring in one easy step. Rest assured knowing that HD ADAPT (when used as directed) will not fill or conceal your true finish. Easily wipes from the surface while not creating any troublesome dust, buildup or oily mess behind. Perfect choice for mobile detailers, paint correction experts, body shops, precious metal workers, car washes, dealerships and/or enthusiast car care aficionados who prefer to keep their product choices simplified. Restore and polish automotive paint, boats, aircraft, RVs, aluminum, brass, gold, silver, headlights, cymbals and much more. VOC compliant formula will not produce any harmful airborne particles that will contaminate sensitive paint shops or the earth’s environment. Safe for fresh paint. Contains no wax, silicone or fillers.
<span style="color:#FF0000;">Directions:
Shake Well Before Use. Use the foam, wool or microfiber pad of your choice tailoring your pad selection to the desired task. Apply 6-8 pea sized drops to the pad for initial priming and work within a 2’ by 2’ area. Use moderate to firm pressure, letting the machine, pad and HD ADAPT do all the hard work. For optimal results use very slow arm movement to allow HD APAPT to chemically and mechanically act with the surface. Use cross-hatched passes (up & down / side to side) overlapping each pass by approximately 50%. Repeat as necessary. To reach optimal gloss and defect-free finish, follow-up with a finishing pad as needed. After each pass, clean pads with compressed air, pad spur or your choice of cleaning tool. Follow up with 3-4 drops for additional passes cleaning your pad after each pass. Swap out to fresh pads often.
<span style="color:#FF0000;">Speed:
**Optimal Rotary Buffer range of 1000-1800 RPM.
**Dual Action Orbital between 4500-6000 OPM.
For further instructions and tips watch the instructional online videos at 3D International, LLC
