I`m getting ready to do my garage floor and I`m interested in getting flake epoxy installed.
Should I add a bit of non-slip grit so it`s not "slippery when wet"?
Any feedback or thoughts would be appreciated.
Printable View
Definitely yes! I did it without once and not sure what I was thinking.
Ron
I was thinking something along this line in White/Black/Grey and a touch of burnt orange
http://www.monkeybarsjax.com/uploads...35200_orig.jpg
I posted a few decent links here:
http://www.autopia.org/forum/car-det...ml#post1525845
You definitely want to do your homework. Garage journal has a ton of info. I personally went without the non slip but use a lot of flakes, it added a good bit of texture but is still pretty easy to clean.
Quote:
Originally Posted by Dan
I do not want to ride onto the epoxy and have any problems with it being slippery. I`m looking forward to have a "clean" work floor.
The main reason I`m thinking about adding non-slip powder to the mix is when riding the motorcycles into the garage from the rain.
http://www.garage-restoration.com/im...0004290276.jpg
As Dan mentioned , the garage journal forum has reviewd and discussed any type of coating on the market. They have a ton of info available. If it`s not on their then it hasn`t been made yet.
Quote:
Originally Posted by Paul Sparks
Excellent...Thank you Dan...Many thanks for the lead...it`s kinda a do it once do it right project.
Quote:
Originally Posted by merlinii
What did you end up doing? Before after shots?
I did a lot of research on "The Garage Journal" and went with Sherwin Willams epoxies with a custom color flakes blend. I added some fine ground glass to the first coat of clear. the final product wound up smooth enough to mop or hose down and hit with a leaf blower yet coarse enough to ride motorcycles into during pouring rain and not slip.
Quote:
Originally Posted by Aaronz
Here is a before shot.
http://i215.photobucket.com/albums/c...ge/Garage1.jpg
Painted the walls black and grey/silver with a premium exterior paint (water and mildew resistant)
http://i215.photobucket.com/albums/c...ge/Garage5.jpg
http://i215.photobucket.com/albums/c...ge/Garage9.jpg
The concrete floor was ground, sanded and any cracks filled.
http://i215.photobucket.com/albums/c...e/Garage10.jpg
While I was at it I also did the driveway.
http://i215.photobucket.com/albums/c...e/Garage13.jpg
Then it was soaked and washed with muratic acid twice.
http://i215.photobucket.com/albums/c...e/Garage14.jpg
Diamond plate chair rail and close-able AC Vent added to air handler.
http://i215.photobucket.com/albums/c...e/Garage15.jpg
Driveway completed with two coats of sealer.
http://i215.photobucket.com/albums/c...e/Garage17.jpg
First coat of nickel epoxy
http://i215.photobucket.com/albums/c...e/Garage18.jpg
Color flakes added to second bottom coat.
http://i215.photobucket.com/albums/c...e/Garage19.jpg
Flakes being rolled (pressed) into the second coat.
http://i215.photobucket.com/albums/c...e/Garage21.jpg
Clear coat applied with light sprinkles of ground glass.
http://i215.photobucket.com/albums/c...e/Garage25.jpg
Top clear coat being applied. Needs 3-4 days to dry.
http://i215.photobucket.com/albums/c...e/Garage28.jpg
Wow, the driveway looks great. I see you went ground the surface as well, you should have no issues, at least inside. Definitely keep us up to date on the outside stuff, interested to see how it does long term.
Left side cabinets being installed
http://i215.photobucket.com/albums/c...e/Garage30.jpg
http://i215.photobucket.com/albums/c...e/Garage31.jpg
http://i215.photobucket.com/albums/c...e/Garage32.jpg
Both sides of the cabinets are now installed. I still need to take pics of the right side done.
This IS in the "Man Cave" section...so here`s a little "Photo Chopping" I did while I was waiting for the floor to dry.
http://i215.photobucket.com/albums/c...e/Garage24.jpg
Merlinii- Gee, you`ve been busy, that looks great!
