need help with these wheels
my friend recently bought a 2012 toyota tundra and it came with 20 inch aftermarket wheels. he recently got back from hunting out of state and he said there was lots of snow where he was at.
we cleaned up his truck today but there is still something on the wheels, i dont know if its pitting (never seen it first hand before) or what
i cleaned the wheels with plenty of sonax full effect and a daytona speedmaster brush but these goldish spots still remain
dirty
http://i1170.photobucket.com/albums/...pse70f83a5.jpg
clean-er
http://i1170.photobucket.com/albums/...ps96021a18.jpg
up close
http://i1170.photobucket.com/albums/...ps811ef1d4.jpg
http://i1170.photobucket.com/albums/...psa33305b8.jpg
he called me earlier and said put some windex on it and rubbed it with a towel and some of it was coming off. i haven`t seen it since he did this but im going to look at it in the morning before work. i told him to hold off on the windex and i would post up on here and see if we can figure out a better way
it looks like rust but could that even happen in a week from being in the snow? he said these wheels were not like this when he purchased the truck
i`ve never seen this before and i didn`t want to get too aggressive with it before asking
think this will come off with 0000 steel wool?
thanks in advance
Re: need help with these wheels
Looks like rust to me but I doubt it`s actually the wheel. It`s probably brake dust rusting. Does he have access to any clay or metal polish?
I would first test to see if these wheels are clear coated. My thought is they are. I would then try any polish that is safe for clear coated wheels or even m205 and see what that does. This may be clear coat failure on the wheel that has now came through worse because it was in the snow.
I would agree that it also looks like clear coat failure to me. I also would try a polish on it also and see if that takes care of it.
bringing clay, 105,205 chrome polish and optiseal (in case any of the before items work)
oh and my da drill adapter and a buff ball
gonna see what those do and post up after 10 when im at the shop
Clay first an some heavy apc, I`m amazed at how much it takes off.
had enough time to work on one wheel today before work.
clay, mothers chrome polish via ccs orange hand pad, and some elbow grease
went from this
http://i1170.photobucket.com/albums/...psa00dc8ad.jpg
to this
http://i1170.photobucket.com/albums/...ps76b17a34.jpg
this
http://i1170.photobucket.com/albums/...ps884efdc1.jpg
to this
http://i1170.photobucket.com/albums/...ps2411ff2b.jpg
drastic improvement but still not where it should be
http://i1170.photobucket.com/albums/...psee7cf77b.jpg
http://i1170.photobucket.com/albums/...psf5b08e7b.jpg
http://i1170.photobucket.com/albums/...ps8af3bcd7.jpg
dirty claybar
http://i1170.photobucket.com/albums/...ps4ba409ef.jpg
he said he would pick up a mini powerball (the larger one i had did not fit in the deep dish) and give it to me, so hopefully that will work a little better than via hand
after claying the wheel twice it smoothed most of the wheel out but i think whatever that is on there has eaten into the surface a little
thinking about hitting it with mild then strong apc and a toothbrush tomorrow and seeing how that works. he wanted to use simple green, but i said NO.
SG is fine, just dilute it. It`s all ratio`s IMO.
Quote:
Originally Posted by
The Driver
i have some 1:5 already diluted and a little 1:10 as well. just always thought that was bad for chrome
should i dilute it more?
SG is not good for uncoated aluminum. It`s okay for chrome as far as I remember but I don`t think it will help in this situation either.
512detail
Chrome is TOUGH. Aluminum not so much. Just a trick, I`ve always used cleaners on the strong side but I never let stuff sit. Wipe it down an get it off. I`m sure 1/10 is fine, if it`s still tough jump to 1/5.
im pretty sure its chrome..if it was aluminum when i used the chrome polish the applicator would have turned dark, right?
or is that just for bare aluminum?
Iron Xor Wolf`s Deironizer (my preference and cheaper.) would have made quick work of those. Pick up some it makes doing really bad rims just as easy as doing nice ones which always sucks in general
0inDetail0
i have a bottle of iron x. i will try that tomorrow
its almost gone but i think i might have enough to do all four
Hang in there, looks like you are getting there. Good progress so far.
