I have a ford sport-trac truck and I have black vinyl around the wheel wells and bumpers. Recently I got car wax on there and I dont know how to remove it. Can anybody help? thanx
Printable View
Lots of ways.
A mild APC and a medium bristled brush.
Poorboy`s Trim Restorer works well if you work it in with a brush.
Some guys like using the Magic Eraser from Mr. Clean.
Some guys even like using peanut butter.:crazy:
I also sell a product called the Wax Blaster that is specifically for doing this.
:cheers:
Looks like Troy has got you covered! :bigups
Yeah, I can`t think of anything more to add; except to wonder if there are still people out there doing the peanut butter thing. :)
just remember that sometimes the solvents in a wax or polish if left on the trim too long will discolor the trim and the only real fix will be a paint or dye.
I`ve seen people use permanent markers to touch up spots and some that end up painting the trim.
The restorers and other products sometimes end up being a temporary solution that will need to be repeated often to maintain the look.
Peanut Butter should do the trick, But I`ll bring the jam........:cheers:
Back to Black is a good option if one has been remiss in his application methods. I know this because when I first started detailing the old Black truck of mine using a PC for applying everything from paste to liquids I know that I was a little to liberal with the pad and polish. What the heck...It got applied to everything to many times. With Back to Black and a regular regemine of Trim Restore I was able to keep the white haze from improper application at bay. Wish I had that old back truck back.:mad::wall
WD-40 also works. Spary it on a rag and rub it on the trim.
I think there are two things that need to happen...one is to clean the old wax out...then protect it.
For me I`ve not seen one product do both as well as trim restore from Steve.
Troy I`ve not used the wax blaster is that a similar product to TR?
I have used Mr.Clean Magic Eraser sponge to get some wax off my trim before. It works great. I have also used Griots dried wax remover with some sucess.
Duragloss wax eraser
peanut butter worked great on my door handles...applied with a toothbrush and let sit for 10 minutes and hosed off.They look new,didn`t even have to bust out my trim restorer
