Used PBs Pro Polish by hand with a MF applicator and an Ultimate wipe for removal. Finished with a coat of AIO.
Before
http://www.detailcity.org/gallery/da...m/DSC01516.JPG
After
http://www.detailcity.org/gallery/da...m/DSC01520.JPG
Printable View
Before
After
A couple of more pics that turned out.
http://www.detailcity.org/gallery/da...m/DSC01515.JPG
http://www.detailcity.org/gallery/da...m/DSC01522.JPG
I was curious how Pro Polish would do. Worked pretty good.
Nice work.
Pro Polish makes quick work out of many residues.
Nice job.
My bosses G35 has the same problem only worse.
Pretty dishearteneing considedering these cars are only 3-4 years only
"J"
Mine had similar issues, SSR1 was my solution. :)
What causes this to happen?
Not sure. Seems like a residue more than actual plastic clouding or haze. What I mean is there is a yellowish tint left on the applicator. In addition Pro Polish is a chemical cleaner so no abrasives were used to remove the haze. If the haze wouldn`t have been removed with the cleaner, then an abrasive would be required. Seems like a common problem on the G35.
Thanks for the replies. Pro Polish is a product I very seldom use. I`m trying to find more uses for it.
I have the same problem on my chrysler minivan Im going to give PP a try will take pictures I thought I might have to use 2000G wet/dry paper then polish thanks for the tip:)
Good luck with that. If you need something abrasive give Meguiar`s PlastX a try.
The key is to either reguarly polish/seal these headlights, or have them clearbra`d...I went for the latter.
There are two ways that this can happen. There is interior fading, which is caused by a leak in the seal, water entering and the evaporation process leaving the residue and film from the minerals are left on the interior. Then there is exterior fading, which is baisically a UV issue yellowing and ruining the exterior finish of the lamp due to sunlight, and once again the water. Big PITA on many cars. What you can often do with an exterior issue is take the lamp off and take it down to a local body shop. They will baisically wet sand it down and shoot a new layer of clean....presto....looks like new! I will attach some pics of before and after of my headlamps on my contour SVT which I had this done to! Sorry for the lengthy response all!Quote:
Originally Posted by 04 RED LARIAT
Be careful not to use anything carnuba, as this has been shown to cause yellowing as well.Quote:
Originally Posted by G35stilez
OOOO! AAAAH!!
Nice fix!
I used PP on a Grand Prix set of headlamps and got great results quickly (and by hand).
Now I just have to find something to work on headlamps that have "flaked." Guess I may have to look at "power-assisted persuasion." :(
I use a high speed polisher on customer cars and charge $40 for headlight restoration. Takes all of 5 minutes each, unless they watch, then it takes 15 minutes a side:)
As stated above, go with a clear bra on them. If you are just worried about the headlights, you can buy just those pieces. I had the entire front of my G35 done and understand that it is pretty expensive. However, the peace of mind is great.
-GT
