Anyone have a door guard on their garage wall to prevent the door from opening into the wall?
I`m looking for something and need a recommendation. I`d prefer something like a soft rubber but most of the ones I have seen are hard plastic.
Printable View
If I remember AG did have something like that
Take a quick look at there store site
I use a pool noodle cut in half...only .99 each. And you can use double sided tape to install or just screw it to the studs.
Sent from my iPhone using Tapatalkhttp://uploads.tapatalk-cdn.com/2016...4f55af60e6.png
Lol, me too....that`s why I used double sided tape, but I`d probably use liquid nail next time. This was just a random picture from Pinterest.
I used plumbing pipe insulation (same as the pool noodles), mounted them onto 1x2 wood strips, using zip-ties, then screwed the wood, to the wall. No problem with door damage, now.............
Wall Mounted Door Guards, Set of 2 - Griot`s Garage
Try this from Griots
My car always sits in the same spot in the garage so the door is always in the same spot.
Got s couple of Gel wrist rests for keyboards from the discount place and screwed them to the wall where the edge of the door would hit
M
I feel extremely lucky on this one. If my vehicles are centered in any of the bays I have at least 4 feet between an open door and a wall. I actually changed floor plans when I built this in order to insure that I didn`t run into issues somewhere down the road.
I feel like so many garages built these days are built just to the minimum standards. So with most "2 car" garages you better not plan on putting 2 cars in there or else you may have to climb in and out of the windows since there`s not much room for doors to open. This is especially true if you have 2 coupes in the garage!
Sent from my XT1031 using Tapatalk
Yep, and especially if you have young kids getting in and out is a pain. Its actually the main reason my wife traded in her Pathfinder for a minivan. Sliding doors are soooo much easier. We practically had to pull out of the garage before to load everyone. Not great in Ohio 4-5 months out of the year.
Something else you can use is garage door threshold. Call your local garage door company and see if they have any scraps laying around. Never know, might get lucky.
The pool noodle is a great idea which I have used my self in a pinch (used string for a quick solution in that scenario). In my current situation I have a work bench on my wife`s side where I have added foam (cut from the end cap used to ship a laptop) on the corner to protect from any accidental contact. She would contact the foam before contacting the wall so I didn`t need to add padding there. I usually save foam pieces that I feel might come in handy for such things in the future.
This is the issue I have in our garage (contact with my car which is on my wife`s passenger side). There is ample room between our two cars but she has still managed to leave a couple small dings in my car from opening the rear door too wide to get our son out of the car. After the last PDR visit I bought two pairs of these:
Magnetic Car Door Protection, Car Door Protectors, Car Door Guards, Prevent Car Door Dings and Dents
I use them in the garage but also when parking in a lot with other vehicles. You just need to be careful when installing and removing so you don`t cause any marring. The 3 pads (contact points) on each bar are soft silicone-like rubber held on by relatively strong magnets within.
