Re: Odd Polishing Experience
Probably done at different times and totally different clear coat used on certain panels (possible damage or root repairs in fenders). I am sure a paint expert will no 100x more then me but I am guessing there are at
least a few companies making clear coats and each with a few formulations making for dozens of different clear coats now not to mention changes over the years depending on the date it was done. Logistical and practical nightmare for you trying to polish it.
Best guess would be do a test spots on every panel, even then hope they didnt blend out the clear on one the quarter or fender panels.
I wouldn`t be surprised at all if you aren`t dealing with two types of paint. A few months back I did a correction on a black 2007 Honda Accord. I could tell by my paint thickness readings that there were several areas that had been repaired and repainted. This paint was a real challenge. What worked well on the hood didn`t work well on the doors and quarter panels which seemed to have much softer paint. I tried all types of combinations and finally had to finish those areas with CG Black Light on a Black Finishing Pad. It was a royal pain in the butt.
Right, this is one part of why repainted vehicles can be a huge PIA.
Just have to see what products work best on each "generation" of paint. Hopefully something will finish without the "filmy result" issue.
This is exactly why I wouldn`t detail a certain Porsche my pal Bob used to own ;)
As everybody said. Different paints/clears/times
Pics of car required
