One Glossy Kitty - 2015 Challenger Hellcat - CQuartz Finest - CQuartz DLUX - Attention to Detailing Peoria
This vehicle was brought to us for a proper new car prep. The owner was very interested in having excellent protection applied to all painted surfaces and wheels. The paint was thoroughly cleaned, spot corrected, polished, and coated with 2 coats of CQuartz Finest. The wheels were removed and thoroughly cleaned inside and out; they were then coated with CQuartz DLUX. While we had the wheels off, the brake calipers were cleaned & coated, wheel wells were cleaned, and suspension was cleaned. The interior was lightly cleaned as well. When it was all said and done, this car looked amazing!
Process
Tires: Tuf Shine Tire Cleaner & Brush
Wheels: Sonax Full Effect & Various Brushes
Wash: Citrus Wash
Decontaminate: CarPro IronX, Tarminator, Nanoskin Speed Prep Mitt w/ Nanoskin Glide
Paint Thickness Readings Taken
Trim & Areas of concern taped with CarPro Masking Tape
Correction: Shine Supply Flat Top on Orange LC Foam via BOSS G21, Rupes LHR21 and 75e
Polish: Meguiar`s M205 on White LC Foam via BOSS G21, Rupes LHR21, and 75e
Coating Prep: CarPro Eraser
Paint Coating: CQuartz Finest
Wheel Coating: CQuartz DLUX
Caliper Coating: CQuartz DLUX
Tire Dressing: WaxAddicts Slick Spray Tyre Dressing
Glass: Meguiar`s D120
Interior: Vacuum, 303, D120
http://i76.photobucket.com/albums/j2...psparxedgr.jpg
As always, we began by cleaning the tires. There was a considerable amount of dirt and grime built up on the rubber.
http://i76.photobucket.com/albums/j2...ps71p9jl60.jpg
We continue repeated cleaning until the tires and brush remain clean which indicates no more dirt is being removed.
http://i76.photobucket.com/albums/j2...pshhzubfrq.jpg
Barrels were then cleaned as best as possible while the wheels were still mounted.
http://i76.photobucket.com/albums/j2...psa3iytpvz.jpg
Wheel faces were then cleaned.
http://i76.photobucket.com/albums/j2...pse2qz5rkg.jpg
The vehicle was then soaked in a thick layer of shampoo while I used a soft boar`s hair brush to clean all the cracks and crevices. The vehicle was then carefully washed and decontaminated.
http://i76.photobucket.com/albums/j2...psn9cid5h3.jpg
Tar was removed from all lower panels.
http://i76.photobucket.com/albums/j2...pswh4mnnbn.jpg
Once clean, the vehicle was then brought inside for inspection. Trim and areas of concern were taped off to avoid accidental damage while polishing. Defects were marked with small pieces of tape.
http://i76.photobucket.com/albums/j2...pszbruinjx.jpg
I then proceeded to make my way around the vehicle and spot correct as many defects as I could find, no matter how small. Some before and after shots.
http://i76.photobucket.com/albums/j2...pshstu4mxa.jpg
http://i76.photobucket.com/albums/j2...ps9t3rje3t.jpg
http://i76.photobucket.com/albums/j2...psh5ztqtob.jpg
http://i76.photobucket.com/albums/j2...psldl7kps5.jpg
http://i76.photobucket.com/albums/j2...ps1igiubah.jpg
http://i76.photobucket.com/albums/j2...pslirng1sn.jpg
http://i76.photobucket.com/albums/j2...psbnw4jdhw.jpg
http://i76.photobucket.com/albums/j2...psgzdsaaoh.jpg
http://i76.photobucket.com/albums/j2...psxb6wlujn.jpg
http://i76.photobucket.com/albums/j2...psbssknu8c.jpg
http://i76.photobucket.com/albums/j2...ps54mdaoor.jpg
http://i76.photobucket.com/albums/j2...psy2igqidv.jpg
http://i76.photobucket.com/albums/j2...psla6kslam.jpg
http://i76.photobucket.com/albums/j2...pstm4bwpfv.jpg
http://i76.photobucket.com/albums/j2...psnfaedprv.jpg
http://i76.photobucket.com/albums/j2...pst5ghskfu.jpg
Carefully removing wheels with protected wheel sockets.
http://i76.photobucket.com/albums/j2...pssk5adtne.jpg
Wheel well before.
http://i76.photobucket.com/albums/j2...psfhcoseig.jpg
Wheel well after.
http://i76.photobucket.com/albums/j2...psl5t1pskb.jpg
Wheel barrel before thorough cleaning.
http://i76.photobucket.com/albums/j2...ps5rdduqpu.jpg
Wheel barrel after cleaning and coating.
http://i76.photobucket.com/albums/j2...psutrbrqgs.jpg
Wheel faces thoroughly cleaned.
http://i76.photobucket.com/albums/j2...pstjadvhlb.jpg
http://i76.photobucket.com/albums/j2...pspyrdv0n0.jpg
Wheel well before.
http://i76.photobucket.com/albums/j2...ps9cm4l0ts.jpg
Wheel well after.
http://i76.photobucket.com/albums/j2...psmzf92zxi.jpg
Calipers were then coated with CQuartz for added protection
http://i76.photobucket.com/albums/j2...psvwqqtsiq.jpg
Applying CQuartz Finest.
http://i76.photobucket.com/albums/j2...psxybobovl.jpg
Baking CQuartz Finest with infrared curing lamps.
http://i76.photobucket.com/albums/j2...psnwjt1x3h.jpg
Wheels looked amazing after being coated
http://i76.photobucket.com/albums/j2...ps2tdtgd43.jpg
Re: One Glossy Kitty - 2015 Challenger Hellcat - CQuartz Finest - CQuartz DLUX - Attention to Detailing Peoria
Excellent work! Love all the little things you did to make this car right. Did you coat the fender wells or just dress them?
Awesome work Jeff !!! What a beast :drool::drool::drool:
Beautiful as always!
And he gave you the red key........ :D
Way better than off the lot! Now only if cars could be prepped this well when you do buy something new. Great work again.
Your attention to detailing never ceases to impress Zach. Beautiful work!
Great work as always, Zach!
Thanks everyone!!
Quote:
Originally Posted by
XxBoostinxX
Wheel wells were simply cleaned... no dressing, coating, or anything applied to them to spruce them up. Keep in mind the car is basically brand new so the plastic is still in very good shape once cleaned.
Great work Zach! Really like those wheels over the matte black ones! :)
Thanks! These wheels really popped on this car.... we loved them, too!
I`m doing the exact same car in Saturday. Can`t wait.
