I just wanted input on whether to do the washer mod on my Rupes 15 and Mini 75e. Does it really make that much improvement if you do?
I read you can use a backing plate spacer used on a PC.
Printable View
I have them on all my rupes except the mini for obvious reasons. It definitely helps when doing heavy cutting at higher speeds.
IIRC, I don`t think you can do the washer mod on the mini. The backing plate isn`t "free" on the Duetto and mini like the Rupes 15 and 21.
Yes!
I agree,yes!
Yes !!! Love it on my 21 !!
Definitely. ...makes a big difference
I guess that will be a go then.
Thanks everyone!
Absolutely. The difference is night and day
Has anyone inspected their backing plate after the KB washer mod.
It looks like my arbor rotated 90 degrees. I`ve only had the 21 for a week or so and did a hood at speed 6.
Has anyone else damaged their plate with the mod?
http://www.autopia.org/forums/attach...id=28028&stc=1
Just did mine on my 15, will have to use it a bit then check it.
I wish KB would comment on this, maybe he can shed some light.
NO! Go Kamakaze plate if you think the washer works well!
