Presidential Detailed: 2001 Mercedes Benz SLK230 KBRM :)
With all the Kevin Brown craziness/hype going on, I thought I would make a nice thread showcasing the results you can achieve using his method using a rotary which is slightly different from his method with the foam pads. I have been working with Kevin for the past couple weeks trying to perfect this method, now I just need to get a DA so I can finish it off! For some reason I have not been able to get a ZERO hologram finish using my rotary and M205 or M105 on a finishing pad. I spoke with both Kevin Brown and Jason Rose today on the phone, thanks to Kevin once again for the contact. The first thing Jason pointed out was that I was not using the new Soft-Buff 2.0 Finishing pad which M205 was specifically designed around and apparently does not play well with others UNLIKE M105. Not even other Megs pads, I was using both the Soft-Buff(non- 2.0) Yellow and Tan and could not get the desired results I was looking for. I even tried both M105/205 on black Lake Country Finishing pads with even worse results. I was running out of time to experiment with my new bottle of 205, so I ended up finishing with 3m Ultrafina on a 3M UK Finishing Pad. I will be purchasing some more 2.0 pads and give it another shot. Once I get my DA, I am positive I will have a better experience as well. WARNING: If you are not open to learning new skills, please press the back button on your browser. :swirly:
What I have learned:
-Kevin Brown IS THE MAN!
-The KB method DOES INDEED WORK! AND VERY WELL!
-You can almost get LSP ready results even using a heavy wool pad, of course this is dependent upon the paint, but even on the softer paints with a foam cutting pad you can achieve great cut and an even better finish!
(my new favorite is the Megs Soft-Buff 2.0 Burgandy FOAM)
-M205 apparently is pad temper-mental. Im going to give it another go with the new pads and hopefully Ill get me G110 this week as well!
-Kevin Brown IS THE MAN! :)
This is how the car looked when it arrived..I got this 2001 Mercedes SLK230 two days ago, and we`ll just say it wasn`t in great shape...AT ALL! In fact, the paint(specifically the trunk)was in probably the worse shape I had seen. I was only hoping and praying M105 would be able to tackle it even using the KB method.
http://i20.photobucket.com/albums/b2...0/IMG_8415.jpg
http://i20.photobucket.com/albums/b2...0/IMG_8386.jpg
http://i20.photobucket.com/albums/b2...0/IMG_8390.jpg
http://i20.photobucket.com/albums/b2...0/IMG_8391.jpg
http://i20.photobucket.com/albums/b2...0/IMG_8392.jpg
http://i20.photobucket.com/albums/b2...0/IMG_8393.jpg
http://i20.photobucket.com/albums/b2...0/IMG_8418.jpg
http://i20.photobucket.com/albums/b2...0/IMG_8423.jpg
http://i20.photobucket.com/albums/b2...0/IMG_8421.jpg
http://i20.photobucket.com/albums/b2...0/IMG_8416.jpg
http://i20.photobucket.com/albums/b2...0/IMG_8389.jpg
http://i20.photobucket.com/albums/b2...0/IMG_8414.jpg
http://i20.photobucket.com/albums/b2...0/IMG_8383.jpg
http://i20.photobucket.com/albums/b2...0/IMG_8384.jpg
Re: Presidential Detailed: 2001 Mercedes Benz SLK230 KBRM :)
:har: Im guessing at this point your asking yourself, THATS IT?!?
Well of course not! I saved the good ones for its own post! :dance
This is what I was working with on the trunk. Apparently the owner took some sort of "rocks in a bottle" compound by hand on a rag to try and remove some swirls, only putting some more MASSIVE swirls into the paint.
http://i20.photobucket.com/albums/b2...IMG_8385-1.jpg
http://i20.photobucket.com/albums/b2...0/IMG_8419.jpg
http://i20.photobucket.com/albums/b2...IMG_8387-1.jpg
http://i20.photobucket.com/albums/b2...IMG_8432-1.jpg
I never thought I was going to be able to correct this, and if I did I thought for sure there would be a significant amount of RIDS left over..WRONG.
The first combination I tried was M105 on a Megs Solo Yellow Wool using the instructions given to me by Kevin months ago. Just to avoid the confusion:
Quote:
Originally Posted by
Kevin Brown
Since you`ve already got the M105 and the wool pad (plus plenty of others)...
Go ahead and try this:
1. Prime the pad THOROUGHLY.
Rub it in with your hand. It`ll take a bit more than you`re used to applying.
2. Apply a bead of M105 to the surface, pull it in, and polish at low speed (1000 rpm).
Try 2-3 passes, or until the M105 is just starting to dry.
3. Using a fine mist, spray the surface with water.
Do not add additional product- Just re-polish with what`s already in the pad.
I think you`ll see a 50% improvement in the cut, but you`ll probably see an increase in swirling (it can be easily removed).
After trying this method (count it as one cycle), spur the wool pad (blow it clean with compressed air if you have it).
I won`t PROMISE a better result, but I am pretty sure you`re going to GET a better result.
Even in my first pass, I removed MOST of the heavy swirling but there were some RIDS still visible.
http://i20.photobucket.com/albums/b2...IMG_8431-1.jpg
I then decided to step it up to the Megs Solo Burgandy Wool just to see if the left over swirls were worth the chase. To my surprise, they were nearly COMPLETELY removed. After TWO passes with this combination, I got what I was looking for. PERFECTION!
These pictures were taken directly after M105/Burgandy Wool. There was no middle or finishing steps taken.
http://i20.photobucket.com/albums/b2...IMG_8436-1.jpg
http://i20.photobucket.com/albums/b2...0/IMG_8437.jpg
http://i20.photobucket.com/albums/b2...0/IMG_8440.jpg
http://i20.photobucket.com/albums/b2...0/IMG_8439.jpg
The same panel under the halogens..
http://i20.photobucket.com/albums/b2...0/IMG_8446.jpg
http://i20.photobucket.com/albums/b2...0/IMG_8445.jpg
http://i20.photobucket.com/albums/b2...0/IMG_8444.jpg
I removed the license plate so I could fully polish the entire trunk. Of course I cleaned up the mess from under the plates before polishing! :nana:
http://i20.photobucket.com/albums/b2...0/IMG_8503.jpg
Uncorrected.
http://i20.photobucket.com/albums/b2...0/IMG_8504.jpg
The trunk only required 1 pass be made with the burgandy wool/105.
http://i20.photobucket.com/albums/b2...0/IMG_8505.jpg
Here, you can see what my Menzerna bottles are getting used for these days. :nervous:
http://i20.photobucket.com/albums/b2...0/IMG_8506.jpg
A shot of M105 after polishing, ready for wipe-off.
http://i20.photobucket.com/albums/b2...0/IMG_8499.jpg
I forgot to add befores of the wheels, so Ill throw them in here before the final shots! :heelclick
http://i20.photobucket.com/albums/b2...0/IMG_8417.jpg
http://i20.photobucket.com/albums/b2...0/IMG_8424.jpg
http://i20.photobucket.com/albums/b2...0/IMG_8420.jpg
:cool::dcrules Looks good. Tell me, Is tha dye pealing on tha console?:cool::dcrules I noticed you didn`t post interior shot. Everyone of them I have ever seen peals..."Should have been a class action lawsuit on that."You also might want to consider coverin that license plate. We are all goodguys here. BUT...
Billy,:bow I am very impressed.
I used 105 for the first time today on a black Bentley Coupe. The 105 made short work out of removing imperfections that were giving me fits with everything I had tried previously. I don`t know why it takes me so long to try something new that other people are raving about.:hmmm:
Cloudy day but my handy Brinkman halogen gun showed me how well it turned out. The part that amazed me most was how aggressive it is but yet finishes way better than any other compound I have tried.:wow:
At least this old dog is willing to try new tricks, eventually.:redface:
Nice post and thanks for sharing it with us.:bigups
Troy@DetailCity
Thanks! Trust me, you havent even began to see what miracles 105/205 can perform! I am still in the process of switching over, which is why I just picked up a DA(G110) to compliment my Makita! :) Your on your way to becoming a Megs fanatic! haha!
There are lot`s of quality brands out there and I am a fan of a lot of them. Meguiar`s has always been a good choice for paint polishes to me.
I try not to favor one brand over another on here but I must admit, after trying the 105, I`m sure I will be reaching for it a lot more than my other compounds. If that makes me a Meguiar`s fanatic then I guess I might be on that road.:redface:
BTW. I don`t even have it for sale on my site.:redface:
I`m about to fix that though.;)
Maybe I missed it. But did you use a PC with this or a rotary. This is the reflects the condition of my ride, so I am looking at trying the same combo.
Oh by the way - absolutely beautiful job!!
Troy@DetailCity
Let me know when you do I want to order some :)
