http://thetoolwarehouse.net/shop/MAN132_TTW453.html
Some cheap stuff!! How was the sevice, products ?
Printable View
Quote:
Originally posted by prowler
Here`s the promised review (a little late, but . . .):
I used it on 3 cars:
PT Cruiser (4 years, 38,000 miles - brakes, trans, PS)
Prowler (4 years, 45,000 miles - brakes, trans, PS)
Windstar (8 years, 68,000 miles - brakes, PS)
brake fluid:
PT - light tan (half-quart)
Prowler - dark tan (half-quart)
Windstar - dark gray (actually, clear with black particles, full quart)
trans fluid:
PT - bright red, looked like new (3-1/2 quarts ATF+4)
Prowler - dark red, plenty of life left (4 quarts ATF+4)
PS fluid:
PT - light gray
prowler - medium gray
Windstar - dark red (Type "F" trans fluid)
Some commented that the 10 quart fluid extractor seemed like overkill, but I consider it to be one of my better tool purchases:
$56.05 for 10 quart Mity Vac: http://www.thetoolwarehouse.net/shop/MIT-7201.html
http://www.prowleronline.com/ubb/ima...s/mit-7201.jpg
$18.03 for the Brake Bleeding Accessory Package: http://www.thetoolwarehouse.net/shop/MIT-7205.html
http://www.prowleronline.com/ubb/ima...s/mit-7205.jpg
Conclusions:
1. The PT Cruiser is a lot easier on fluids than the prowler, I`ll probably only do brakes and trans every other year on the Cruiser.
2. A smaller extractor would work if you just want to do brakes, but the larger unit pays for itself (at least for me) since it can do the Chrysler tranny fluids without having to remove the tranny covers. It`s a 10-minute job, also quite clean.
3. The brake-bleed kit is a necessity, and the valve works for other purposes - it keeps the vacuum in the extractor to reduce pumping. For the front wheels, the extractor is up front and you can add brake fluid while you watch and control the flow. For the driver-rear wheel, you can watch the flow (and the color) but you have to run from front to back to shut it off. For the passenger rear, you`re working blind since you can`t see the flow in the hose while you`re at the master cylinder. Next time, I`m going to get a longer hose (plain old Home Depot type of item) so I can work the extractor from the front while I`m at the maste cylinder.
VERY happy with the purchase and performance.
