ok. i tried a little last night. i read how to from different places including posts here. i want to have a glass finish in the clear coat. it has the factory orange peel now.
while i was sanding, the paper and my makeshift sanding block would sort of create a vacuum due to the moisture. i didn`t have a lot of control and i was trying to be careful. i did scratch it up pretty well.
i used 2000 grit, 3m fine cut, #9, BF twins & QD.
while i was doing it, i was hoping that it wouldn`t look too different than the rest because it was a pita. now that it is done, i really like the improvement. my problem is that i am not going to continue unless i can find an easier way. plus, all the orange peel is not out. about 50% is gone. i will have to do the same thing on the same area to make it completely flat.
