Page 1 of 2 12 LastLast
Results 1 to 15 of 25
Hybrid View
  1. #1
    Join Date
    Jun 2015
    Posts
    16
    Post Thanks / Like
    Gloss-Coat, so much more then an "entry level" coating
    For the professional detailer Optimum Gloss-Coat is so much more than an entry level coating.
    Designed for maximum Gloss while providing protection against environmental damages for 2 years, Gloss-Coat is very durable hybrid Si02 coating. Other well liked attributes of Gloss-Coat are its ease of application, lack of installation complications such as the need for multiple layers, curing lamps and excessive waiting times before releasing to the consumer.
    Often shunned as a consumer coating, detailing professionals have good reason to look to Optimum’s Gloss-Coat to fill their customer’s coating needs.
    For the customer on a budget Gloss-Coat fills that role with pleasure. Costing less than $20 per application, and taking less time than any wax to apply(15-20 mins is typical) the detailer can give their customers a coating experience without the pro coating price tag. Think of Gloss-Coat as a “gateway” coating, it gets your customers hooked on the advantages of a coating for a very small investment, and when it comes time for a new car, they will be receptive to a higher level of coating. With its hybrid chemistry Gloss-Coat does not need periodic topping up of the resin to maintain its protection, unlike most Si02 coatings.
    For the customer on a short term lease Gloss-Coat fills that market need as well. Most short term leases are for commercial vehicles which do not benefit from the coverage of the typical pro coating warranty, Gloss-Coat will protect the vehicle for the term of the lease while keeping it cleaner, easier to maintain and reducing the risk of lease return fees due to paint damage.
    For that customer who is not a good fit for a long term coating due to their requirement of having a pristine vehicle for shows, or just personal pleasure, Gloss-Coat answers that need as well. We all have those customers that have a panic attack when they get the slightest of marks on their toy. While Opti-Coat Pro is the best coating in terms of protection, for that consumer the fact that the warranty is voided if the coating is polished makes it less interesting for them. For that “special” customer Gloss-Coat shines. Polish the customers paint to perfection as you would before the application of Opti-Coat Pro, apply Gloss-Coat, knowing that if something should happen to mar the paint, you can polish and re-apply. That same consumer can be put on a yearly maintenance schedule where unlike other Si02 coatings that have a resin reapplied to revive it, Gloss-Coat due to its low cost and ease of use can simply be reapplied as the customer sees fit. If the consumer want’s an even deeper gloss you can add a second layer of Gloss-Coat after 1 hour, and follow that up with Opti-Seal one hour later. This will rival the gloss of any pro coating, while providing great protection, and profits for you. It is not recommended to use more than 3 layers, and after 2 the difference is very minimal.
    For the consumer who enjoys maintaining their own vehicle Gloss-Coat can be topped with a wax or sealant if the consumer so desires, and as often as they want.
    Thanks Oldfordisbetter, newtows4thlaw thanked for this post
    Dislikes allenk4 disliked this post
  2. #2
    Join Date
    May 2015
    Posts
    17
    Post Thanks / Like
    Re: Gloss-Coat, so much more then an "entry level" coating
    It is good to have around here Yvan! Welcome
    Now, a few questions.
    1. It would be good to establish an updated guide of application of Gloss Coat (New Formula 2015), out there as there are several different opinions, there are still doubts about whether a pattern X to the first panel, how many drops of GlossCoat for each panel, time before wipe off.
    2. It is said that the microfiber suede stretching further the product, increasing the yield quantity per car, vs the foam applicator.
    3. The curing time of Gloss Coat is 1 hour, once cured if the car is left out 24/7, subject to changes in climate (heat and rain), to protect the cured until the 7th day for first wash, one layer of Opti Seal is sufficient?
    4. How much has chemical resistance against APC, degreasers, ferrous cleaners, etc.
    Thanks Yvan
    Likes Yvan Lacroix liked this post
  3. #3
    Join Date
    Jun 2015
    Posts
    16
    Post Thanks / Like
    Thank you
    1. I will endeavour to produce one in the next week or so.
    2. That`s a common perception, but is in fact false. The included applicator is actually very efficient in terms of transfer efficiency. Suede applicators are good as well, it really comes down to personal preference.
    3. The curing time before washing is 7 days, curing time before exposure to water is 8 hours. 1 hour after application, Optiseal can be applied. This accomplishes a few things. It protects the Gloss-coat while it`s curing from chemicals, it allows the car to be released to the customer immediately. It protects the coating against touchy-feely types.
    4. Chemical resistance of Gloss-coat isn`t that of Opti-Coat Pro, but it will resist all of Optimum`s cleaning chemicals due to Optimum`s strong synergy. Power Clean, FerreX, and MDR when used as directed, will not damage Gloss-coat.
    Quote Originally Posted by EG89 View Post
    Thanks Yvan
    Likes The Guz liked this post
  4. #4
    Join Date
    May 2015
    Posts
    17
    Post Thanks / Like
    Quote Originally Posted by Yvan Lacroix View Post
    Thank you
    Yvan,
    referred that application costs $ 20 per car, that few cc equivalent?
    One layer of OS protects the curing of Gloss Coat in car outside 24/7 against the rain for many days?, if is dirty or bird dropping should be done or how to clean?
  5. #5
    Join Date
    Jun 2015
    Posts
    16
    Post Thanks / Like
    The Opti-seal and Gloss-Coat will protect it against the bird dropping, Simply wash off with ONR.
    Average usage per car is 4cc so a 20cc syringe can yield 5 cars.
    Yvan,
  6. #6
    Join Date
    Jun 2015
    Posts
    16
    Post Thanks / Like
    Greg, the confusion was caused by me and my English as a second language misinterpretation of a meeting at Optimum. Optimum does not make it, simply Dr. G was consulted during the development of it. Uber is 100% an Autogeek product, and one they should be understandably proud of.
    Likes Robert DiTerlizzi liked this post
  7. #7
    Oldfordisbetter's Avatar
    Join Date
    Feb 2015
    Location
    PA
    Posts
    707
    Post Thanks / Like
    Nice write up, thank you Yvan.
    you seem to be a good guy to ask. How many CC of Gloss Coat does Optimum recommend for a 4 door sedan like a Ford Fusion. Coating wheel faces and paint. There is opinions out there from several cc`s to the whole syringe. Thanks
  8. #8
    Join Date
    Jun 2015
    Posts
    16
    Post Thanks / Like
    It depends on your prep and application method, but 4-6cc is average for that size. One thing to remember with Gloss-coat is that it bonds to and becomes one with the paint instead of sitting on the paint, so a "thick" coat is not needed.
    Quote Originally Posted by Oldfordisbetter View Post
  9. #9
    Join Date
    Mar 2013
    Location
    San Diego, CA
    Posts
    341
    Post Thanks / Like
    How did you come up with $20 per application?
    I would consider a Ford Fusion an average sized vehicle.
    The only size available on Autopia is 10cc....$59.99 before Shipping
    You should include that you are the Distributor for Optimum Polymer Technologies in Canada
    https://m.facebook.com/detailedbykyle?_rdr
    Likes Richie Carbone liked this post
    Thanks Richie Carbone thanked for this post
  10. #10
    Long Time Member GearHead_1's Avatar
    Join Date
    Jul 2003
    Location
    Utah
    Posts
    10,698
    Post Thanks / Like
    Quote Originally Posted by allenk4 View Post
    ...You should include that you are the Distributor for Optimum Polymer Technologies in Canada
    The comments are appropriate in this sub-forum. That said, Yvan it might be a good idea if you were to add a title under your username. Stopping in and introducing yourself would also be nice for those that don`t yet know you.
    A society willing to trade liberty for temporary security deserves neither and will lose both
    ΜΟΛΩΝ ΛΑΒΕ
    Likes Stokdgs, Yvan Lacroix, 4u2nvinmtl liked this post
  11. #11
    Join Date
    Jun 2015
    Posts
    16
    Post Thanks / Like
    It`s also available as a 20cc syringe for $99 that will cover 4-5 cars. While not listed in the Autopia store it is available to them, and if there is demand I am sure they can add it to the store.
  12. #12
    autoconcierge's Avatar
    Join Date
    May 2010
    Posts
    1,578
    Post Thanks / Like
    20 CC`s will cover 4-5 cars................... really?.
  13. #13
    Join Date
    Apr 2002
    Posts
    29
    Post Thanks / Like
    Re using suede applicator. When I did my car, I took the included blue foam applicator, but snipped off the edges of the circle. This made the foam applicator into a rectangle, preserved the loop on the back to help hold it, and gave the applicator less volume to soak up product.
  14. #14
    Mike The Guz's Avatar
    Join Date
    Oct 2013
    Location
    Lawndale, CA
    Posts
    3,757
    Post Thanks / Like
    Very nice post. I just recently used the newest formula of gloss coat and I can honestly say it`s one of the easiest coatings to use. It also looks great.
    My preference is the suede applicator when applying it.
    Competition Ready Team 1929 Bentley
    1999 Silvermist Metallic Pontiac Grand Prix GT
    2002 Arctic White Chevy Camaro SS
  15. #15
    House of Wax's Avatar
    Join Date
    Nov 2004
    Location
    Roscoe, IL
    Posts
    3,521
    Post Thanks / Like
    sub`d
Thread Information
Users Browsing this Thread
Similar Threads
  1. Replies: 4
    Last Post: 06-18-2014, 08:11 AM
  2. The Gloss Boss, LLC presents: Ford F-150 "Dry Clean" interior treatment.
    By The Gloss Boss in forum The Detailers Showcase
    Last Post: 01-23-2012, 11:02 PM
  3. 3M "Clear Bra" Protective Paint Coating...
    By Brad B in forum Machine Polishing & Sanding
    Last Post: 08-08-2010, 03:58 PM
  4. Looking for "Concours Level" detailer
    By YellowC4S in forum Car Show & Concours
    Last Post: 01-27-2004, 11:28 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
