Lake Country Mfg has done it again. (We don`t know how many times they have done it, but it seems to be a lot!)
With traditional rotary polishing, only the outer most area of the foam is used. The rest of the foam acts a cushion. The new "1 Pad" Finishing System uses a new, patented Tri-Density backing plate that replaces the traditional foam bad. The backing plate is then covered with various foam "skin`s" of thin polishing foam, to help save cost and deliver a more consistent feel when polishing.
The description that best describes the resulting polishing action is smooth. Gone is the radical difference between hard, stiff foams and the spongy feel of softer finishing pads.
Features and benefits.
-Form fitted pads are self centering
-Tri-Density cushion plate maintains consistent cushion feel ... won?t break down with use like conventional pads
-Full radius design allows user to buff safely on entire pad surface
-1-Pad? uses 65% less material that most conventional pads
-Pad shape allows easy transition from flat to vertical surfaces
For me personally the biggest benefit is the consistent feel and the smooth, almost gyroscopic effect of the backing plate.
The system will be available with the following color`s and levels of cut.
PAC will be one of only two select distributors aimed at bringing this professional system to the consumer and end user.
Coming Soon!
Bookmarks
