Page 1 of 2 12 LastLast
Results 1 to 15 of 21
Hybrid View
  1. #1
    Brk4euros's Avatar
    Join Date
    Jan 2005
    Location
    San Diego
    Posts
    87
    Post Thanks / Like
    Well, I removed my lenses from the headlight assembly on my 2004 VW GTI. I have sanded them in/out with 1000grit and then 2000grit. I have tried removing the sanding scratches with many types of polishes and light compounds....no luck. Would a good plastic polish take care of this....Meguiars Cleaner/polish for clear platics?
    Here are a few shots of my ride just for fun, I don`t have any pics of them sanded. My car is currently on stands waiting on new wheels and to finish up prep work and paint. The reason I did this was because there was moisture getting in and some minor pitting from canyon run rocks and what not... :har:
    Old shot
    GeT ThaT ShoW SHiNe YoU DreAmeD oF
  2. #2
    Burn Then Buff! 4830Deuce's Avatar
    Join Date
    Jun 2005
    Posts
    686
    Post Thanks / Like
    try metal polish with a wool pad at very low speeds if using a rotary or 5 using a PC...then make sure you step down your polishes to get a perfect shine!
    I used Menzerna PG after wetsanding my headlights I saw a write up that used metal polish so im just passing it on...
    -Justin
    "God made turbo lag so V8`s could keep up!"
  3. #3
    Brk4euros's Avatar
    Join Date
    Jan 2005
    Location
    San Diego
    Posts
    87
    Post Thanks / Like
    Quote Originally Posted by 4830Deuce
    -Justin
    Thanks!!! Any recommended metal polishes?
  4. #4
    Join Date
    Jun 2005
    Posts
    686
    Post Thanks / Like
    I would suggest NXT for this job...
    -Justin
  5. #5
    Join Date
    Jun 2005
    Posts
    34
    Post Thanks / Like
    nxt polish kicks ***. but first off, i would try a finer grade sandpaper like 3000. and emphasize the WET in wetsand. soak the paper in soapy water for like 15 minutes
  6. #6
    Join Date
    Oct 2004
    Location
    SoCal
    Posts
    2,516
    Post Thanks / Like
    Nice pair of, †headlights.
    You may want to take it a couple grits finer on the abrasives before polishing too. You could try Meguiar’s #3000 paper and/or Mirka #4000 foam pads.
    PC.
  7. #7
    Brk4euros's Avatar
    Join Date
    Jan 2005
    Location
    San Diego
    Posts
    87
    Post Thanks / Like
    Thanks all! Awesome tips!
  8. #8
    Join Date
    Mar 2009
    Posts
    368
    Post Thanks / Like
    Nice *gulp* (is it hot in here ??) headlight assy... I never knew VW`s came with pink`n white headlights though... Huh ? The headlights are the other ones underneath ? Who cares ???
  9. #9
    Join Date
    Jul 2003
    Location
    LA
    Posts
    289
    Post Thanks / Like
    Here`s a write-up I did on Maxima.org on wetsanding my headlights (with pics):
    http://forums.maxima.org/showthread.php?t=375480
    Without trying to offend anyone in any way, I must say the ladies look stunning. I really like the brunette`s ahhhh, hair. Are those two a normal sampling of the population in San Diego? I may be moving.
    Hope this helps.
    Dave
    PS: Thank the ladies for brightening a Jarhead`s day for me.
  10. #10
    CIXELSYD
    Join Date
    Dec 2005
    Location
    Charlotte, NC
    Posts
    548
    Post Thanks / Like
    I sanded the headlamps on my GTI 337 . . . first use 1000/2000/3000 grit paper. Proceed with a rotary polisher, 4†polishing pad, and light abrasive compound. Wipe with alcohol to ensure the lens is crystal clear. Finish with Meg`s Plastx, again using a rotary and 4†polishing pad. Good luck :xyxthumbs
    PS: You may want to consider X-PEL Headlight Protection to guard against rocks.
  11. #11
    Join Date
    Sep 2004
    Location
    Perth, Western Australia
    Posts
    3,454
    Post Thanks / Like
  12. #12
    Brk4euros's Avatar
    Join Date
    Jan 2005
    Location
    San Diego
    Posts
    87
    Post Thanks / Like
    :2thumbs: thanks for all of the quick feedback!
  13. #13
    Join Date
    Jan 2004
    Location
    Oklahoma
    Posts
    326
    Post Thanks / Like
    I found this link on another forum and though it would best fit under this subject matter:
    http://www.nseconsulting.com/bmw/hpt.pdf
    I think it is an excellent write up with pics.
  14. #14
    Join Date
    Jan 2004
    Location
    Oklahoma
    Posts
    326
    Post Thanks / Like
    I finally tried the the method posted in the link of my response above. It work great on a Jeep I worked on today, then I tried it on two of my cars with excellent results. I did sand up to 2,500 and 3,000 sandpaper (did not stop at 2,000).
    After the sanding I polished with Megs 85 using a drill then I followed with Megs 17 and 10. Plexus was my last step.
  15. #15
    AMG Classic Car Detailing Old Pirate's Avatar
    Join Date
    Feb 2008
    Location
    Sunny Florida
    Posts
    11,199
    Post Thanks / Like
    I forgot what i was going to type:shocked
    AutopiaForums is the place to be.
    Remember to Shop Autopia-CarCare.com for your Detailing Needs!
Thread Information
Users Browsing this Thread
Similar Threads
  1. Has anyone "Re-Cleared" Plastic Headlight lenses???
    By imported_Luster in forum Everything Else
    Last Post: 06-17-2009, 08:47 AM
  2. restoring clear plastic headlight lenses
    By bigron62 in forum Auto Detailing 101
    Last Post: 04-27-2004, 05:52 PM
  3. restoring headlight lenses
    Last Post: 04-18-2004, 01:53 PM
  4. Oxidized headlight lenses
    By Heff in forum Car Detailing
    Last Post: 12-22-2003, 10:07 AM
  5. Plastic headlight lenses
    By imported_Eric in forum Car Detailing
    Last Post: 04-25-2002, 03:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
