Page 1 of 2 12 LastLast
Results 1 to 15 of 23
  1. #1
    dcjredline's Avatar
    Join Date
    Dec 2013
    Location
    Near Rochester, NY
    Posts
    788
    Post Thanks / Like
    Heavy cut compound discussion / help
    So the dealer I do a lot of work for has brought me 2 cars lately that were wet sanded. The first was sanded with 2000 grit wetsanding. I tried my Mothers Heavy Duty Rubbing compound with Yellow flat cutting pad and was NOT impressed, had to slow hand speed way down and do 3 section passes 2x each section to get all the dull out. Friday he brought me another one and this time he wetsanded with 3000 Meguiars Unigrit. This time the Mothers HDRC did 50% better but there were still spots it didnt get the first passes. It has a 10 of 10 cut rating on the Autopia Compound and polish chart. I dont get it.
    When I have used it on paint that wasnt wet sanded I have been fairly impressed by it but it not being able to cut through 2000 and now 3000 sanding marks is VERY DISAPPOINTING to me.,
    I also have a boat here for oxidation removal and I started that with the McKees RV Heavy Cut Oxidation remover. Here is the thing I noticed
    The Mothers is VERY liquidy and there is barely a grit feel to it between my fingers, The McKees is an almost toothpaste consistency and the grit was very noticeable. Both shaken VERY well and the bottle of Mothers is probably at least 1 year newer than the McKees.
    Anyone have opinions on this AND anyone have a recommendation for a HEAVY compound that is thick and gritty and actually works well in situations like this? I see compounds rated to remove 1500 and 1200 grit sanding marks and I highly doubt that this Mothers will.
    Don
    1989 Formula 350
    2004 Saturn Ion Quadcoupe
    Likes Stokdgs, Mary B liked this post
    Thanks Mary B thanked for this post
  2. #2
    dcjredline's Avatar
    Join Date
    Dec 2013
    Location
    Near Rochester, NY
    Posts
    788
    Post Thanks / Like
    Re: Heavy cut compound discussion / help
    Sorry, this work is being done with my FLEX 3401 also. Left that part out by accident
    Don
    1989 Formula 350
  3. #3
    dansautodetailing.com Stokdgs's Avatar
    Join Date
    Apr 2009
    Location
    NorCal.. Avatar = Swan Lake, Hallstatt, Austria
    Posts
    5,191
    Post Thanks / Like
    Quote Originally Posted by dcjredline View Post
    Hello, Don !
    Hope all is good with you and your family !
    For any type of wet sanding scratch removal, the only thing that I have ever found that took it out is Rotary Power with Meguiars 105, and Lake Country Purple Foam Wool pads - a lot of them..
    Meguiars 105 will actually finish down really well, if you can get it past the "Im going to dry up immediately and try to ruin your work" part.. And it is easy to get it past that by just spraying a little moisture on the pad and mind it while you are doing the work. Keep on adding just enough moisture as needed, to allow the compound to almost go away completely.
    These L/Country Purple Foam Wool pads will only last so long ( they will go flat and not fluff up any longer), and then you have to toss them and get a new one out.. They are made to work this way... You will be able to tell when they no longer change the paintwork they were just used on...
    I have used this same process and products on very dirty, harder than granite, Urethane Airplane paint (2 different colors), and while it took an enormous amount of hours, it took the airplane paint to a beautiful, pretty clear, and very glossy state, ( M105, and M205 with White Flat Foam), that the Owner could not believe when he saw it again.. He was so excited that we pulled the airplane out of the hanger so he could take pictures of it..
    Regarding Boats, the absolute best Boat Detailer in Seattle WA., and surrounding areas, uses nothing but Rotary Power and heavy compounds to knock all that stuff off that sticks even worse to gelcoat... I have seen his work on jet black boats and they look every bit as good as what I can achieve on jet black automotive paint.. He routinely kills DeWalt Rotaries every year from this hard work, and lucky for him, he has helped DeWalt design better quality Rotaries for this application, and they give him a break when he sends in the the dead ones, on new ones...
    Any random orbital would never last very long trying to Detail gel coat... He laughs when companies send him random orbitals to test out..
    Gelcoat takes even longer to correct than automotive paint... I will never want to detail boats!!! Or anymore Airplanes!
    Later on but still a while back, Meguiars came out with Meguiars 101, which is similar to M105, but made specifically for Foam Pads, used in Europe...
    Eventually, Meguiars made M101 available in America; this might also be a great option to try... Here is a link for it -- https://www.autopia-carcare.com/megu...l#.W5X8U1WpH3g
    Coming from the auto painting world as well, we used nothing but professional products; back then it was all 3M products to get similar results with all types of automotive paintwork in all the different conditions we found it in...
    I have had a Flex3401VRG since they first came out! I immediately cut down the 6" backing plate to work with 5" pads and that alone helped, but it will never be able to put down the power of a direct drive rotary.. As I remember, the marketing for it was that this machine will give you rotary benefits and random orbital benefits, to help one never have to deal with rotary holograms, etc...
    I tried it to see what it would do, and it would handle minor paintwork issues pretty good, but nothing like a direct drive can accomplish... It has been having a long, long, vacation, in the machine cabinet..
    Well, in my 50+ years of holding 10lb Rotary machines, , I have never had issues with creating all those rotary "defects" people talk about all the time anyway..
    It is all about keeping the pad, product, and paintwork just moist enough so all 3 can have a nice time together, knock out the needs for that spot, wipe it off, and move on...
    Keeping speeds below or right at 1,000rpm also helps these 3 key elements (Pad, Product, Paintwork) working together nicely, until it is all broken down, the pad cleans most of it all up, and all you have left is very little to wipe off, thereby eliminating another source of adding more defects to the paintwork...
    This is exactly how I was taught as a 10-year-old boy, and the same lessons were reinforced by some really great painters, throughout my life, until I went out on my own, and then taught others who were new to the business..
    Don, you may find your own "technique" to arrive at the same place be different than mine, or anyone else`s, but I can promise you, the basics for the 3 elements above, (Pad, Product, Paintwork) really need to be able to get along nicely, and when allowed to, you will always see great results..
    Sometimes, I have had to lean a little harder ( I always put pressure on it) on some defects in paintwork to help the process be more efficient, and quicker, and that is ok too, as long as you mind the total paint thickness of that spot, the type of paint - soft, medium, hard, very hard, granite, etc..., and how much heat you are creating... Strive to keep the heat down, let the spot cool off if it got too hot.. Look it over very carefully, do not let it get "sticky"..
    So, you may need to consider using a direct drive Rotary to really knock this stuff out faster and give you incredible, beautiful, clear and glossy paintwork..
    Wish I was there to help !!!
    Dan F
  4. #4
    Join Date
    Oct 2015
    Posts
    136
    Post Thanks / Like
    I will second the suggestion to use your rotary and a wool pad. Then finish with the 3401.
  5. #5
    jatleson's Avatar
    Join Date
    Sep 2016
    Location
    North Chicago Suburbs
    Posts
    236
    Post Thanks / Like
    Can`t speak to sanding marks, but M101 using a Boss 15 DA and Griots Boss Microfiber got through some deep scratches and scuffs on `hard` black Mercedes paint no problem. I like Stokdgs suggestion to add a little moisture to extend working time, ease removal and I bet it controls dusting a bit.
    I don`t compound often, so I don`t have some of the newer formulas, but the way M101 gets through stuff, I really don`t need to shop.
    Atleson Detailing Service
    FB - https://www.facebook.com/AtlesonDetailing/
    WEB - https://sites.google.com/prod/view/a...detailing/home
  6. #6
    Autopia Specialist RaysWay's Avatar
    Join Date
    Jan 2014
    Posts
    4,832
    Post Thanks / Like
    Rotary + Wool + Meguiars M100 is the friend you need. I don`t ever plan on using a DA to remove sanding scratches.
    Instagram: www.instagram.com/rayswaydetailing
    Facebook: www.facebook.com/RaysWayDetailing
    Website: www.RaysWayDetailing.com
    Likes Stokdgs, Mary B, JustJesus liked this post
  7. #7
    dcjredline's Avatar
    Join Date
    Dec 2013
    Location
    Near Rochester, NY
    Posts
    788
    Post Thanks / Like
    Thank you for the specific post Dan. And thank you everyone else. Looks like I will have to bust out the rotary. I was hoping there was something I was missing. And I will have to price those jobs to go around the vehicle 2x instead of once.
    Not the news I wanted but the news I needed to hear.
    Don
    1989 Formula 350
  8. #8
    A Miracle Detailing Merlin's Avatar
    Join Date
    Sep 2010
    Location
    Sunny South Florida
    Posts
    2,579
    Post Thanks / Like
    You may wish to try Jescar Correcting Compound with a wool pad on your 3401.
    M101 is another favorite compound and (although designed for foam) works well with a wool pad on a 3401.
    You will need to follow up with a polishing pad and a finishing polish. I suggest trying Jescar Micro Finishing Polish.
    AMiracleDetailing.com
    YouTube - Facebook - Instagram
    Likes Stokdgs, JustJesus, Mary B, dcjredline liked this post
  9. #9
    Join Date
    Apr 2009
    Location
    Posts
    5,191
    Post Thanks / Like
    Mi Amigo, Don !
    You are welcome ! I am sorry its not going to be easy - but - it will be worth it to just knock that stuff out and as has been advised by some of the BEST guys out there, come back with your Flex 3401VRG and it will be very fast and easy to remove anything left in the paint to totally bring the clarity and gloss out to an amazing level..
    You are in total control of exactly what level you want to end this all at, I am positive, the results will be stunning to the Client...
    Dan F
    Likes Mary B liked this post
  10. #10
    JustJesus's Avatar
    Join Date
    Sep 2014
    Location
    So Cal
    Posts
    2,534
    Post Thanks / Like
    Oddly enough, I was planning on making a thread for a recent combo I did over the weekend. Hopefully, I can do it today.
    At any rate...
    On a softer-side OEM Toyota Yaris paint:
    - a bit of damp sanding with 2000 grit
    - compound with CarPro FLASH pad
    - Menzerna FG400
    - Flex 3401
    In just two passes, I got good results. I later went back to clean up parts I missed with those two passes. Got rid of the sanding marks, and finished well.
    Like i said, I`ll try and do the thread (with pics) today.
    Likes Stokdgs, Mary B, rlmccarty2000 liked this post
    Thanks Stokdgs thanked for this post
  11. #11
    Join Date
    Sep 2002
    Location
    NE Ohio
    Posts
    86,984
    Post Thanks / Like
    I use the 3401 with M101 and just do as many passes as it takes. I`d probably ly at least consider resanding 2K with 3-4K, I don`t like working 2K scratches.
    Likes Stokdgs, dcjredline liked this post
  12. #12
    JustJesus's Avatar
    Join Date
    Sep 2014
    Location
    So Cal
    Posts
    2,534
    Post Thanks / Like
    Likes Stokdgs liked this post
  13. #13
    Join Date
    Oct 2017
    Posts
    1,168
    Post Thanks / Like
    Could it be that they sanded before with a lower grit sandpaper? So they did not sanding down the first sanding enough. Or the defects before they started sanding was to deep to be sanding down.
    I think that I would test with a different pad and compound first. Lake Country does a thick and a thin purple wool pads that works on DA polishers. Combo them with your 3401vrg and a heavy cut compound. Maybe your Mothers compound can have the cut to get where you are expecting to get. Sonax Cutmax and Menzerna SHC300 and Carpro ClearCut I think would give you the cut you want. The Meguiars m100 or m101 you have the benefit with SMAT abrasives so you can work it for a long time. Just some suggestions before investing in a new rotary polisher. Or you maybe have a rotary already? A rotary would get you the high cut and working faster. But I think that your 3401vrg would handle to polish out p2000 sanding marks quite easy with the right combo of pad and compound.
    Likes Stokdgs, rlmccarty2000, dcjredline liked this post
  14. #14
    dcjredline's Avatar
    Join Date
    Dec 2013
    Location
    Near Rochester, NY
    Posts
    788
    Post Thanks / Like
    Quote Originally Posted by JustJesus View Post
    At any rate...
    - Menzerna FG400
    - Flex 3401
    Ill check the thread later thank you. Ive done MANY MANY spots or panels that were wet sanded with really good luck. There is a HUGE difference between doing a spot/panel to the whole stupid car lol. This last car was an 11 Cruze there are many contours on those and cutting those are the worst part of it. Thanks again for the comment, I will get some before and afters of the boat for everyone.
    Don
    1989 Formula 350
  15. #15
    dcjredline's Avatar
    Join Date
    Dec 2013
    Location
    Near Rochester, NY
    Posts
    788
    Post Thanks / Like
    Ok, a little update.
    1. I wasnt using enough product
    2. Even with a wool pad and rotary the results were minimally better cause the gelcoat was in bad shape.
    Looks like photo gallery is STILLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL not working.
    Don
    1989 Formula 350
Thread Information
Users Browsing this Thread
Similar Threads
  1. Heavy Compound w/Rotary?
    By M0nk3y in forum Machine Polishing & Sanding
    Last Post: 06-13-2008, 05:05 AM
  2. Anyone Use Megs#4 heavy cut compound?
    By Carbon Blue in forum Car Detailing
    Last Post: 11-06-2007, 08:20 PM
  3. recommend a heavy compound
    By matrix_808 in forum Car Detailing Product Discussion
    Last Post: 10-30-2007, 12:10 AM
  4. Optimum Polish / Compound Discussion.
    By poyo in forum Car Detailing Product Discussion
    Last Post: 10-27-2007, 08:04 AM
  5. 1Z Heavy Compound Polish
    By pingable in forum Good Deals
    Last Post: 04-28-2007, 09:28 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
